Subtle thump when coming to a stop?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Slice of the Jungle, Feb 27, 2012.
  1. Slice of the Jungle
    Slice of the Jungle Junior Member
    Kent, NY
    I'm not even a Prius owner yet but have test driven 5 used ones in the last few days. The thing that is bugging me is a very subtle thump when coming to a stop. I noticed it on an 06 with 77k mi and also an 08 with 45k. I am more curious about the 08 as it was more noticeable and I drove the car quite a bit trying to figure out the sound, when I would slow down from about 35mph just as the car was at 3mph just before coming to a complete stop(and coming to a normal/gentle stop, not jamming on the brakes), there is a little thump. To me it sounds like possibly one of the electrical motors is stopping it's rotation and causing it, or maybe the braking system. When I abruptly stopped it would not occur. When I would slow from just 15mph to a stop I did not notice it. The 06 with 77k almost seemed like it would make the same sound but do it two or three times while gently braking and much more subtle than the 08. Thanks in advance for any help, Tim
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Unfortunately, since I'm not driving those cars, I can't tell you if it's normal or not.
    My 06 Prius w/61K+ miles still does a slight stuttering in the last couple of mph before 0 while doing light braking. I'm totally used to this now. I posted about it when I was a newbie at http://priuschat.com/forums/gen-ii-...tter-right-before-car-stops-4.html#post198335. Just for kicks, you could try shifting to neutral before braking to see if there's a difference. You won't get any regen if in neutral.
    You could also intermittently hit a rough engine shutdown. It's normal and isn't easy to repro at will. I believe it's easier to repro when the engine's cold. One of my posts is at http://priuschat.com/forums/gen-ii-...-troubleshooting/93532-rough-engine-stop.html. There are tons of threads on this such as the one at http://priuschat.com/forums/local-prius-club-main-forum/37051-rough-engine-shut-down.html.
  3. uart
    uart Senior Member
    4,220
    1,209
    Australia
    It's probably related the transition from regenerative to friction braking. The speed you're traveling and the deceleration rate probably determine exactly where the transition occurs and how abruptly.
  4. fotomoto
    fotomoto Senior Member
    5,626
    3,802
    So. Texas
    Another vote for transition from regenerative braking to conventional braking. It's not always seamless.
  5. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    A suggestion about the above is to drive around w/the windows down and listen to see if if the "thump" coincides w/the gas engine shutting down, esp. when it's not totally warmed up. If so, I wouldn't worry about it.
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,829
    Clearwater, Florida
    Listened to my 07 on the way home tonight and no thump braking in any mode at any speed.
    I also put it in neutral at 30 mph's and came to a stop a few times. No thump.
    Be aware if your test driving a Prius that has sat outside and not being driven for a few days the brakes will be messed up. You will hear some grinding and they will also catch bad.
    The car does not like the fine coat of rust we get on our rotors and the brakes get grabby if the car sits for a while outside.
    The rust goes away quick but its an issue we have all learned to live with.
  7. Slice of the Jungle
    Kent, NY
    Thanks for all of the input, after checking out those posts cwerdna, and driving several, I'm chalking up the sound to a quirk with the vehicle. My biggest concern was that I drove two 08's with similiar mileage and one did it and one didn't. I am going to buy an 08 with about 44k miles, can't wait to get behind the wheel again, Thanks everybody
  8. fuzzy1
    10,332
    Mine (different generation) has always had something matching OP's 'thump' description, but it has never been bothersome enough to track down. It is clearly distinct from the regen->friction braking transition. I'll start watching the ScanGauge for any correlation to engine shutdown.
  9. Wimble
    Wimble Junior Member
    30
    uk
    The car is full of little quirky noises if you're used to a standard gas guzzler. :)
    When first had mine I often found myself noting every little click and buzz due to the complete absence of the usual engine drone.
    I am throwing my hat into the switch from regen braking to friction as well by the way!
  10. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    I've seen this in gangster movies. Have you checked for a dead body in the trunk?
    Tom
