Temperature
Discussion in 'Gen 3 Prius Main Forum' started by RangerPete, Feb 13, 2010.
  1. RangerPete
    RangerPete New Member
    Earth. Let's save it.
    Most cars have a temperature gauge, I noticed the Prius does not. Why is that?
  2. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    You mean a gauge to indicate the engine's internal temp?
    There's not one because when they designed the car neither of us were asked if there should be one.
  3. Flying White Dutchman
    4,374
    313
    this must be a new major security defect of the prius.
    2.000.000 prius need to be recalled.
  4. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    Usually, after braking over a pothole, the driver rather than the car runs a temperature.
  5. Flying White Dutchman
    4,374
    313
    in those cases whe need toyota to install this in to the prius
  6. hockeydad
    hockeydad New Member
    298
    23
    zip
  7. Tom Banjo
    Tom Banjo New Member
    62
    South Florida
    does scangauge II show temp ?
  8. RobH
    RobH Senior Member
    2,369
    984
    70
    Sunnyvale, California
    Temperatures? We've got temperatures. Inside, outside, engine water, air intake, MG1/MG2, traction battery, tires (all 4 individually), plus a few others that I can't recall at the moment.
    The problem is that the only driver display is the red triangle that says that one of them is out of range.
    A ScanGauge can show many of them, and the Toyota Techstream scantool can show all of them.
  9. tumbleweed
    tumbleweed Senior Member
    4,067
    690
    Eastern Oregon
    Out of the box it will display engine coolant temperature. If you program the Xgauge feature you can choose from 7 other temperatures to display. It can also display RPM, throttle opening, HV battery current, and a bunch of other stuff. You can only display 4 things at a time though.
    check this thread: http://priuschat.com/forums/gen-iii...discussion/64406-scangaugeii-work-2010-a.html
  10. F512M
    F512M Member
    415
    Laguna
    Please not another recall:eek:
  11. JimboPalmer
    12,470
    6,875
    Greenwood MS USA
    If they show the driver's internal temperature, you KNOW where they are putting the probe!
  12. Harold Bien
    Harold Bien Member
    113
    39
    Stony Brook, NY
    For such a technologically advanced vehicle, I'm surprised they didn't consider offering displaying a lot more information than usual to the driver. Given that it's an electronic display, doesn't take much more resources to give us more information on how the vehicle is operating instead of making the complex HSD display. Something similar to a "debug" screen/info, but more closer to information one would expect from a FADEC - a nice monitoring screen might display engine RPM, temps, battery/bus voltage, oil pressure/temp, exhaust gas temps, etc.
  13. tumbleweed
    4,067
    690
    Eastern Oregon
    It would be nice if they had provided more information but we, on PriusChat, are not average Prius owners. The average owner probably wants to know how fast they are going and how much gas in left in the tank, anything else would be to much to absorb.
  14. OZ132
    OZ132 Member
    170
    Northern Indiana
    Amen!
    And: This is the STOP pedal, this is the GO pedal....
  15. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    Toyota got an "eye-ful" when I submitted my satisfaction survey. Since they used a generic form & asked about problems with the instruments I selected "yes" & said some of the problems are that coolant & inverter temps are missing. They also need to supply more feedback space. I ran out of room explaining my dissatisfaction.
    IMO the bottom line is that Toyota doesn't want to provide useful data to the driver/owner. It would rather have little problems become big problems that only the dealer can solve, hopefully out of warranty.
  16. bwilson4web
    15,934
    Ok, ok, I have the answer ... aroma therapy:
    • Soft accelerator and braking - heat a flower smelling wax
    • Hard accelerator and braking - heat a diesel smelling wax
    • Speeds averaging +75 mph for 10 minutes - diesel
    • Speeds averaging 65 mph for 10 minutes - whiff of roses
