Technical Question
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by BitShifter01, Feb 24, 2009.
  1. BitShifter01
    BitShifter01 New Member
    91
    Hello,
    I was on my way into work when my Prius started to cut out when accelerating. Let me explain:
    Driving conditions:
    About 19 Degrees and clear.
    The State of Charge on the Hybrid Battery was 1 bar away from being green. I was going about 55 mph and decided to accelerate to the speed limit (65). When I accelerated I noticed the Prius seemed to have revved higher than normal and then the gas engine cut out like it hit its rev limiter. I also noticed a slight loss in power. It was almost like the batteries where dead. I notice the car seems to rev high when the batteries are red (two bars) but then it stops once the batteries are 3 to 4 bars and up.
    Has anyone else experienced this problem? I only noticed it one other time. I would contribute it to the cold weather, but I bought this car new back in 04 and have never experienced this problem.
    I may take it into the dealership since it is still covered under warranty.
    Any help is appreciated.
    Thanks,
    Ryan
  2. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Haven't had anything like that happen. No check engine light?
  3. Bob64
    1,540
    93
    Virginia
    What car do you have?
    Be sure the vent is not covered.
  4. richard schumacher
    7,664
    1,042
    United States
    Good one! I haven't thought of that possibility in a while.
    Bob means, make certain that the battery cooling vent to the right of the rear seat is completely un-obscured.
  5. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi Ryan,
    The vent comment would be an unlikely issue if your temp was 19 F, but it would if the temp was 19 C.
    A standard thing to check with loss of power on all vehicles is the engine air-filter. Hold it up to the sun, and you should be able to see a glow through the element. If not, you need a new element.
    BTW, this seems more like a "Care and Maintenance" question, than a "Prius Technical Discussion" post. But, that is just one of my pet peives.
  6. northwichita
    481
    102
    29
    Wichita KS
  7. richard schumacher
    7,664
    1,042
    United States
    Are you certain it was not merely wheel slip?
