Sumitomo T4 195/65R15 vs. GPS
Discussion in 'Gen 3 Prius Technical Discussion' started by bwilson4web, Aug 16, 2010.
  1. bwilson4web
    15,939
    After a second flat in the repair area of a tire, I replaced all four with Sumitomo T4 195/65R15, Toyota had a sale. But I notice the GPS distance does not match the tripmeter distance:
    Column 1 Column 2
    0 miles source
    1 102.6 GPS
    2 102.1 A trip meter
    Assuming the GPS is accurate:
    0.5/102.6 ~= 0.5% error
  2. cproaudio
    cproaudio Speedlock Overrider
    2,401
    760
    CA
    Of course the GPS will show farther distance compared to the tripmeter. The OEM tire is 195/65/15 not 195/70/15. This means that the tires you replaced has larger OD and less rotations per mile than the OEM size. Did you buy a 70 series tires for correcting the speedometer's reported speed error?
  3. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Scandalous:D
    Good news is after you have worn 2/32 off your tread, your odometer will be perfect. :rockon:
  4. bwilson4web
    15,939
    Correction, I wrote the wrong tire spec:
    195/65R15 - ZVW30
    195/70R14 - NHW11, a different experiment
    Regardless, tire wear should bring them smack dab perfect someday in the future.
  5. adrianblack
    adrianblack Member
    447
    187
    Los Angeles
    On a regular Gen III does GPS speed match the CAN speed? I seem to recall it does on my car .... and am pretty bothered by the fact Toyota artificially inflates the digital speed display.
    You will have slowed down acceleration with the bigger tires. :)
