The "computer" that accompanies the main battery on the 2001 Prius
Discussion in 'Gen 2 Prius Technical Discussion' started by ElizaDay, Sep 8, 2008.
  1. ElizaDay
    ElizaDay New Member
    17
    NORTHERN CALIFORNIA
    2001 Prius
    Greetings.
    Toyota is telling me that they cannot replace the main battery without replacing some "computer" that accompanies it. They were very vague and short. The battery is 2200, the computer is 1100.
    I'm looking into getting a salvaged battery but I'm wondering about the computer. Is this necessary or can it be bypassed. Do I really need to replace both or is this Toyota's way of price-gauging?
    Thanks,
    Leslie Intriago
  2. Patrick Wong
    18,200
    6,490
    Hi Leslie,
    The battery ECU is located within the battery enclosure. Unless it was damaged, there is no need to replace it.
    My 2001 traction battery was replaced under warranty at 61K miles. At that time, the old battery ECU and three system main relays were moved to the new battery enclosure, then the total assembly was installed in the vehicle.
    Frequently when you buy a salvage battery, the battery ECU and the relays will be included since they live within the battery enclosure. If the ECU is not included, then the seller should make that clear.
    BTW, $2,200 is a good price for the new traction battery as MSRP is closer to $3,000. Has the dealer advised you whether there will be a delay in supplying a new battery?
  3. statultra
    statultra uber-Senior Member
    798
    31
    Edison,NJ
    2001 Prius
    theres absolutely no reason to replace the battery computer, if you want to see it heres a picture i took a while back[​IMG]
  4. statultra
    798
    31
    Edison,NJ
    2001 Prius
    All it is a little box, that has a large connector that plugs in that monitors every aspect of the battery, most of the time when you buy a salvaged battery it comes with the battery computer.
  5. bwilson4web
    15,934
    Speculation on my part:
    • control computer software - the NHW11 computers, to the best of my knowledge, have no download or field upgrade. To get the latest software, it will take a different control computer. The way to tell is to check the part number and see if they can show a different variation of the part is evident.
    • relays - although they are pretty long lived, there is a risk of some contact wear over time. I admit, this one is a bit of stretch. Power flow is really handled by the hybrid vehicle ECU managing the inverter so I have a little trouble with relay replacement.
    GOOD LUCK!
  6. deanatglobe
    deanatglobe New Member
    San Diego
    2002 Prius
    My battery is dead on my 2002 Prius and my Dealer is telling me that to replace the battery they also have to replace the ECM. They say the new battery is not compatible with the old ECM.
    Price for both is 3650.
    Has anyone else heard the same thing? I am picking the car up from the dealer this afternoon. It still runs with the check engine light on. I am going to get the codes when I pick it up, they said one of the battery modules is reading bad.
    Dean
  7. tochatihu
    tochatihu Senior Member
    9,457
    3,656
    Kunming Yunnan China
    2001 Prius
    If corrosion from electrolyte leakage were extensive it might damage the ECU connections or worse. But one could probably determine that by visual inspection.
    I have no info on whether NHW11 battery ECUs had any firmware upgrades during the model run. But there is evidence that DIY battery replacements are successful without seeking out the most recent ECU.
    A generous assessment would be that for a Toyota new part replacement with 1-yr warranty, dual replacement is required by company policy. Less generous assessments have already been made here.
  8. colonel570
    colonel570 New Member
    48
    Elon, NC
    2001 Prius
    I need one. Does anyone have an extra one for sale?
