steering wheel question
Discussion in 'Prius c Accessories and Modifications' started by Gcoop, Mar 31, 2013.
  1. Gcoop
    Gcoop Member
    156
    79
    niagara region ontario canada
    for those on here that have had the wheel apart,
    the 2 plastic silver pieces on the front of the steering wheel.
    do they just pop off? or is it much more involved to get them off the wheel?
  2. ROLOPR
    ROLOPR Member
    441
    95
    Puerto Rico
    I wonder how is the process to remove the steering wheel, since I want to add the voice command module on my Prius C II for the aftermarket radio.
  3. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    You have to remove the airbag because the 2 silver trim pieces are screwed in place.
  4. ROLOPR
    ROLOPR Member
    441
    95
    Puerto Rico
    How do you remove the Air bag?
  5. B2FiNiTY
    B2FiNiTY Active Member
    979
    227
    It is not difficult. Just don't forget to unplug the negative battery terminal m
  6. ROLOPR
    ROLOPR Member
    441
    95
    Puerto Rico
    Can you tell me how???
  7. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    1st u have to disconnect the neg on the 12v accessory battery.
    Next there are 2 plastic covers at the 3 & 9 o'clock position near the rear of the steering wheel. Remover these covers. Now use a flat head screw driver to release the metal clip. U either push towards the back or the front of the car
  8. ROLOPR
    ROLOPR Member
    441
    95
    Puerto Rico
    ok thanks.
  9. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Did you get it worked out?
  10. ROLOPR
    ROLOPR Member
    441
    95
    Puerto Rico
    Not yet. Since I still waiting for the voice command botton control to arrive this week
  11. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Cool. Hit me up if u need help when ur button comes.
  12. ROLOPR
    ROLOPR Member
    441
    95
    Puerto Rico
    I let you know. Thanks :)
  13. wmo168
    wmo168 Member
    239
    50
    South Florida
    Where did you order the voice command botton control ? What part # and where and cost?
  14. ROLOPR
    ROLOPR Member
    441
    95
    Puerto Rico
    Here's the pics of the steering wheel module, with the part number (2nd pic) and wiring plugs. I bought it with the steering wheel for $100 on ebay.
    There's some 2010-2011 and the difference from this one is that the 2010-2011 buttons are horizontal instead of the 2012 that are vertical.
  15. wmo168
    wmo168 Member
    239
    50
    South Florida
    Nice, so it just plug and play right? Let me know how the install go!
