Streaming Navigation audio thru Prius 2
Discussion in 'Gen 3 Prius Technical Discussion' started by febz, Oct 27, 2012.
  1. febz
    febz New Member
    Chicago, IL
    Hi there,
    I like to know if there is a way I could listen to the phone navigation directions thru my 2012 Prius 2? I could use the Bluetooth to make calls and listen to the music but I cannot listen to the navigation directions from my phone thru the bluetooth or usb connection... I have Verizon HTC Thunderbolt and I use the google nav. Please advice if there is a way... Thank you,
    febz.
  2. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    It is dependent on the App, whether or no it will support streaming the directions via BT. I use BlackBerry Traffic, it has a setting to enable that. It works fine, I have the audio input set to BT audio.
    I use that occationally because BlackBerry Traffic has much up-to-date traffic info, than XM traffic in the factory Nav.
  3. sbddude
    sbddude Junior Member
    62
    Bay Area, California
    2013 Prius v wagon
    southernguy likes this.
  4. southernguy
    southernguy Junior Member
    55
    Thanks sbddude for that info
