Synthetic Oil
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by berryman, Oct 12, 2004.
  1. berryman
    berryman Junior Member
    55
    Southern California
    After a couple of months of reading the postings on this site, I have the impression that about half of you use dino oil while the other half use synthetic oil.
    What brand of synthetic oil do you synthetic oil advocates recommend and why?
  2. priusham
    priusham New Member
    525
    Michigan - land of everlasting snowflake icon!
    hmmm... you made me think... well, at least you made me Google. From the Mobile 1 website
    Historically, conventional oils lack the performance of synthetic oils in the areas of low-temperature performance and high-temperature oxidation stability. Conventional motor oil is made up of an inconsistent mixture of long and short chains of carbon and hydrogen atoms. In the extreme heat of an engine, short-chain molecules can evaporate, and unstable molecules can oxidize and break down. Conventional oils also contain much greater amounts of impurities, such as sulfur, reactive and unstable hydrocarbons, and other undesirable contaminants that cannot be completely removed by conventional refining of crude oil.
    Mobil 1® with SuperSyn™ uses high-performance fluids, including polyalphaolefins (PAOs), along with a proprietary system of additives. Each Mobil 1 with SuperSyn™ viscosity grade uses a unique combination of synthetic fluids and selected additives in order to tailor the viscosity grade to its specific application.
    Now this is interesting...
    Mobil 1 with SuperSynâ„¢ is available in five viscosity grades:
    Mobil 1 with SuperSyn™ 10W-30 – Higher-Mileage Vehicle Formula
    Mobil 1 with SuperSyn™ 5W-30 – Newer Vehicle Formula
    Mobil 1 with SuperSyn™ 15W-50 – Performance Driving Formula
    :idea: Mobil 1 with SuperSyn™ 0W-30 – Enhanced Fuel Economy Formula
    Mobil 1 with SuperSyn™ 0W-40 – European Car Formula
    Mobil 1 with SuperSynâ„¢ is truly a global formulation, exceeding the latest standards of the oil industry and vehicle manufacturers.
    For instance, the appropriate grades of Mobil 1 with SuperSynâ„¢ exceed API Service SL/CF, European ACEA standards and Japanese valvetrain requirements. In addition, certain viscosity grades exceed ILSAC GF-3 and specific OEM standards. For instance, Mobil 1 with SuperSynâ„¢ 0W-30, 5W-30 and 10W-30 exceed ILSAC GF-3 and are certified as "Energy Conserving." As another example, Mobil 1 with SuperSynâ„¢ 0W-40 exceeds Mercedes-Benz's 229.3 specification.
    Myth Busters...
    One of the myths that persists about Mobil 1 is that new engines require a break-in period with conventional oil. Current engine manufacturing technology does not require this break-in period. As indicated by the decisions of the engineers who design these high-performance cars, Mobil 1 with SuperSynâ„¢ can be used in an engine from the day you drive the car off the showroom floor.
    :? Looks I have to consider switching to a synthetic. From the sounds of this, it will work better on cold Michigan mornings in the dead of winter, and I can safely go the full 8,000 miles between oil changes. I do them at about 4000 now.
  3. jamarimutt
    jamarimutt New Member
    985
    Synthetic oil is about as necessary for this car as high octane premium gasoline. Both are great ways to throw away the money you save on gas.
  4. DaddyLongLegs
    DaddyLongLegs Junior Member
    Gainesville, VA
    I use Mobil 1 5W-30 Newer Vehicle. I use Mobil 1 in all three Toyota's we own for the very reasons stated in W8KC's post above. Additionally, you can go longer between oil changes and while I don't have any scientific proof, better gas mileage.
  5. rflagg
    rflagg Member
    947
    Springfield, VA
    I use Mobil 1 synthetic. I use synthetic because then I can tell people I've reduced my foriegn oil consumption by 75% overall with this car.
    -m.
  6. priusham
    priusham New Member
    525
    Excellent point. I mean, that is the main reason I bought the car.
    I always thought that the best reason to use synth oil was to go longer between changes. A non issue for me as I tend to change oil frequently and my local Toyota dealer only charges $19 and that includes a full, hand car wash.
    With synth, from what I just read, it would work much better (^ MPG) at low Michigan temps, I could be comfortable going 8K between changes, and I might as well do it myself.
    Definitely worth looking into...
  7. wb9tyj
    wb9tyj 2017 Prius Prime Advanced
    389
    95
    Indiana and Nevada
    Synthetic Oil is the "oil" of choice,due to, 1. you can go longer between chenges,so therefore you recover your costs in that respect...instead of 2 dino changes, only 1 syn change. 2. friction coeffcient is less, so therefore,less wear over the long term...after pulling valve covers and gaskets after 250,000 miles on my old car, with synthetic, very little sludge,and the compression of the engine was within 5% of a new engine...so buying synthetic is not a waste of money, as high octane gas is......synthetic is oil of choice in all my vehicles......it carries heat off much better... :wave: :wave:
  8. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    new to the forum. Just took delivery of a 2004 Prius in Tideland Pearl and it's a great car. I first started using synthetic oils here in Manitoba and Northwest Ontario, Canada, back in 1980, but for much different reasons than I've seen posted: a regular motor oil has the flow properties of a brick at -40, and is quite sluggish at -30. I started using Mobil Delvac 1 5W-40 in the heavy equipment and Mobil 1 in my personal car. I now use Mobil 1 0W-30 or Esso XD-3 0W-30 (A heavy duty PAO synthetic for large diesel motors) in winter. Fuel economy gains are something you'd probably only notice in a carefully-controlled lab test, not in the real world. In order of importance to use a good synthetic: need for cold-temp flow, especially at -20 F or colder; extreme high-temp or hard use; and, you want the motor to last forever. Unless you want to keep the car forever, those lucky enough to live in a "moderate" climate will get good service out of a "dino" oil at much lower cost. BTW: my local Toyota dealer is also an Amsoil dealer, and he recommends a 10,000km break-in before using ANY synthetic. I can see that with a Kenworth, but wonder why such a long break-in for a Toyota?
  9. mark_hamrick
    mark_hamrick New Member
    103
    Littleton, Colorado
    Just went to my dealer's "thank you / info" session. Asked their master tech (20+ yrs with Toyota) about using synth oil. His response was he does not reccomend them because they can cause seals to break down faster...Does anyone have an answer to that charge? I am thinking about replacing the dino at 5000 and want to do whatever is best for the car. Am leaning toward Mobil 1...
  10. VARedDevil
    VARedDevil New Member
    129
    Fredericksburg, Virginia
    I have not changed over to synthetic in the Prius yet...am considering it with the vehicle approaching it's first 5K soon. My dealer said no problem with changing over to synthetic. If I have them do it, it would be the difference between the 19.00 dino oil and synthetic, I guess probably another $3.00 / quart or about 12.00 more...or I can bring my own synth in, which I can get at COSTCO or SAM's Club for a lot less, and they will use that. I go to WalMart to get the oil changed in my Avalanche and Accord...they charge me $38.00 for the Avalanche (it uses 6 quarts) and $35.00 for the Accord, both using synthetic. No problems in either. I changed to synthetic at the first oil change in both of them. Factory for the Chevy states when the oil life meter reads 0% oil life or 10,000 miles whichever comes first. I change at 7500 miles, same for the Honda. I have heard of synthetic oil affecting seals. I have heard that in older engines with less tolerances in the clearances, that synthetic because it is "thinner" will slide past pistons and cause a slightly higher consumption of oil. That did happen in an 80 Toyota Tercel I had, but both Mobil and Toyota said the loss that I encountered was well within specs. I've been using synthetic oils in all of my vehicles (yes, even my hog) since 1979. I've never had any problems with it. I will shift over to Mobil 1 in the Prius but I will have the dealer do it, because I'm not sure WalMart is ready to deal with a hybrid yet. I will buy my own and take it to the dealership...that will bring my cost back down some....just my $0.02 :mrgreen:
  11. VARedDevil
    129
    I have to make a correction to my previous post...where I said I have heard of synthetic affecting seals, I meant to say I have NOT heard of synthetic oils affecting seals....sorry about that. :oops:
  12. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    Master tech?? That is old old data from the original synthetics....that problem no longer exists.
  13. mark_hamrick
    103
    Littleton, Colorado
    Evan, do you use synth? If so, which brand?
  14. jayman
    13,439
    641
    Winnipeg Manitoba
    The issue of seals leaking when using synthetic motor oils really made news in the trucking industry about 25 years ago. A regular motor oil tends to leave varnish or ash at the interface between the seal and the rotating surface, causing the seal to wear away. Since there is a layer of varnish at the seal and polished rotating surface, there won't be any abnormal leakage. Switch to a synthetic oil and here is what happened: synthetics are very stable oils so have MUCH higher detergent levels, which start to eat away the deposits in the motor. Since the seal was already damaged by the varnish and ash deposits, the oil can now freely leak past. This is more apparent on an older motor with a LOT of miles on it, a new motor (Less than 6,000 miles) should never have this problem. Synthetic gear oils can cause the same leak problems for manual transmissions and axles: Eaton/Rockwell warns owners of large truck HP-40 tandems and similar HD axles that if they switch a rear end from mineral gear oil over to a full synthetic, and the axle has more than 5,000 miles on it, they MUST change all the axle seals or risk gear oil leaking out onto the air brakes.
  15. efusco
    19,891
    1,194
    Nixa, MO
    Yes, Mobile 1. Although, I think, my current oil is Castrol (dino) thanks to an unrequested premature free oil change from my service dept.
  16. VARedDevil
    129
    Ya gotta love those premature free oil changes...I have a standing agreement with my service departments...actually, it's not an agreeement, but a mandate...that unless I tell them to do so, do not touch the oil...but sometimes the dealer feels they're giving you a great deal for being a valued customer and throw one in free on you without asking...nice jesture on their part put kinda throws everything off... I run Mobil 1 5W30 in the Avalanche and right now, Penzoil Synthetic 5W20 in the Accord. But supposedly Mobil 1 now comes out in 5W20, I haven't seen that yet. I've never had any problem with Mobil 1...can't verify any power gains or MPG gains, I just like running synthetic oil because it has a higher breakdown temperature then any dino oil has.
  17. tofani
    tofani New Member
    17
    Newburgh, In
    2002 Prius
    I have always used Mobil 1 and have been very pleased. I have done some research and I am going to use Amsoil. In test Mobil 1 creates half the wear of dino oil and Amsoil creates half the wear of Mobil 1. If you are considering synthetic oil you should check out their website. I have a 2002 Prius with 17k. I just ordered Amsoil Series 2000 0W-30. I will update after I receive and perform my next oil change. www.amsoil.com
  18. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    301
    Northwest VT
    2018 Prius Prime
    They didn't notice the color of the old oil draining out? Maybe they owe you another unrequested oil change. With Mobil 1 this time.
  19. efusco
    19,891
    1,194
    Nixa, MO
    Always be skeptical of companies advertising and 'studies' posted by them...they'll only show you the ones that favor them. There's an ongoing independent study of oil (someone will post the URL, I don't have it on the computer I'm using now), that shows some areas where Mobil 1 is superior and some where Amsol was superior, but all in all they're about equal.
    If you find you like Amsol better then that's great...I'm not trying to talk you out of it as it is clearly an excellent product. I just would buy their promotional stuff lock, stock and barrel without looking at other sources of info besides their own web site. I'd have told you the same thing if you'd have decided to switch from Amsol to Mobil 1 based on Mobil 1's web info.
  20. efusco
    19,891
    1,194
    Nixa, MO
    Considered and decided against for a number of reasons. First, my time is valuable and I'd already spent WAY too many hours dealing with the whole SKS problem and didn't want to waste more time and travel going for an unnecessary oil change. Second, they were 'trying' to be nice and compensate me for my trouble, I hate to punish or discourage that. Third, they don't carry Mobil 1 at the dealer anyway, so I'd be using Castrol synthetic or buying my own. Fourth, and maybe most importantly, I don't think it's that big of an issue. I've noticed no change in engine performance, dumping 4 quarts of perfectly good motor oil would be an even further and more environmentally unfriendly act for my own selfishness....just not worth it.
    I doubt they did notice. Depending upon what the oil goes into I doubt they spend a lot of time studying it. Some grease monkey kid dumps the old, adds the new and collects his check with as little brain activity involved as possible.
