Strange halo back glass tinting - defroster lines
Discussion in 'Prime Accessories and Modifications' started by ricomtl, Mar 18, 2019.
  1. ricomtl
    ricomtl Member
    137
    39
    moon
    2018 Prius Prime
    Technology
    Got my Prime tinted yesterday and noticed these flares/halo along each defroster line created from car headlights behind me. I read this is normal when defroster lines aren't embedded inside the glass but layed over the glass. It creates a small gaps and reflects light.
    Anyone has noticed this issue with their Prime back glass tinted? I had the Prius V prior this and never experienced these halos. The shop used SunGuard film.
    Thanks!
    #1 ricomtl, Mar 18, 2019
  2. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    I am going to guess that this is a normal reaction due to the curve of the glass. I'm impressed with a tint shop that can do your rear window.
  3. ricomtl
    ricomtl Member
    137
    39
    moon
    2018 Prius Prime
    Technology
    As I stated, several others report this on other models (Tesla, Subaru, etc...) and they don't have curved back glass. Some say it's due to cheap film, others say it's simple rules of physics (due to thick drefroster liner), etc...
    I'm just curious if other Prime owners have experienced this...
  4. yoyoman
    yoyoman Active Member
    342
    117
    San Jose California
    I have tinted my 2017 Prime and my 2014 Prius myself but decided to remove the prime rear tint film after a week (because of too dark). Never really notice the flares in your picture-even in my 2014 Prius . I used 3m Fx-premium 35% film from eBay.
    iPhone ?
  5. Tideland Prius
    16,402
    I thought I read about it in the other Prime tint threads.
  6. will the engineer
    will the engineer Active Member
    238
    119
    LA
    2019 Prius Prime
    Hmmmm nope! I don't have that issue. it's probably the brand your tint guy ended up using (or you ended up using)
    I don't know the brand my guy used, but it's flawless
    ricomtl likes this.
  7. ricomtl
    ricomtl Member
    137
    39
    moon
    2018 Prius Prime
    Technology
    Interesting. Thanks for sharing... So weird that lots of folks (toyota nation forum) say it's to be expected regardless of film quality due to the fact the defroster lines are layed above the glass and automatically creates light refraction...
    Will circle back to my tint guy and see what his comments are...
    #7 ricomtl, Mar 19, 2019
    will the engineer likes this.
  8. ricomtl
    ricomtl Member
    137
    39
    moon
    2018 Prius Prime
    Technology
    Ok more reading on this topic tonight... when windows are tinted (up north in this cold weather), the back glass needs more time & heat to cure. Until then, there are small pockets of water left from the installation that built up around the defrost lines, causing the light refraction!
    will start heating up my garage a little more and run the defroster!
    will the engineer and citiprius like this.
  9. Rob43
    Rob43 Senior Member
    1,373
    1,048
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    If that simple solution fixes your problem....score !
    Rob43
    Montgomery and ricomtl like this.
  10. citiprius
    citiprius Active Member
    241
    238
    51
    2018 Prius Prime
    Please keep us posted how it goes
  11. ricomtl
    ricomtl Member
    137
    39
    moon
    2018 Prius Prime
    Technology
    Looks like it's quite typical when it's installed at this time of year (up north at 0-5F).... I cranked up the heat in garage and eventually, when it's hot outside, it should cure naturally under the sun.
    I've already seen improvement so far!
    Prodigyplace likes this.
  12. lextoy
    lextoy Active Member
    291
    131
    philadelphia
    2018 Prius Prime
    you are way up north;) park it in the sun the radiant heat will cure it as well, sun is pretty strong already down here...you know...below the arctic circle ! lol
    ricomtl likes this.
  13. ricomtl
    ricomtl Member
    137
    39
    moon
    2018 Prius Prime
    Technology
    heheheh! Our parking lot at work is always in the shade, so I don't get much sun there in daytime and. I'll leave the car in the driveway this weekend so it can soak up in the sun!
  14. Prodigyplace
    12,367
    11,661
    Central Virginia
    I used to live in Toronto.
    I have gotten spoiled living in Virginia the past 30 years. We are expecting 56 F today. Currently 48 F
    ricomtl likes this.
  15. will the engineer
    238
    119
    LA
    2019 Prius Prime
    If so, that could be the reason why I am not experiencing that issue. I am in southern California I let the car bake in the sun for several days before rolling down the window or using the defroster
  16. SaraBBrown94
    SaraBBrown94 Active Member
    234
    263
    Pittsburgh PA
    Edit: let us know if it goes away.
  17. ricomtl
    ricomtl Member
    137
    39
    moon
    2018 Prius Prime
    Technology
    A little less, but still quite noticeable. I guess I'll have to wait for the warmer weather to kick in about a month!
  18. idleuser
    idleuser Member
    53
    CaliCali
    I had this issue as when I first got my windows tinted. You will experience crazy double vision in the rear due to the thick defroster line. However, when the film fully cures after 1-2 months it will be less noticeable with the auto dimmer set to on. However, the double vision will never go away due to the light refracting. You will still experience it but it will not be noticeable unless you look for it.
    ricomtl likes this.
  19. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,550
    722
    You guys having a long winter? We're expecting 85 F tomorrow. :D
    ricomtl likes this.
  20. Prodigyplace
    12,367
    11,661
    Central Virginia
    We hit low 70s yesterday. Got the cultivators installed on the row crop tractor and planted some beet seeds.
    Montgomery, Raytheeagle and ricomtl like this.
