Stability Control Light
Discussion in 'Gen 3 Prius Technical Discussion' started by thx2112, Oct 14, 2010.
  1. thx2112
    thx2112 New Member
    Los Angeles
    When I am at a full stop, such as waiting at a stoplight, and I press hard on the brake pedal, the stability control light flashes on the instrument panel. Has anyone else experienced this? Does it indicate a problem? Thanks.
  2. ozthis
    ozthis New Member
    Kansas
    I noticed mine does the same thing....dont know if it is normal or we have the same problem
  3. socratesthecabdriver
    283
    31
    greece
    it a special feature,when on a uphill you activate it by presing on the brake in the same maner so that your car dont roll backwards when you take your foot of the brake for a couple of seconds until you hit the accelerator hehehehe
  4. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    It's in the manual.
  5. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    yep this has came up a few times. it's Hill assist. It will hold the car in place long enough for you to take your foot off the brake and to press the gas. it prevents you from rolling backwards on hills if you use it.
  6. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    It's a reminder to read the user manual. :p
    Seriously, it tells you that you have invoked hill assist.
    Tom
  7. Tideland Prius
    16,403
    Like others have said here... it's the Hill Start Assist. You activate it by pressing the brake pedal past a little dente.
