Strange Hybird Synergy Drive Behavior
Discussion in 'Gen 2 Prius Technical Discussion' started by Bob Hayes, Mar 7, 2010.
  1. Bob Hayes
    Bob Hayes New Member
    29
    OK...here's a weird one...is this normal?
    My Hybrid Synergy Drive on my 2005 frequently races the gas engine for no reason. And on the display, it doesn't show the engine running! But I can hear it, clear as day...the 4 cyl. buzzing.
    This odd behavior happens in the same place frequently and always has: After a 10 mile drive on the freeway, I enter a log stretch of downhill road. The battery is fully charged by the time I get to the bottom. At the bottom is a stop light. Inevitably, 100% of the time, the 4 cyl. engine is running at very high rpm's while I sit at the light, and as I slow down. The display doesn't show that it's running, but the mileage calculation, which declines as I slow down, clearly shows the Hybrid Synergy Drive knows the gas engine is running.
    I tried turning off the heater, thinking the engine was running to keep the car warm. It still happens....very high rpm's!
    Is this normal? Am I missing something?
  2. john1701a
    john1701a Prius Guru
    12,793
    5,275
    57
    Yes. Yes.
    The battery-pack is totally full and the system is spinning up the engine as a method to discharge. So, the engine isn't actually running. It's just the smaller electric motor cranking it up to the startup RPM, allowing it to slow down on its own, then repeat.
    This is how the system ensures longevity. Allowing the battery-pack to stay at that high of a level for too long shortens it life.
    "B" mode is available to help prevent this situation.
  3. Bob Hayes
    29
    That explains it! Thanks very much!
  4. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,000
    Fort Lee, NJ
    It intentionally wastes energy by turning the gas engine (with electricity, no gas) as an air pump.
    B gear would basically do it on your downhill so the car won't have to do it at the light.
  5. richard schumacher
    7,664
    1,042
    United States
    Using "B" manually you would most likely waste a little more energy (and thus fuel) than the car would by itself.
