Steering Column Rubbing Noise
Discussion in 'Gen 2 Prius Technical Discussion' started by dksachdev, Oct 29, 2008.
  1. dksachdev
    dksachdev New Member
    Vienna, VA
    Our 2009 Prius is just over one month old. With the car switched on, if I turn the steering column right or left, I can hear a noise which looks like something rubbing against the column. The dealer has changed the yoke sub-assembly, shaft sub-assembly and the airbag cable, but the noise is still there. Another brand new Prius has a similar noise but at a lower level.
    Any similar experience or solutiion?
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    I'd say it's normal. I had it on my 04 and I have it on my 09.
  3. dogfriend
    7,512
    1,188
    Carmichael, CA
    If the car is in Ready, and not moving, if I turn the wheel either direction I can hear the tires scrubbing on the concrete (I try to avoid this, BTW). Is that the same noise?
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,829
    Clearwater, Florida
    Yes I hear the exact same thing on my 07 too if I turn it lock to lock sitting. Its normal for our cars. Don't worry about it. When your driving you can't hear it though. When your driving you don't really turn the wheel that much or at least that quickly. I suspect there's quite a slip ring in there for all the steering wheel mounted electronics.
  5. john_dough
    john_dough New Member
    75
    2008, pkg.2, 2 months old---I get it too. It's not annoying while driving.
  6. chriscard25
    chriscard25 New Member
    35
    Chicago area
