Test Drive: 2006 Ford Escape Hybrid
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Tideland Prius, Aug 12, 2006.
  1. Tideland Prius
    16,403
    When the 2000 Honda Insight arrived on the market, the first consumer gasoline/electric hybrid, it didn't look like anything else on the road. It was small and slippery, with fender skirts and tiny tires, and looked more like a big bullet. Ditto the Toyota Prius, which looks as futuristic as its propulsion system.
    But there's a new wave of hybrids, built not as unique models, but as hybrid versions of existing vehicles. These include the Toyota Highlander Hybrid, Toyota Camry Hybrid, Honda Accord Hybrid, Honda Civic Hybrid, and my tester, the Ford Escape Hybrid. Were it not for the badges, a discreetly-placed battery vent in the rear quarter window and a special gauge, you couldn't tell it from a regular Escape just by looking.
    Full Article
  2. andrewgs
    andrewgs I Pity Da Foo!
    86
    Houston, TX
    Pretty good article that will hopefully win some customers. I like the stories from the cab companies that have adopted the Escape hybrid as opposed to the Crown Vic. They love them and have put over 100,000 hard city miles on them without failure.
    Ford doesn't get the respect they deserve for the Escape hybrid.
  3. jbarnhart
    jbarnhart New Member
    629
    Santa Clara, CA
    I've put some miles on a friend's Escape Hybrid and I really like that SUV. I was struck by how smooth and seamless everything is. My Prius sometimes has little "bumps" when it switches between ICE and electric at cruise speed, but the Escape gave me none of that feeling. What was so cool about it is that you could toss the keys to anyone with a driver's license and they would be unlikely to even know you'd given them a hybrid car to drive.
  4. rudiger
    rudiger Active Member
    696
    45
    Cincinnati, OH
    There may eventually be two distinct types of consumers for hybrids, not unlike (ironically) SUVs.
    Modern AWD/4WD SUVs are either car-based or truck-based, respectively. The smaller car-based SUV with its AWD system is designed to be as innocuous as possible. It is front-wheel drive the majority of the time and when maximum traction is required, manufacturers strive to make the shift from front to rear drive as automatic and unnoticable as possible. In a lot of car-based SUVs, there's nothing from the driver's viewpoint to indicate they're driving anything other than a regular car.
    OTOH, large truck-based 4WD SUVs are normally rear-wheel drive and give the driver much more control over the change from 2WD to 4WD. While most offer an automatic system, there is also a switch or lever which provides the driver with manual control over a transfer case (absent in the car-based SUV), in addition to having a 4WD-low range.
    Hybrids may break down into a similiar split. On one hand will be the Ford Escape-type, where the manufacturer tries to disguise and integrate the hybrid system and make the driving experience as similiar to any other ICE vehicle as much as possible.
    Then there will be the Prius-type, which has unique innovations and puts the hybrid system 'in the face' of the driver, letting them know everything that's going on (and may even allow them to have manual control over which propulsion system is being used).
  5. dipper
    dipper Senior Member
    1,242
    252
    <div class='quotetop'>QUOTE(rudiger @ Aug 12 2006, 08:51 AM) [snapback]302124[/snapback]</div>
    There are AWD Truck based SUVs too, you know!!!!
    LandCruiser/LX470 and GM Denali/Caddy Escalade are all good example. The LC/LX have a transfer case for high/low as well like car based SUV..... so I don't get the comparisons.... :huh:
  6. rudiger
    696
    45
    Cincinnati, OH
    <div class='quotetop'>QUOTE(dipper @ Aug 12 2006, 08:44 PM) [snapback]302347[/snapback]</div>
    Upon what cars are the Land Cruiser/LX470 and GM Denali/Cadillac Escalade based? They are body-on-frame, truck-based, full-size SUVs.
    The distinction is simple:
    4WD = transfer-case equipped with a user-operable low-range, truck-based, normally rear-wheel-drive. I believe all are full-time 4WD (nothing has manual lock-out front hubs, that I'm aware of), but it's not AWD.
    AWD = no transfer-case and no low-range, car-based, normally front-wheel-drive. There may be a user-operable switch to 'lock-in' the torque split, but it's not a low-range.
    The examples cited above have transfer-cases and low-ranges so while they might be called 'AWD' by the manufacturer to appeal to more consumers, in reality, they're 4WD systems modified to operate full-time.
    It's purely a marketing gimmick. 4WD implies 'truck' (which is accurate) and could turn away some prospective buyers of big, expensive luxury SUVs, so Toyota and GM decided to call their most expensive, most sophisticated full-time 4WD systems 'AWD' in the hopes of fooling some consumers into thinking they're buying a plusher, car-based SUV.
    Another way to look at it is Jeep. Until the recently introduced Compass (which uses the same car-based AWD system as the Dodge Caliber), every Jeep had a transfer-case, a low-range, and was normally rear-wheel-drive. Thus, every Jeep could legitimately be called a 4WD.
    Unfortunately, while 4WD systems are preferred for legitimate off-road situations ('trail-rated' by the Jeep marketing department), the reality is that car-based AWD vehicles are best for the vast majority of drivers who never venture off-road.
  7. GreenGene
    GreenGene New Member
    177
    Northern Virginia
    When we decided we wanted to check out and probably buy a hybrid, the Escape Hybrid was the first vehicle we looked at. We were trading in a Honda CR-V, and really liked the small SUV - very practical size for us.
    Maybe it's because of the inevitable comparison with the CR-V, but the Escape just didn't impress us. And we wanted it to. We went on a test drive with the salesperson, and then went on another test drive without the salesperson. We took turns driving it, checking out the features, playing with the toys, etc. And it was nice ... but just wasn't what we had hoped for.
    The next hybrid we drove was the Prius. We placed an order and put down a deposit the same day. :)
  8. Tideland Prius
    16,403
    There are also part-time and full-time 4WD neither of which require you to do the hubcap thing any more. They're all controlled via a rotary knob or a shifter inside the vehicle.
