tach signal
Discussion in 'Gen 3 Prius Technical Discussion' started by sciguy125, Dec 19, 2009.
  1. sciguy125
    sciguy125 Junior Member
    CA
    Does anyone know if there's a signal other than IGF that can be used to determine engine speed?
    I want to install a tach, but I know that the engine can spin without actually burning fuel. I want to have separate engine speed and fuel indicators.
  2. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    Don't know if this will help, but here is a link to what little there is on
    installing an after-market tach in a Gen II car:
    http://techno-fandom.org/~hobbit/cars/tachack/
    Have you considered getting a ScanGauge, it will give you RPMs and a
    whole lot more and its plug-and-play as well: :cheer2:
    PriusChat Shop : ScanGauge II Scan Tool + Digital Gauges + Trip Computers [ScanGaugeII] - $159.95
    Unfortunately, the XGauge feature is inop on the Gen III at this time.
    It took a number of years for folks to crack the Gen II codes, so there is
    reason to believe that Gen III XGauges will be found sometime in the
    indefinite future.
  3. tumbleweed
    tumbleweed Senior Member
    4,067
    690
    Eastern Oregon
    I agree with Rokeby, check out the ScanGaugeII.
    When you set it up you tell it you have a hybrid and it indicates as long as the car is on even when the engine is off. I have mine set up to tell me coolant temp, ignition timing, and throttle position as well as RPM. There are several other parameters you can display (4 at a time) if you wish.
    It is small and light and mounts nicely on the steering column with velcro. Total installation and set up time about 5 min.
  4. sciguy125
    CA
    Thanks, but I know about the scanguage. I'm just looking for something simpler/cheaper. I'm no stranger to electronics, so if I can find an appropriate signal, I'll be able to get what I want.
  5. bwilson4web
    15,932
    Excellent!
    I believe the engine control computer is located in the engine compartment. To tap a spark, injector or other signal, you'll need to run a data line (or signal) from the compartment into the cabin. Ken@Japan posted a note about tapping a signal this summer and that might be your best bet.
    Do you have the instrument already? What make and model? What interfaces does it come with?
  6. ken1784
    ken1784 SuperMID designer
    2,943
    1,380
    67
    Yokohama, JAPAN
    engine speed: #16 of A connector on the Power Management ECU shows the engine speed.
    injector: we have to tap off from the injector drive wire, like shown following picture.
    Ken@Japan
  7. sciguy125
    CA
    I don't have anything yet. I'm just doing research before I spend money on anything.
    Thanks. The engine speed signal you're talking about is called GI in the schematics. Do you know what the signal looks like? Also, do you know where the Power Management ECU and ECM are physically located?
  8. risingsun
    risingsun seeker of the way
    186
    30
    Prescott, AZ
  9. ken1784
    2,943
    1,380
    67
    Yokohama, JAPAN
    The GI signal is 12V square wave as attached.
    The PM ECU is located behind the glove box and the ECM is located at driver's side under the hood.
    But, it's hard to access the ECM connectors because of the connector cover, so I tapped off from the injector connector.
    Ken@Japan
  10. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    risingsun,
    Better look twice at the Bullydog unit. The only Toyota on their
    applicable vehicle list is the Tundra.
    For any multiple gauge display unit to work effectively on the Prius, it
    has to have a "Hybrid" setting. This because the Prius ICE frequently
    shuts down during vehicle operation. Without the hybrid setting the
    gauge package starts and stops the mileage readings whenever the ICE
    shuts down, making at least MPG and "average" readouts useless.
    I think that I've looked into all the various currently available gauge
    units mentioned here on PC. The only one that I know has the Hybrid
    setting is the ScanGauge. It also has the very useful programmable
    XGauge feature for displaying hybrid specific parameters, currently
    working on the Gen II, but not the Gen III.
