Strange Transmission/CVT switch-off
Discussion in 'Gen 2 Prius Technical Discussion' started by ferryflytheworld, Sep 20, 2012.
  1. ferryflytheworld
    ferryflytheworld New Member
    Hi guys, apologies for not introducing myself if that is the normal m.o. of the thread- I guess the lack of having to post goes a long way in saying how please I am with my Prius.
    I recently noticed something odd. After a long drive it seemed like the Gas Motor was switching off and on just TOO easily. If i just lightly touched the gas pedal the motor would go on and then immedialy switch off back on to electric if I took my foot off. The second i removed my foot from the gas pedal it did the same thing. I no longer have that "buffer" where at low speed and erratic driving both motors are working to stop this on and off jerking. In parking garages and other low speed driving there is a constant on/off of the gas motor if there isnt sufficient battery.
    If my foot is off the gas, the gas motor is immediatly off. If my foot is on the gas just a little bit the gas motor is on. Also there seems to be more of a jerking when the transition takes place. It is no longer seamless and you can actually feel the motors switch over.
    This is extremely difficult to explain to a technician and I immediately took the car in. I drove the guy around to show him but he was understandably confused. Ive been driving the car for 110k now and he would not be able to pick up the subtle difference in behaviour that was bothering me.
    They ran a system check and it seemed there was an error on the Cylinder 3 ignition coil. They replaced that and the car seemed to be ok again until I did a long trip.
    Here comes the weird part. It started after id driven about a mile on a short dirt road. After the car was washed it seemed to be fine again. Then after the ignition coil replacement it was fine. Again I drove on a short section of dirt road and it immediately seemed to start doing it again.
    Could it be dust in the CVT? Hybrid battery dying? CVT on the way out?
    I love my car and have had absolutely no issues. i planned on driving her until 150k but this is freaking me out as I can feel something is wrong..... Help !
  2. ferryflytheworld
    Oh yea, The codes that came up were P3000, P0353
  3. northwichita
    481
    102
    29
    Wichita KS
    Were these codes the technician had? Just to be clear , does the car currently show these codes? The 'jerking' doesn't sound normal, cycling of the engine on and off at low speeds does. If the transition is subtle, with no codes, my opinion is you don't have a problem.
    Also, when was the last CVT fluid change? This is probably the best thing you can do for long term ownership concerning the CVT.
    PriusGuy32 likes this.
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,830
    Clearwater, Florida
    You don't have to introduce yourself but it really helps if you introduce your car.
    What year?
    Where does the car live?
    Whats the maintenance record?
    If a Gen II did you have the Inverter Coolant pump replaced under service campaign?
    Having said that whats the Hybrid battery state of charge (SOC) looking like this whole time in question?
  5. ferryflytheworld
    Hi guys,
    Its a 2006, based in Cape Town, South Africa. All maintenance carried out as per the service plan and no issues as yet. It does it through various SOC. Low and Full. That said it still seems to run fine on the battery and this doesnt seem typical behaviour for a hybrid system failure.
    Does anyone know when in the maintenance cycle the CVT fluid is changed?
  6. ferryflytheworld
    Ok we did a full check of the ECU, Hybrid System, Etc using the fault checker at Toyota this morning. The P3000 code is no longer there. We also checked the individual cell voltage on the Hybrid battery. With the car on it was running an even 15.03-15.2 on each cell which is apparently normal.. so its not the battery by the looks of of it
  7. ferryflytheworld
    If you guys were wondering this is what the coils look like. All self contained and neat :)
  8. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Hi Ferry, you may have just accidentally bumped it into "B". I've done that before and been surprised at the sudden increase in "drag" when I go on or off the accelerator.
  9. usnavystgc
    3,159
    990
    Tucson, AZ
    Or... It sounds like to me you're stuck in S3. If it does this again, pull over (parking lot or something), leave the car in D with your foot on the brake until the ICE shuts off. Then... drive away and tell us if you have the same problem.
    Read this for more info about stages of operation on the Prius.
    The Five Stages of Prius Hybrid Operation | PriusChat
