Sudden storm slammed my prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by car78412, Aug 13, 2011.
  1. car78412
    car78412 Member
    284
    32
    Hudson Valley, NY
    When I left work one day last week the sun was out and it was about 92 degrees. I started my 26 mile commute home when at around 5 miles from my home I hit a bad storm. It got very dark and started to rain very hard. The wind picked up and it started to hail. Before I could pull off the road a huge branch hit the side of my Prius. The branch seemed to hit the side pillar and windows. When it hit I knew that there would be damage. I was surprised the side glass didn't shatter. I pulled off the road and the hail was unrelenting. Surely the aluminim hood would be damaged. The storm subsided and I immediatly drove home. When I got home I checked out the side where the branch hit. There were leaves stuck in the window track but I couldn't see any damage. I was totally amazed that here wasn't even hail damage.
    Yesterday I washed the car and found dents and broken paint behind the left rear side glass. It isnt very noticable but the broken paint area will rust and the dents bother me. The car is only 6 months old. If the area where the paint is broken is aluminum, it won't rust. Does anyone know if the rear pillar next to the small rear glass side window is steel or aluminum? Is barcelona Red easy to match?
  2. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    WOW, you were really lucky. I am not sure what kind of material the Prius is made of. It doesn't seem to be steel, aluminum, or plastic, but a combination of something. As for matching paint, I would leave it to a professional. Sorry I couldn't help you.
  3. J5A
    J5A Active Member
    592
    83
    Severna Park, MD
    Sorry to hear about your IV. :(
    Back in May large hail fell not far from where we live. I recently saw a newer Ford Edge at Trader Joe's that looked like it was in that storm. Every square inch of the top area was severely dented. It looked like a golf ball!
    Here's a pic of the hail taken from the news:
  4. DetPrius
    DetPrius Active Member
    545
    92
    Southeast Michigan
    My understanding is the hood and rear hatch are aluminum. You could check for steel with a magnet, gently!
  5. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    Maybe not. Here is what one touchup paint site has to say:
    "Always verify your color code on your vehicle! Do not order paint based
    on the paint name or color samples shown above.
    There can also be additional colors, especially interior, trim and wheel
    not shown above. Please note:
    The VIN does not give us your color code. It only gives us any paint
    formula variance in an existing color code
    FWIW, the paint code for Barcelona Red is 3R3.
  6. car78412
    car78412 Member
    284
    32
    Hudson Valley, NY
    Thank you for your comments. I guess I could say I am lucky that the branch didnt go through the diver side window and slam me. But I am impressed how well the Prius withstood the beating with little damage. The side glass is as strong as steel.
  7. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,800
    Undisclosed Location
    I believe The Prius is made of Adamantium.
  8. SW03ES
    SW03ES Senior Member
    2,480
    176
    Gaithersburg, MD
    A good body shop should be able to tint it and match it perfectly...
    Sorry to hear about the damage, ours was in a hail storm last year too...
  9. billnchristy
    billnchristy Active Member
    924
    123
    GA
    2016 Chevy Volt
    Prius is one tough cookie. This car has amazed me with its toughness.
  10. bisco
    50,805
    :D
  11. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    hahahahahaha
  12. car78412
    car78412 Member
    284
    32
    Hudson Valley, NY
    You are correct. I used a magnet and it showed that it is Adamantium. Thanks :D
  13. vinnie97
    vinnie97 Whatever Works
    1,430
    277
    Somewhere out there
    I have 2 dents on the roof from an unexpected spring hail storm...can't afford a fix now, them's the breaks.
  14. car78412
    car78412 Member
    284
    32
    Hudson Valley, NY
    UPDATE: I took my Prius to a body shop and got an estimate for $2,180.00 which includes repairing all the damage. The rear tailight was cracked. I didnt even see it. Needs to be replaced. I have $500 deductable. I am meeting with the insurance adjuster tomorrow. :mad:
  15. poway
    poway Junior Member
    Pensacola FL
    Good luck!
