Steel wheel question
Discussion in 'Gen 3 Prius Main Forum' started by abutler6615, Sep 14, 2011.
  1. abutler6615
    abutler6615 Junior Member
    Pittsburgh, PA
    Does anyone know if a set of steel wheels from a 2006 corolla will fit the 2010 Prius? I have a line on a set from cl and want to use them for my winter tires. They are 15". Anyone have experience with these wheels?
  2. Teakwood
    Teakwood Member
    491
    73
    New Mexico
    They are heavy and will reduce your MPG
  3. JimboPalmer
    12,470
    6,875
    Greenwood MS USA
    Both the bottom of the line 2006 Corolla and the 2010 Prius Two use 15" wheels with a 5-100 bolt spacing and a 5.35" offset. So aside from gas mileage, they should work.
  4. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Yes, as Jimbo said, they will work... I have a sent of winter tires/rims I use and work great. Yes, you will lose FE but I think in my case that has more to do with the studded tires I have.
  5. ETC(SS)
    6,841
    As others have pointed out....they'll work.
    You'll have to put black tape over your TPMS light.....or....you can make a pressurized pvc gizzywhopper to put your TPMS sensors in...or....you can go through the trouble of mounting your sensors into the winter tires.
    Personally, if I lived in the frozen north, I'd use black tape.
    Don't worry so much about the fuel economy. You're going to see 10,000 angry "Why did my MPG drop???' posts this winter just like last winter.
    That's life.
    Good Luck!
    Drive Carefully this winter!!
