Stupid Question of the Month: How can I safely rotate a front tire?
Discussion in 'Gen 2 Prius Technical Discussion' started by Robert John, Jul 19, 2025 at 2:32 PM.
  1. Robert John
    Robert John Junior Member
    57
    Montreal, QC
    I need to rotate a front tire (up on a stand) to trouble shoot an annoying noise on my Gen 2. From what I’ve read here, the only way I can do this is: set the emergency break; ‘block’ the opposite front tire; jack-up the wheel to be examined; start the car (with foot on brake); shift into ‘N’; then rotate the tire while the car is ‘ON’ (to try and locate the noise).
    I’m not comfortable having a car up on a stand - possibly with a front tire off - when the motor can start running at any moment… even if it is in ‘N’.
    Q: Is there a safer way (i.e. without the car running)?
    Thanks!
  2. ChapmanF
    17,401
    That's not correct: you may have read it here, but we've got lots of threads on PriusChat and you can find both correct and incorrect information. If you identify the thread(s) where you read that, we can add clarifying information there so other people don't get misled the same way you did.
    You do not need to "start the car (with foot on brake)" to shift into N—and in fact, for the exact reason you've already given, you shouldn't want to. Just take the car to "ON" (that is, two power button presses without touching the brake). You can shift to N then with no problem, and nothing is ever going to start.
    Or, simply jack up both front wheels. If the transmission is in Park, when you spin one front wheel the other one will spin the opposite way. It will take a bit more effort than just shifting to N and spinning one wheel, but you might be able to diagnose your noise either way.
  3. Robert John
    57
    Montreal, QC
    Great, that sounds MUCH safer! I've owned the Gen 2 for over four years, and somehow, the 'double-'ON'-no-foot-on-brake' function escaped me.
    Thanks for the tip... much appreciated!
  4. ChapmanF
    17,401
    Yeah, that's one of those pieces of basic Prius knowledge that's in the owners' manual somewhere, and it's all over this forum, but it bears repeating because it's sort of never in the exact thread somebody's looking at with a question.
    In old cars that had a key you would turn, the key pretty much always had the following positions marked around it:
    OFF ACC ON START
    Some cars put ACC on the other side of OFF, like: ACC OFF ON START
    You'd take out the key in OFF position when you were done with the car.
    If you turned the key to ACC you could listen to the radio and maybe use a few other ACCessories.
    If you turned it to ON, you could do that, and also the dash instruments would wake up, and you could use blinkers and wipers and stuff, but not drive the car.
    If you turned it to START the car would start and you could drive it (the key would spring back to ON, but the car would be running).
    The ON state (without starting the car) is also usually what you want if you're connecting a scan tool to retrieve trouble codes and such. It was sometimes also called "KOEO" (key ON, engine off).
    In a Prius with the pushbutton, they correspond like this. Starting with the car OFF:
    One button push without the brake takes you to ACC.
    Next button push without the brake takes you to ON. Instruments light up, but you will not see the word READY.
    Next button push without the brake takes you OFF again.
    One button push with the brake takes you to READY, where you can drive the car. The word READY lights up on the dash then.
    Do you happen to remember where you found threads on here saying you had to be READY to shift to neutral? If you can point us to those we can fix them so other people don't stumble on the wrong information.
  5. dolj
    dolj Senior Member
    8,237
    4,197
    Wellington, New Zealand
    I would precede that last statement thus:
    From any of the above states, one button push with the brake takes you to READY, where you can drive the car. The word READY lights up on the dash then.
    We received a laminated cheat sheet card with all the basic "what's different about a Prius" information and more that included the above. At the time, keyless cars were not common, so it made a lot of sense.
  6. Paul Gregory
    Paul Gregory Senior Member
    1,586
    397
    Alberta
    2024 Prius Prime
    XSE
    Or you could decide for yourself, ignoring the self-appointed "experts" who claim to be the arbiters of what is right and what is wrong. Common sense is your friend.
  7. dolj
    dolj Senior Member
    8,237
    4,197
    Your comment makes no sense in this context.
    It was because the OP had concerns about the safety of what he thought was the correct way to do the thing that he posted.
    The reply then pointed out the way to do the thing without having the engine on.
    Perhaps you need to take a step back?
  8. Paul Gregory
    1,586
    397
    Alberta
    2024 Prius Prime
    XSE
    Y'know, it seems a bit odd that the focus of these things seem be on me and how I should behave. Am I really that interesting?
  9. dolj
    dolj Senior Member
    8,237
    4,197
    Etiquette applies to all equally, so no, it is not specifically about you.
    #9 dolj, Jul 21, 2025 at 12:23 AM
  10. Paul Gregory
    1,586
    397
    Alberta
    2024 Prius Prime
    XSE
    Is that how you spell, "Etiquette?"
    dolj likes this.
  11. dolj
    dolj Senior Member
    8,237
    4,197
    Spelling mistake fixed. Thanks for spotting that and the correction.
  12. rjparker
    rjparker Tu Humilde Sirviente
    9,634
    5,927
    Texas Hill Country
    Kind of like saying "don't believe a guy who says a jack stand is needed when getting under the car. Just use common sense".
    Dangerous advice. We are not born with "common sense". What you consider common sense varies based on individual experiences, background, and education.
    Life changing mistakes happen everyday to people who are "sure" their knowledge is good.
    Ultimately many get old and forget what experience has taught them but still rant on.
  13. Paul Gregory
    1,586
    397
    Alberta
    2024 Prius Prime
    XSE
    If that's your idea of common sense,
    you don't have any.
  14. T1 Terry
    T1 Terry Active Member
    761
    406
    Common Sense is a misnomer, good sense is very uncommon, if it were more common, the world would be in a lot better standing than it is now. Sense isn't taught, it is learnt, not allowing the Darwin Principle to sort the wheat from the chaff has seriously reduced the amount of sense doing the rounds ......
    One of the basics is "If you are unsure, ask" that is a sense that should be a lot more common than it seems to be ......
    T1 Terry
  15. Paul Gregory
    1,586
    397
    Alberta
    2024 Prius Prime
    XSE
    Like I said, you don't understand it.
  16. T1 Terry
    761
    406
    And that is where the problem lies, the OP didn't know, so asked to see if there was a safer method than the one he had gathered from what he had read ...... that is an example of good sense ...... if you asked someone who had never driven a Prius, would you expect them to know the safest way to conduct the test they wanted to do ...... that would be an example of common knowledge or common sense, everyone would know it ..... it's a bit like having to label things as, caution, hot surface on the surrounds of an out door heater ...... if the Darwin principle was applied, the first idiot that touched the red part or close to it, and received a severe burn, all those that witnessed the event would share the knowledge that you will get hurt if you touch the hot parts, no sign would be required ..... keep hand clear of blades is another example ..... starting the Prius up when on a jack or single stand and getting run over, isn't asking if there is a better way showing a lot more sense than assuming what you have read is the correct way to do the test?
    T1 Terry
