Tech specs for HV battery?
Discussion in 'Gen 2 Prius Main Forum' started by mspencer, Mar 9, 2005.
  1. mspencer
    mspencer New Member
    101
    Council Bluffs, Iowa
    I posted something about an amateur Prius documentary a while back, but that thread got lost when the forum had problems.
    I've decided to try to help teach myself the art of video production. Since I've been obsessed with the Prius for the past several months (just can't afford one yet), I'm trying to plan and shoot a documentary about the Prius. This will be low-budget, and I'll distribute it for free on the Internet.
    So anyway... one of the segments I'm putting together involves the HV battery. I'm going to show why the HV battery lasts as long as it does, and why conventional wisdom about rechargable batteries doesn't apply here. That is, people already know how rechargable batteries last if you beat them to death: overcharge them a little bit, or leave them on a float charge long-term; discharge them until they're unusable, then leave them sit for a while and then quick-charge them again. On the other hand, if you have several thousand dollars worth of battery management systems on a vehicle, and you carefully control charge current, discharge current, and state of charge, you get much more life out of your batteries.
    We know this -- first generation Prius owners already know this is true first-hand. But why is this true? I'm going to try to establish this in a rather technical video segment. Because it's distributed over the Internet, people can skip this part if they want.
    I'm looking for some details about the HV battery, to help with this video.
    First, what do we know about the individual cells in the 2004/2005 Prius battery pack? I believe they're NiMH D-cells, but do we know what manufacturer and what model? I'd like to try to find the data sheet for just those battery cells.
    Second, for the 2004/2005 Prius, what do we know about how the battery pack is treated? I think Graham's Prius page says he measured something like 50 or 60 A of charge current during regenerative braking, but is that MG1-side current or battery-side current? What were those maximum and minimum states-of-charge the Prius considers empty and full, again?
    Currently I'm planning three parts for this HV battery life segment. For part 1 I'd like to interview someone with Toyota (maybe a Prius tech on his day off, or something) and establish how the Prius treats its batteries. We might even show viewers sections of the repair manuals for confirmation, if that information is available there. Or in a pinch, maybe I can just get permission to show sections of the manual and talk about them myself.
    For part 2, I'm interviewing Dr. Tisko at the Chemistry department of the University of Nebraska at Omaha. I think we're planning on shooting this next Tuesday. He'll give us a lesson on how rechargable batteries work, and what mechanisms cause a battery to break down over time. He said he can't get too specific, because battery design is still an area of active research and it's not his specialty. He's pretty sure he can get us "up to speed" enough that we can talk to a professional and understand what they're saying.
    And then for part 3, I'm hoping to find someone "in industry" to interview to connect everything together: why will a battery treated the way a Prius treats its batteries last a long time, but a battery treated the way little Timmy's RC car treats its batteries needs to be replaced after a couple of years.
    (Dr. Tisko surprised me. I was just hoping for a few minutes of on-camera interview, but it sounds like he's planning on showing us a demonstration or two. This could be cool. :) )
    Because this is non-profit and amateur and all that, and because I really don't know what I'm doing yet, I'll definitely share these video segments with the community as soon as they're finished.
    Thanks ahead of time for the information, guys. :)
  2. victor
    victor New Member
    414
    Gilching Bavaria Germany, & Drapanos, Crete, G
    The HV batterie of the Prius 1 was 228 cells at 1.2varranged in groups of 6, making 38 modules, providing 273.6V. The new Prius has 168 cells at 1.2v again in groups of 6 making 28 modules and providing 201.6v. This has produced a more compact and lighter power pack.
    In the previous Prius the connections betwen the cells were single points. In the new Prius, the cells are connected at 2 points which helps reduce internal resistance.
    The battery pack is made by Panasonic. Not 100 % sure of the composition, but I think you have it correct.
  3. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    <div class='quotetop'>QUOTE(mspencer\";p=\"70986)</div>
    http://www.peve.panasonic.co.jp/catalog/e_kaku.html
    "New Prismatic Module" is for NHW-20 and "Current Prismatic Module" is for NHW-11.
    http://john1701a.com/prius/presentations/p...entation_15.htm
    Lower and Upper limit is 40% and 80%. The target SOC is 60%.
    Regards,
    Ken@Japan
  4. xevious
    xevious New Member
    187
    Oregon
    "D" size cylindrical cells were only used in the first generation Prius. (Early Japanese models, U.S. model year 2000.5 and, I believe, a few 2001s.) 2001 and later models used a higher density prismatic battery. The 2004 THS-II (third generation Prius) uses an improved version of this prismatic battery.
    Others can supply much better technical information; just wanted to head off that "D battery" misconception as quickly as possible!
  5. mspencer
    mspencer New Member
    101
    Whew -- you guys saved me from looking like an idiot in front of potential interviewees then. *reads more* (The professor at UNO already knows I'm an idiot -- I'm not worried about him. :) )
    I googled for Panasonic NHW-20 and didn't find much. It looks like these Prismatic modules are self-contained sets of 6 cells with some battery-management electronics inside. It sounds like it'll be even harder to get information about the contents of those modules... but I'll try anyway. Do we know what kinds of cells are inside those modules? If those cells are available as separate products, they might have data sheets.
    Maybe I should try to email Panasonic customer support and find out.
    I have a bunch of 9000 mAh NiMH D cells I was going to use as a visual aid. I guess I can put those away... X__X
    Hmm...on even further analysis, it seems NHW20 is the model name for the current generation of Prius. Previous models were NHW10 and NHW11. http://www.autospeed.com/cms/A_2357/article.html
    So "Panasonic Prismatic NHW20" just means the battery in the current-generation Prius. Hmm...
  6. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    Funny you should mention it, but the Honda Insight actually uses D-Cells for its battery pack.
  7. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    Ford also uses the D-cell design. And both are supplied by Sanyo, which is preparing to double production for them within the next 2 years.
    In other words, HSD will retain that 2 generation lead for awhile still. And as time goes on, it will become more obvious what the heat-management & energy-density advantages really provide.
    By the way, I'm glad more people are taking interest in the greater detail now. It makes explaining why Prius is actually on the third generation a whole lot eaiser. Though, I am still hoping this simplistic chart will do the trick.
  8. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    <div class='quotetop'>QUOTE(john1701a\";p=\"71052)</div>
    Are you saying Honda Insight uses Sanyo cells?
    http://www.peve.panasonic.co.jp/e_catalog2.html
    Regards,
    Ken@Japan
  9. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    <div class='quotetop'>QUOTE(mspencer\";p=\"71027)</div>
    They only supplies it as 7.2V module, therefore no spec is available for the single cell.
    http://www.nrel.gov/vehiclesandfuels/energ...hive_prius.html
    Regards,
    Ken@Japan
  10. Anonymous
    Anonymous Guest
    It's the Accord hybrid that uses Sanyo cells - the Insight remains on the Panasonics. Really good that we're starting to get some competition in the hybrid battery market - a one horse race would never have led to the price war we need.
  11. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    No electronics in the modules themselves that I am aware of, would be a bit redundant. The diagram you see on Panasonic's site is a typical application of their module, which is exactly how the Prius manages the battery pack. You have a battery ECU that monitors the voltage and temperature of each module and can detect the failure of any one module.
    By the way, you'll get more engineering specs from New Car Features than you will from the repair manual.
  12. xevious
    xevious New Member
    187
    Oregon
    NHW-20 refers to the newest Prius.
    Conceptually, the biggest difference between a cylindrical ("D", "C", "AA", "LR-6", etc.) and a prismatic battery is that the electrode/electrolyte layers are rolled up in a cylindrical battery and flat in a prismatic battery.
    I found a good link with a summary of the various construction techniques for you: http://www.valence.com/construction.asp
    As for the lack of competition, keep in mind that the battery technologies used by our Prius are quite new, and are protected under a number of patents. Unless a completely new chemistry or design establishes itself, we are unlikely to see much competition.
  13. mspencer
    mspencer New Member
    101
    Hmm... New Car Features... it sounds like I need to sign up for access to Toyota's technical document library for a day. I can do that. Do they make it difficult to download entire documents for future reference?
    I just spoke with the parts department at Old Mill Toyota. He said the entire HV battery pack is listed at $4823.41, and he doesn't show any items for one of the 28 individual batteries by themselves. Basic math tells me an individual battery costs $172.26. This makes sense: my fancy industrial 9000 mAh NiMH D cells cost $15.00 each, and I don't think they can tolerate anywhere near 100 A of charge/discharge current.
    This is interesting stuff. I wonder if that flat-plate design has anything to do with the battery's higher current capacity, in much the same way as an automotive lead-acid battery with lots of thin, flat plates is capable of such huge current for cranking the engine.
    (Or maybe I just don't know what I'm talking about, and my normal NiMH D cells would take that much of a beating just fine, as long as I didn't use wimpy little wires to connect the battery to power.)
    So my targets for Dr. Tisko's interview should be:
    * see the basic chemical mechanisms that make a rechargable battery work
    * talk about which parts of that process can degrade, and how those are affected by overcharging, leaving a battery flat, charging too fast, discharging too fast, etc.
    * talk about how the battery's structure (thin flat plates instead of cylinder-shaped plates) allows the battery to tolerate faster charging and discharging
    --Spence
  14. xevious
    xevious New Member
    187
    Oregon
    Spence,
    Prismatic (flat/rectangular) cells generally store less energy per mass than cylindrical cells. They pack more efficiently, however, so often there is an efficiency gain in a multi-cell prismatic system.
    I think you're going in the right direction with this, and I applaud your effort. Sounds like a fun and educational project!
    A bit of advice that I'll offer as a professional researcher and classroom know-it-all (that would be the one at the front who blabs on at glassy-eyed students) is to go to the library and search the primary literature before conducting a formal interview. You should be able to find some good review articles (or less technical articles) in the IEEE, chemical, electrical, and physical journals. I'd point out a few if I were at all familiar with this subject area.
    Your local (university?) library should have a selection of these and the ability to search them electronically.
    If that route is too inaccessible or too taxing, set up a telephone pre-interview with Dr. Tisko, and ask the really boneheaded questions then. He should be able to point you in a few good directions to get your knowledge started.
    A final suggestion would be to write all of your interview questions early, and send them to Dr. Tisko well in advance of the interview. This will give him plenty of time to formulate good, accurate answers. During the interview, you'll probably ask a few new questions, but try to stick to the pre-planned list. This requires considerable preparative effort on your part, but will result in a more professional and meaningful interview.
    Have fun, and keep us posted!
  15. mspencer
    mspencer New Member
    101
    Thanks Xevious. Hopefully a .torrent should be forthcoming in the next couple of weeks. :) (You might want to edit your earlier post, by the way, and add asp to the end of your link.)
    From what it sounds like, this won't be a pure interview. I'll introduce him, establish his position and expertise, and then things will be teacher/student from then on. You're right, though: I should learn as much as I can about this before wasting someone's time.
    I think I already have the basics down, though: http://www.valence.com/BatteryEducation.asp
    Apparently there's some kind of barrier material which keeps the postiively and negatively charged portions of electrolyte separated. I think he mentioned something about dramatic things happening when the negatively and positively charged portions of electrolyte combine all at once, so I don't know. I think there's some magic happening in that little orange tube in the flash animation on that site, though, and that things aren't nearly as simple as that tube makes it seem.
    (So I think it's not so much that he's agreed to an interview, I think it's that he agreed to teach a mini battery chemistry class for me. That makes me extra worried about wasting this man's time.)
    --Spence
  16. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    The separator is the one of the biggest driving factors in battery reliability as well as its connecting technology. Degradation (mostly oxidation) of the electrodes (the plus and minus) is another big factor.
  17. acarapella
    acarapella Junior Member
    82
    Rochester NY
    Hey! I understand that I am replying to a 19 year old thread, but back to the cylindrical cells found in "gen 0" 1998-2000 Prii. I am an importer of Japanese cars (to the USA) and, for my car dealership here in NY, I have had at least 150 2-4 gen Prii. I love them. So naturally, I am SOOOO wanting to import a 1999 prius. Cars have to be 25 years old to legally bring into the USA.
    Does anyone know what would be involved in running a 2001-2003 pack in a 1998-2000? Can it be done? China makes the 1998-2000 cells, but I dont trust them and its $360 each in shipping plus a long wait.
    I cannot bring my self to import a car that may be a paperweight to its final owner
