Stall in San Fransisco
Discussion in 'Gen 2 Prius Technical Discussion' started by Stalix, Feb 11, 2007.
  1. Stalix
    Stalix New Member
    Me and my friends were driving on two separate cars to San Fran from Sacramento. I on my 2001 Toyota Prius with 77K miles, and my friend on his SUV. WE arrived without problem... well almost. Just as we got to our destination at a stop light my called stalled like never before. The engine stuttered to a stop and the touch screen went white and all the displays went dim as if I had a low battery. A few minutes later my Friend pulled up behind me and I jumped my battery and we started up fine with the exclamation point and check engine light on. So we go to the parking lot, and just as a start accelerating from a stop the car does the same, luckily i was able to roll to a parking spot. At this time I didn't know what to do, so we just did what we came to do hang out.
    after 4-5 hours later we come back to the cars to start heading home, the car starts fine and and we head toward the highway, but then as we are going up one of this insane inclining hills my car looses power, I floor it and no movement, and as soon I i press the brake the car stalls and power gets dim again.
    Another jump later gets me a little further. Taking me to a quite crowded street, where a lot of experimenting takes place which I will explain. first as long as I'm jumpered to my friends alternator the car runs fine. I take of the jumpers and as soon as I turn on my headlights and or heater i see the screen start to flicker as to having no power. This is where I though it was my alternator just not charging the battery. so I trade batteries with my buddies car and off we go and got a good distance, just to the on ramp to the highway which is juts before the bay bridge. I stalled and that was it. Luckily a Cal trans tow helped me get to the other side of the bay bridge and into Emeryville. At that point the battery looked as if it was completly dead and so we left the car there and and all went on my buddies SUV back home.
    Now I come back this morning and it starts just fine, battery seems to be good, no check engine lights, and no problem. Drove all the way back to sacramento and haven't had the problem yet, but I'm so afraid of this car now.
    Sorry for the long type out but I wanted to be thorough. Any help diagnosing this problem please.
    The only problem I had before this was the normal cold morning P3139 stall once in a long while, i heard that was caused by a faulty computer, and that the dealer changes it for free under 80k miles?
    Any help guys would be appreciated.
  2. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi Stalix,
    Have you ever had the auxiliary 12 volt battery replaced ?
    Lead-Acid batteries can develope intermitant shorts, and high resistance. If a cell shorts out, that may drop the voltage below what is needed for the Prius electronics. If it develops high resistance, the amount of current required may also just drop the voltage too low.
    I hope its not the DC-to-DC converter.
    If you have never replaced the 12 V battery after 6 years, that is the most likely thing that is bad. 12 V Lead Acid batteries rarely last that long.
  3. Stalix
    Stalix New Member
    <div class='quotetop'>QUOTE(donee @ Feb 11 2007, 02:49 PM) [snapback]388585[/snapback]</div>
    Thank you for your reply, I dont think it was ever replaced, I got this car in mid 2004, and so don't know.
    So all my problems could have been caused by a bad 12v battery? then how come when I traded batteries with the friend it drove fine for a while but then stalled anyways?
    could this have anything to do with the computer?
    And I want to figure out, when the car is started and the gasoline engine turns off, where does it take the power from to restart the engine? The 12v battery or the hybrid battery?
  4. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi Stalix,
    I am not a total expert on the Prius, but thought I would give you a quick response.
    Not sure what happened when you swapped batteries. But if the terminals were not clean, this would cause similar problems.
    When the car is started, the 12 volt batery closes the main-disconnect relay inside the drive (or hybrid) battery box. The purpose of the relay is to disconnect the drive battery from any external circuitry during power down, or in the case of an accident.
    Once the relay is closed, drive battery current flows to the inverter, which routes it to the MG1 (called the generator sometimes), which then cranks the engine.
    Electronic circuitry is typically designed to operate at specific voltages applied at various points of the circuit. If one of the voltages drops below the design value, the circuit might not work as designed. There are devices called "voltage regulators" that set the voltage. One part of the circuit might run at 5 volts - like logic circuits and a computer. Another might operate at 10 volts - like an analog circuit used to receive and precondition signals from sensors. If the voltage drops down below 12 volts, the 10 volt regulators will drop out of regulation, and the sensor signals be corupted. A loose connection might cause intermitant dropouts of the voltages, which would also corrupt the sensor signals. The supply used to light of the MFD panel might also need a minimum voltage for its power oscillator to switch, so that it can provide AC signals to voltage changing transformer.
    This is all general stuff, and I do not have specific information on the Prius. Yes, a bad battery, or connection from the 12 v battery could cause problems you reported to the best of my knowledge. That does not mean that the 12 v battery and its connections are the cause, or the only defect. Running the car on jumper leads is NOT sufficient due to the intermitant connections that can occur as the jumper battery clips move around.
    When you hit the brake, or otherwise use extra 12 volt power beyond what a damaged or weak battery can provide, (brake lights might drop the 12 volt supply voltage) it could then effect the electronic controls. With the result that they go offline, and the car just stop, or the computer react incorrectly.
    What you typed seems to indicate the 12 V battery is not being charged though. Which may be a more serious problem. But probably not the computer or the hybrid battery. To avoid damage to those, you should get it to a qualified Prius mechanic soon. Do not run down the hybrid battery. If the engine quits, get it to the side of the road and call for help. Do not try to use the battery to run the car for more than a few hundred yards. And no distance at all if your in the pink State of Charge (SOC) bars.
  5. slvr_phoenix
    slvr_phoenix Tinker Gnome
    84
    <div class='quotetop'>QUOTE(donee @ Feb 11 2007, 06:51 PM) [snapback]388640[/snapback]</div>
    I agree. Sounds to me like it's not recharging the battery. The friend's battery worked fine at first because it had a charge ... until operating the car drained it. I'd say take it to a qualified mechanic/dealership and let them sort it out.
  6. D0li0
    D0li0 New Member
    118
    Seattle, Wa
    <div class='quotetop'>QUOTE(Silver Phoenix @ Feb 13 2007, 11:58 AM) [snapback]389610[/snapback]</div>
    You might also check to see if there's a main fuse for the 12v system that may be keeping the DC-DC converter or "alternator" from charging up the 12v battery.
  7. tochatihu
    tochatihu Senior Member
    9,457
    3,656
    Kunming Yunnan China
    2001 Prius
    Hi Stalix, unsure if problems with your 12 volt battery can cause all of that, but That ought to be a relatively easy system to diagnose. You need a Toyota shop, or if you can swing by Oakland, Art's Automotive.
    You mentioned an earlier non-start trouble code (you may have meant P3190). I guess that the engine control module was not replaced at that time? This may be the source of your current woes. It would be warranteed until 80k miles (technical service bulletin EG011-03). However, there are other components in that TSB under 36k mile warranty which sometimes appear to need replacing as well.
    If your shop finds the P1120 code, you may need a new accelerator pedal. Expense from Toyota; less if you buy one of my rebuilds. Accel pedal sensor problems do not always cause that code to be stored, but the feeling of losing power while driving is pretty diagnostic. Often called 'the big hand syndrome'.
    Finally, there are cheaper alternatives to Toyota's 12 volt battery, if that turns out to be needed.
    Please let us know your progress on this. Good luck.
  8. Stalix
    Stalix New Member
    well everything was fine, 1 month has passed since teh incident in San Fran. Anywas it happened again today, luckily very close to home.
    I was driving with another battery than before, going 50 on the freeway when i hear a BIM sound, and check engine and the exclamation point shows up.... Damn it!!!
    Than I'm like please get home... please, as soon as I pray my little prayer, my dash lights get weak and a stall in the middle lane of trafficked freeway. I waited for a while and I got it to start and got off an exit and and repeated a couple time until i got home. So I though cool now I have a chance to OBDII this sucker. I first open the hood and inspect things to be safe, the Power invert or convert ... the electrick engine lit was extremely hot!!!!. couldn't hold my hand for more that 5 seconds.
    anyways I plug in the OBD II and get 2 codes: P3125 & P3130 both Auxiliary Emission Controls System codes.
    So now I don't know what to do...
    And I have found a thread with a person that had the same problem: http://priuschat.com/index.php?showtopic=2...mode=linearplus
    so what the is air in my coolant line? how can I get it out and/or can i have the dealer do it for free? since my car is salvaged title and all?
  9. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi Stalix,
    Well the dealer wont do it for free, but if all it is , is a cooling system buble, then a properly experienced Prius tech should be able to bleed out all the bubbles in no time, and little money. Galaxy, who's SO is a Prius Tech on the east coast has indicated it can be tricky to get the cooling loops right.
    But, I would not drive it more than short, slow trips in cool weather till its fixed. You may want to change the oil too, if the engine got hotter than usual the oil maybe degraded. Mobil 1 full synthetic oil would be called for, until the overheating condtion is taken care of.
    You want to get this taken care of fast. Both the engine and Hybrid Inverter have cooling circuits and seperate radiators. The Hybrid Inverter is expensive, and the older Prius are not so pletiful, so they may be short supply. If the inverter is not getting cooling, you will definately blow it.
    If you do not know if the transmission oil has been changed, you should have it changed as well done too. Its due at 77K miles in a Gen 1 Prius.
  10. Stalix
    Stalix New Member
    Are there any instructions online how to bleed the system? I know someone who could do it, but they are just a normal engine mechanic. they are very good though, I'm sure if I had some instructions they could do it for me.
  11. Stalix
    Stalix New Member
    Looks like even if I do get the bubble out, there was already damage to the inverter assembly.
    Unless someone proves me wrong I think this car is scrapped.
    any info please!!!
  12. tochatihu
    9,457
    3,656
    2001 Prius
    Here is a link to a document that explains the NHW11 (2001-2003) Prius DTCs and subcodes:
    http://www.ecrostech.com/Products/MiniScanner/UserManual.pdf
    3125 related to inverter function and 3130, inverter cooling.
    Excerpts from the technical manuals describing how to refill and bleed both coolant systems are in
    http://autos.groups.yahoo.com/group/Prius_...olant%20change/
    but I believe you have to join that Yahoo group (painless) to access them. If you have problems accessing these files PM me and I can email them to you directly.
    Based on your new codes, I agree that the inverter etc. is having a heat problem but it is not necessarily "cooked". There is, apparently, a "limp-home" mode that allows the system to continue operating at reduced power levels when it is unhappy.
    Bleeding the inverter coolant loop is a high priority. If your Sacramento mechanic still has questions on the procedure after reviewing the docs above, the independent hybrid shop in Oakland I mentioned earlier (Art's Automotive) may be a resource.
    With the coolant loop functioning correctly, further driving should reveal if there is any damage. If you need a replacement inverter (and don't like Toyota's prices), they are removed from totaled Prius and sold by salvage vehicle dismantlers such as LKQ online (just one example). When they show up on ebay they are typically $300. Good luck.
  13. bwilson4web
    15,934
    <div class='quotetop'>QUOTE(Stalix @ Mar 12 2007, 10:08 PM) [snapback]404539[/snapback]</div>
    There is an inverter coolant reservoir to the rear and left of the inverter. What color is the liquid and where is it relative to the 'fill line'?
    When you turn on the car, do you hear a small pump run near the driver side, low? This is the inverter coolant pump that normally runs all the time.
    BTW, salvage inverters are available and though I bought my extra one for $500, I suspect you can shop around and find one for less.
  14. Stalix
    Stalix New Member
    Thanks guys for all your replies. I have access to a salved prius with the front intact that has 30k miles on it. so if it comes to changing the inverter there is no problem finding one the only thing is, I was talking with my mechanic and he's hard of believing that something as simple as a bubble could cause the engine to stall and display my symptoms.
    I think I got the coolant tank right, its the one just to the left of the inverter when you open your hood. The fluid is reddish in color, and is just a few mm above FULL line.
    Also I remember the sound of the inverter coolant pump whizzing before, but I haven';t heard it lately, but I haven't been paying that much attention to that pump anyways. Could it possibly be the inverter coolant pump that is causing the problem?
    and how do I convince my mechanic that a simple bubble in the coolant line could cause such a problem like mine.
  15. bwilson4web
    15,934
    <div class='quotetop'>QUOTE(Stalix @ Mar 15 2007, 12:42 PM) [snapback]406156[/snapback]</div>
    A failed pump could cause the problem. I don't have my maintenance manuals handy but maybe someone could walk you through the steps. There may even be a fuse to check.
  16. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi Stalix,
    There is a good chance there has been no damage to the inverter. But there might be damage that would still allow the car to function.
    In their writeup on the inverter developement, Toyota mentions the work they went through to put a temperature sensor right in the inverter switching transistor chip. This was unique for the time, due to the large electrical noise in such power devices, and the small temperature signal most temperatue sensative semiconductor devices deliver. The advantage to having the temperature sensor integrated on the chip is so there would be minimal time delay between an overheat condition, and sensing it. The sensor is also sensing the temperature of the very semiconductor (SiliconCarbide in the case of the Prius) that the inverter switching devices are operating through, not a metal block that the semiconductor may have lost thermal conductivity too. Sensing such a condition quickly and accuratly then allows the car to fault out, and avoid pushing the inverter chip too hot that it would fail.
    But that does not mean that parts of the chip could become changed, and develop partial open, or higher resistance. Which would make the chip more prone to getting hot in the future. It may work just fine for average driving once the cooling buble is removed. And may not be damaged at all. Its just if you keep tempting fate by not getting it fixed, it will fail permanently eventually.
  17. Mr.Vanvandenburg
    1,311
    534
    2020 Prius Prime
    Just a note from a new owner(three days.) I saw in the warranty that salvage vehicles ARE covered under the CA emmissions control warranty, which may be still in effect for your car. The waranty is 15 years or 150,000 miles in CA on the parts listed for today's model. It includes the inverter and computers.That's how I read it anyway. Good luck.
  18. statultra
    statultra uber-Senior Member
    798
    31
    Edison,NJ
    2001 Prius
    i had this problem but not to your extent, my dash lights went dim , but luckily everytime i entered my driveway, i really hope no damage to your inverter/converter, if the car is not under warranty, change the inverter coolant, and check the water pump, i also have a feeling the pump that circulates inverter coolant may be damaged, need to get that checked too.
    i am just hoping your inverter is ok, i ran my car in this condition and its still good as new ( considering i fixed the problem ), also make sure there are NO AIR POCKETS what so ever in the coolant, but using the toyota coolant its pretty hard to make a air pocket if you follow toyota instructions.
    to check the pump, turn the ig on without ready mode, and pop the hood, facing the front of the vehicle there is a black pump located near the drivers side headlamp, this pump circulates inverter coolant, if it is possibly listen in that area, if you hear the gushing of water, if not , put your hand on it ( make sure the engine is cold too ) if iyou feel some sort of a vibration then it might be a good pump, also check the inverter coolant level, located right next to the inverter.
    it is very easy to change inverter coolant, just drain and replace in the tank located next to the inverter, you must buy toyota long life coolant. hurry and do it before its too late.
    for the sake of your prius i hope it gets cold
  19. Loveit
    Loveit New Member
    473
    <div class='quotetop'>QUOTE(Stalix @ Feb 11 2007, 06:30 PM) [snapback]388579[/snapback]</div>
    Does the car have a computer chip type thing in it? If so, it is very possible that it is no good.
    I had the same thing happen to me years ago in a Plymouth Voyager.
    It came to a dead stop.
    It sounds like a connection problem or the computer chip is wacked out.
  20. Stalix
    Stalix New Member
    ahem... plymouth voyager is a normal car, prius is a hybrid. You can't really use the same troubleshooting tips on both.
    Anyways I already tried a know working good computer and it still had the problem.
    Today I changed the inverter coolant pump, because the front of the tank wasn't lifting up like the other prius i have. anyways I swapped the pumps and now both reservoirs show good pump flow. I don't really care as long as it works. Now to wait for a very hot day to take it for a test drive. But it looks pretty good already, I drove it around a bit and the inverter assembly want hand scolding hot anymore.
