Strange Door Locking
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by SilverPriusIII, Sep 3, 2009.
  1. SilverPriusIII
    SilverPriusIII New Member
    39
    Bay Area, Ca
    Not a problem but very strange to me.
    I was doing car wash at my driveway with the car unlocked and has the fob in my pocket. While I was washing the top of the car at the driver front door I heard a sound and the door was locked as if I have touched the door handle.
    (The car was wet at that time. Later after the car was dried, I put the fob near the door handle while the car was unlock inside the garage and nothing happened).
    I unlocked the car and continue to wash my Prius. While I was washing the lower pannel of the passenger door and reach the bottom of the metal, I heard a sound and my door is locked again.
    I did not re-program the fob. I can only lock when I touch the driver handle. There is nothing in my pocket with the fob which can accidentally push the lock button.
  2. Politburo
    Politburo Active Member
    971
    208
    Water/moisture will affect the system.
  3. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    OK, as long as "water/moisture" won't unlock the car.:eek:
  4. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    Maybe the sensor is an IR sensor and the water because of a temp difference activated the lock sensor like the presence of your hand would?
    Anybody know how the sensor works?
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    Water running over the touch sensor in the door handle makes it think your fingers are touching it. To lock or unlock, you have to be in close proximity to the door with your fob on the outside of the car. Obviously water can't make it lock or unlock if you aren't standing there with the fob.
    Tom
  6. SR1227
    SR1227 New Member
    Redondo Beach, CA
    I noticed similar and just assumed that the sensor is a conductivity/resistivity (don't know the proper term) type where your skin, or water in this case, bridges the 2 terminals. But I forget if it worked both ways. And actually it was more reproducible if I pointed the spray directly at the handle, rather than the water just dripping on it.
    Maybe your locking was the auto-locking feature?
  7. ceric
    ceric New Member
    1,114
    Fremont, CA
    When you touch the sensor pad, you carry the static charges away accumulated on it. It senses the drop in voltage, and interprets the "touching". (try wearing a latex grove and to unlock it ....)
    When water contains detergent (ions), it becomes a better conductor than, say, rains.
    Try that with clean tap water. It won't happen as readily.
    My educated guess, of course.
  8. jay_man2
    jay_man2 jay_man_also
    1,246
    144
    Manassas, VA
    http://priuschat.com/forums/gen-iii-2010-prius-main-forum/68138-rinsing-car-set-off-alert.html
    From post 10 in the thread above:
    The Owners Manual does address this problem on page 50 and 51:
    - The doors may unlock or lock if a large amount of water splashes on the door handle, such as in the rain or in a car wash when the electronic key is in the effective range. (The doors will automatically be locked after approximately 60 seconds if the doors are not opened and closed.)
    - If the key is kept near the vehicle while it is being washed, water appplied to a door handle mahy cause the door to lock and unlock repeatedly. In this event, place the key in a location 6 ft. or more from the vehicle taking care not to lost the key.
    - If the key is inside the vehicle whle it is being washed, water applied to a door handle may cause a buzzer to sound. In this event, locking the doors will cause the buzzer to stop sounding.
  9. ceric
    ceric New Member
    1,114
    Fremont, CA
    So, in other words, this is a "feature", not a "bug" since Toyota's manual already covers it in details. :confused:
  10. jay_man2
    1,246
    144
    Manassas, VA
    I prefer to think of it as a mystery explained, a non-issue. :spy:
  11. cantgoback
    cantgoback Junior Member
    santa rosa, ca
    I noticed that the car doors automatically locks ~1-2 minutes after unlocking them w/o opening (not sure what happens if doors are opened/closed). This happened to me last night when I unlocked the doors for my wife using the remote button so that she could access the inside. But right when she was about to open one of the doors, the car beeped once and the doors locked. Goes w/o saying that she wasn't too happy with me after that.
  12. yardman 49
    yardman 49 Active Member
    606
    77
    Northern Kentucky
    G2 and G3 Prii will relock the doors if they have been unlocked but then not opened within a certain amount of time.
    If you unlock them, open them, and then shut them, they will stay unlocked.
    My Sienna does the same thing.
  13. cmalberto
    cmalberto New Member
    95
    Sour Lake, Texas
    My finding is that if you leave the key in the car(cup holder), the alert will sound but will not lock(which implies not unlock) when the water hits the sensor.
    This is really good for those times when the carwash people send your car through the wash since there is no body in it. Wouldn't ya just love it. They put your car in neutral, shut the door, send it through and if it were to lock(keys in it) and they couldn't get in to move it?
    I do wish there was a way to disable the locks temporarily as it is an annoying feature.
    --Mickey
  14. octavia
    octavia Active Member
    968
    137
    Beautiful Oregon
    It just occurred to me I can't use the little under-car magnetic key holder anymore or my car will just open for anyone and everyone.
    Kind of like the way my dog guards my house.
    "Hi badguys! welcome... let me show you were she keeps the silver."...
  15. jay_man2
    1,246
    144
    Manassas, VA
    Others in other threads have discovered that you can wrap a fob in aluminum foil to prevent it from activating the car sensors.
