Steering suddenly went out
Discussion in 'Gen 2 Prius Technical Discussion' started by [email protected], Jul 5, 2007.
  1. jkglolo@msn.com
    [email protected] New Member
    A few times in the past two days, when turning at slow speeds (like onto my street or into my driveway) the steering would suddenly lock to the point where I couldn't complete the turn. The first couple of times it came back after a few seconds or if I turned the wheel the opposite direction. But just now, turning in my driveway, it completely locked and I couldn't turn it AT ALL in either direction. No warning lights come on and the car is functioning perfectly otherwise. I turned the car off, waited a while and started it again and the steering wheel still won't turn at all. What is that about?
    I have a 2003 classic with 57K miles. I bought it used last summer and the only other problem I have had with it was a shifter sensor that came loose and when they repaired that, they also said I had to replace the auxillary battery.
  2. bwilson4web
    15,937
    <div class='quotetop'>QUOTE(jguyot @ Jul 5 2007, 01:23 AM) [snapback]473360[/snapback]</div>
    The fleet reports included problems reported with the steering. Given the inability to complete the turn, it sounds like the steering gear is broken and will have to be replaced.
    GOOD LUCK!
  3. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Did it lock, or did it seem like the power steering motor was fighting you? The latter was affected by a service campaign followed by a "lifetime" rack warranty.
  4. subarutoo
    subarutoo New Member
    1,213
    23
    Chatsworth, CA
    A similar thing hapened to my nephew driving a Range Rover, in a "bad" part of town with no steering. It's not just a Prius only issue. Good Luck with yours.
  5. galaxee
    galaxee mostly benevolent
    9,810
    468
    MD
    could be one of two things:
    1. if it is incredibly difficult to turn, then it's a rack and pinion unit (steering gear, as bwilson referred to it). not cheap, unfortunately.
    2. if it is completely locked like it is in park, could be the steering column lock.
  6. jkglolo@msn.com
    Update on the steering problem: When the tow truck came to get it, the big burly driver was able to crank it loose (using all his strength) from its locked position. He towed it to the dealership, and now they cannot reproduce the problem (I usually had to drive it for a little while before it would do it) and nothing shows up on the diagnostic gizmo. They said they never heard of any problems with the steering on the 2003. Any more suggestions? I have the platinum warranty. There is no way I am driving it again until it is fixed!
    In response to htmlspinnr -- the first times it felt like all the assist went out of the steering, but if I turned the wheel as hard as I could I could get it to turn, albeit not as tightly (as in turn radius), and then it would come back to normal. But the last time, it felt like it was locked and I couldn't turn it either way no matter how hard I tried (I am a woman with a fair amount of arm strength from carrying around my kids).
  7. jkglolo@msn.com
    Another update: The Dealership just called back and said the rack and pinion unit needs to be replaced -- which will be covered under the platinum warranty. Unfortunately, it won't be ready for four more days.
  8. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    If at all possible, get the tow truck driver to call the service manager. This will make a big difference. If nothing else, get his name and company so that they can call him. You have a witness.
  9. ibmindless
    ibmindless Member
    206
    <div class='quotetop'>QUOTE(jguyot @ Jul 6 2007, 01:45 PM) [snapback]474224[/snapback]</div>
    Boy, I would make sure they provide you with a good and FREE rental/loaner car now! I hope you're not driving that car around. You're a hazard to yourself and everyone else on the road. This is a Lemon Law situation, so I would insist the dealer replaces the rack as soon as possible and that they provide you with a loaner until the car is fixed. Also be sure to ask what the warranty is on the new rack installation.
  10. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    <div class='quotetop'>QUOTE(ibmindless @ Jul 7 2007, 07:17 PM) [snapback]474805[/snapback]</div>
    After 4 years and 1 repair attempt I doubt it would qualify under a Lemon Law (certainly not NJ's). Shouldn't the platinum warranty cover the repair and the loaner/rental?
  11. hschuck
    hschuck Member
    385
    bay city, ca
    Score 1 for the extended warranty. It might be useful for someone to keep a log of extended warranty experiences (good and bad). This is the first one I remember seeing reported.
  12. valrit
    valrit New Member
    I had the exact same thing happen today, just as you have described it with the steering wheel suddenly freezing up, no funny lights going on or anything, and then having to get a burly man un-stick it. Now it randomly freezes when I'm turning, and so I throw all my weight on turning it while braking and trying not to hit anything . . . hardly safe city driving. I have not taken it in yet--should I bother taking it to a regular mechanic or go straight to a dealership? It is a 2003, no longer under warranty for this I think. Jguyot, did this cost a crazy amount of money? (before they applied your warranty, that is.) Any advice appreciated,
    <div class='quotetop'>QUOTE(jguyot @ Jul 6 2007, 02:07 PM) [snapback]474203[/snapback]</div>
  13. bwilson4web
    15,937
    <div class='quotetop'>QUOTE(drvalerie @ Oct 13 2007, 09:53 PM) [snapback]525321[/snapback]</div>
    User 'Jquyot' posted about their problem and have not returned. During the Dept. of Energy fleet study, the analysts reported problems with the steering that had to fixed. I don't know if Toyota has a technical service bulletin on this that would still apply. You might check the "Maintenance" forum to see what has been posted. Regardless, it does need to be fixed since it leaves the car a hazard to drive.
    GOOD LUCK!
  14. tochatihu
    tochatihu Senior Member
    9,457
    3,656
    Kunming Yunnan China
    2001 Prius
    drvalerie, Toyota issued a warranty enhancement for the power steering covering 2001 through "early 2002' Prius. I understand that yours is a 2003.
    You must consult a Toyota shop as to whether you are still covered by warranty. If not, contact Toyota directly at 1-800-331-4331 and ask them to open a case file and request some (financial) assistance in repairing it.
    If yours is similar to the earlier ones, the torque sensor has failed and the entire unit must be replaced. The full cost would be approximately $2000 for a new one installed. Obviously this would not be the ideal solution.
    If you cannot get some help from Toyota, then you might also consider purchasing the unit from a salvage vehicle dismantler. A 2003 donor vehicle would be preferable to 2001 or 2002.
    In either case, the labor to remove and replace the unit would be approximately 4 hours.
    It would be appropriate for the Toyota shop to perform diagnostics to confirm that the unit does in fact need to be replaced. Perhaps there is a simpler solution? Good luck and please keep us informed.
  15. valrit
    valrit New Member
    Update on my steering problem:
    I first took it in to the regular mechanic, on the off chance that there would be a simple solution. He told me that they can't deal with the electronic component of the steering, so I should take it to the dealer. Then I took it to the dealer today at about 3. They just called and said that the rack/pinion needs to be replaced, and that it is not under warranty anymore after 3 years (I've had the car almost 5 years). THEN, he said that Toyota was willing to pay for the parts and labor for the rack/pinion as a "goodwill warranty", IF I had them do the 60k maintenance (which I need to do anyway) for about $500. I accepted. This was Northside Toyota on Broadway in Chicago.
    Some may think I should have played harder ball with this, but I really need my car back, and $500 is a lot better than the worst case scenario I was fretting about. And they really *should* pay for the steering problem, considering that Prii manufactured right before and after mine, in various parts of the world, had steering issues that got extended warranties or other concessions (see the info on this very site). So I'm relatively happy with this turn of events today. I love my little black 2003 Prius, and I'd hate to have to part with it before it's even paid off!!
    I'll report any further interesting details--thanks for the advice and info--
    Valerie
    <div class='quotetop'>QUOTE(tochatihu @ Oct 14 2007, 09:37 PM) [snapback]525660[/snapback]</div>
  16. tochatihu
    9,457
    3,656
    2001 Prius
    Fair enough. Will there be any warranty on the steering replacement system?
    Will a transaxle fluid change be part of this 50k mile service?
  17. patsparks
    10,664
    567
    Adelaide South Australia
    A pretty good outcome I think.
  18. valrit
    valrit New Member
    Hello all,
    The final outcome is that I will pay $500 even, the replaced rack and pinion will have a one year warranty, and the 60k service *does* include the transaxle fluid. So I'm pretty happy, considering what the cost could have been. Hooray for the "goodwill warranty." And thanks very much for the tips and advice on this.
    Best,
    Valerie
  19. statultra
    statultra uber-Senior Member
    798
    31
    Edison,NJ
    2001 Prius
    my 01 did that one time, and i was making a 90 degree turn i almost went straight into a tree, i had to brake hard. but it never happened since then
  20. Winston
    Winston Member
    614
    SF Bay Area, California
    They covered the steering unit and they got paid to do the standard 60k maintenance. Sounds like a good deal to me.
    I am one of those that would never take my car to Toyota for any of their maintenance packages, but I would have accepted that deal in a heartbeat.
