Subdermal Keys
Discussion in 'Gen 2 Prius Accessories & Modifications' started by joerdie, Dec 11, 2008.
  1. joerdie
    joerdie New Member
    61
    Cincinnati Ohio
    I am giving some serious thought to trying to get my Prius keys transmitter placed in my arm. I have no idea how to make this work as I would need some sort or power source.
    I really think it would be nice to never have to carry any keys. The Prius opens my garage door, and I could place a front door key in the car in case if emergency’s. It sounds insane but I every day, I like the idea more.
    Any thoughts about how this could be done?
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    The Prius SKS fob is too large and requires a replaceable battery. Your idea is good, but the technology of the Prius isn't up to the task. Wait for some sort of longer range RFID device, which will allow a small implant with no power source.
    Tom
  3. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Duct Tape...
    RBowman likes this.
  4. qbee42
    18,058
    3,076
    Northern Michigan
    I suppose we could make a suppository fob case... :eek:
    Tom
  5. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    Why don't you start a little less aggressively...why not see if you can build a wrist watch with the transmitter built in? That way you can use the same battery to power the watch and the key and it'll be replaceable and not permanantly scar you or put you at risk for infection, illness, etc.
    The Japanese Crown Hybrid has a watch w/ the SKS built in available...so it can be done.
    I think it would take a fairly large device to house the unit, a large enough battery to last the life of the car...and a surgeon/physician willing to lose his license to implant something like that.
  6. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    :ear:please!!! We're already getting to look like "The Borg" with people wearing those damn cell phones in their ears. "Beam me up Scotty"
  7. blazer_5154
    blazer_5154 Heh, you said "member"
    106
    Maryland
    I have seen keyless entry systems that use RFID receivers, but a Prius-esque smart key is not yet feasible. Look into the systems used in car-sharing businesses HowStuffWorks "How Car Sharing Works" These are usually accessed by a type of RFID card, but could be made to work with an implanted glass-tag.
  8. EZW1
    EZW1 Active Member
    722
    81
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    I bet you could buy one of those Crown Hybrid watches and have it programmed to your Prius.
  9. joerdie
    joerdie New Member
    61
    Cincinnati Ohio
    The watch idea may be a good way to start. For me, It's not about a body mod. I just think it would make my life easier. The current FOB is far to large to work in either the watch or under the skin.
    I will do some research and report back. I have been dying to bring something new to this forum... This may be my time to shine.
  10. RobH
    RobH Senior Member
    2,369
    984
    70
    Sunnyvale, California
    A google search for "implanted rfid" turns up a number of sites talking about exactly this. The website at Amal Graafstra's RFID page is dedicated to hobbyist use of rfid. The guy who runs it has two implants, and uses them to unlock his car and house.
    There are a number of other possibilities short of an implant. You could use something like a Garmin Forerunner 405 as a wristwatch. It communicates with a computer via an ANT radio connection, about 5 feet max. The serial number of the watch could be used as identification. Any Bluetooth device, such as a cell phone (or even the wireless headset) could be used as identification.
    The actual electronics inside a keyfob are quite a bit smaller than the keyfob. You could take apart a keyfob, and repackage the electronics in something smaller.
    Some Ford vehicles have keypads on the driver's door for keyless access. There's probably some aftermarket equivalent that could be used.
    The TapLock device (TAPLOCK.COM) uses taps on the windshield as a code to unlock the doors.
  11. ilusnforc
    ilusnforc Member
    404
    San Antonio, TX
    The battery wouldn't be a problem for an implant if you use the right technology. Our bodies produce plenty of energy to power our key fobs, we just have to harness that power. Either tap into the electrical energy our bodies produce or probably the more likely technology would be what a group of German scientists are developing to convert our bodies heat into electrical energy. Not sure that the necessary technology for that is practical or even available yet, but would be the way to go with an implant.
    A far better idea for an implant though would be to ditch the Toyota SKS system all together and just cut into the wiring that powers on the car, unlocks the doors, etc and install a device that reads RFID implants like they use on dogs, you just hold your arm or whatever up to the windshield or wherever you mount the scanner (like vets use for dogs to scan for an RFID) and if it picks up a code you program into it that matches the ID you have implated it unlocks, same for inside to start maybe? I think thats the only practical way of doing it though, because an RFID does not require power, it uses the radio waves coming from the scanner to send a very small signal back. Much better idea, all you'd really need to do is have a device built to do what you need it to so it will unlock and allow the car to turn on and cut/splice it in.
  12. joerdie
    joerdie New Member
    61
    Cincinnati Ohio
    I guess I need to brush up on how to convert SKS to rfid. Before I get too deep into this, I need to get the wife on board. When I told her last week.... it was not good. This makes no sense to me considering all of our collective ink... whatever. Anyhoo, I think rfid will the way to go for underskin keyless entry. I may try to get the rfid working in watch form, then convert at a later date.
  13. spitinuri
    spitinuri Member
    317
    You have multiple issues here.
    1) placing a device non-sterilized under the skin. (huge risk of infection)
    2) if you could sterilize heat is out as it could damage components. Gas sterilization might not be efective since there are no smooth surfaces on the electronics and they would probably be damaged in the process.
    3) Size. Placing it on the inside of your arm would not really be a huge challege, but everytime you bumped it, it would hurt. You would have to suture it in place as it would be likely to migrate over time.
    4) You would have to get a physician to place.
    The idea on its own seems a little on the freaky side until you think it is not as far-fetched as you think. After all we are already putting computer chips in our pets and some children for identification.
    I think where you might head from hear is the remote start aftermarket. Valet, Cobra etc. might be a little interested in this idea. It is several years down the road before it is a viable alternative. For now listen to your wife. Patent your idea before you talk to any companies.
    Best of luck.
  14. spitinuri
    spitinuri Member
    317
    just a few typos
  15. cairo94507
    cairo94507 Active Member
    923
    36
    Auburn, CA, USA
    UHHHHHH.......:eek:
  16. blazer_5154
    106
    Maryland
    There are actually RFID tags that are encased in glass beads, the same type that are used to "tag" pets / livestock. Being totally hermetically sealed inside the glass vials, makes sterilization simple and insertion a breeze. There was actually a Mythbusters episode that showed the entire process of having an RFID chip implanted; Keri Byron was the "lucky" recipient of the implant, and commented that she couldn't even tell it was there. Not only can it be done, it is being done currently, I have seen DIY versions of the keyless entry system cobbled together by inventive individuals. As a matter of fact, I actually have an RFID reader and 10 of the glass-bead "tags", but I personally had no intention of implanting them into my body.
  17. hyo silver
    hyo silver Awaaaaay
    15,260
    1,598
    off into the sunset
    I see another problem with RFID. Following the theory that the best crooks are always a step ahead of the best cops, somebody with a hidden RFID scanner could gather a great deal of sensitive data in a very short time, just sitting in the mall reading the paper.
  18. tedmarshall
    tedmarshall New Member
    25
    San Jose, CA
    Not precisely on topic, but I installed this on my front-door to avoid having to pull out my keys. I'm spoiled by my Prius SKS :D
  19. joerdie
    joerdie New Member
    61
    Cincinnati Ohio
    I would have a Dr. do it. I don't have the guts to do it myself.
    I am concerned however about the potential theft issue and have been looking into that also. There are a few products out there that can get around that issue however. Will narrow them down and follow up here.
    As I give this more and more thought, I see less and less reasons NOT to. I really think this is a good idea.
  20. thedutchtouch
    thedutchtouch prius is my SUV
    181
    Baltimore MD
    go for it. and post pics.
