THE NEW PRIUS MODEL CONCEPT ????
Discussion in 'Gen 2 Prius Main Forum' started by mjms2b, Oct 27, 2007.
  1. mjms2b
    mjms2b MJ Green
    349
    Socal
  2. GeekEV
    GeekEV Member
    417
    NorCal, USA
  3. hill
    8,562
    They also talk about the Volt . . . mistakenly calling it a 'Pure' electric vehicle?
    Really? Then what's that ICE for ? What's that gas tank for?
  4. MarinJohn
    MarinJohn Senior Member
    3,945
    304
    The 'new Prius" so far called 'Hybrid X' looks great! Suicide doors, lounge chairs, distinctive styling and 100mpg all come together in a nice package.
  5. mjms2b
    mjms2b MJ Green
    349
    Socal
    I already want one, but I'm waiting for the plug, :)
  6. blamy
    blamy Member
    380
    Central Florida
    It wouldn't be hard to start producing the X in a couple of years. If only Toyota had a little more brass in the right area we could see this in the near future. Glass roof looks nice but I'll bet that would be very hot in the south and southwest.
  7. mjms2b
    mjms2b MJ Green
    349
    Socal
  8. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    <div class='quotetop'>QUOTE(MJGreen @ Oct 28 2007, 09:52 PM) [snapback]531768[/snapback]</div>
    Confirmation of what, precisely? the article you liked to is a historical lay out of the various concepts and press releases and such, but I don't see any confirmation of anything other than the fact that Toyota has said they plan to stick to NiMH.
    Could you clarify what you are talking about, esp. since your original post contains no text for reference.
  9. David Beale
    David Beale Senior Member
    5,963
    1,985
    Edmonton Alberta
    That car was first shown in Germany last winter. It is indeed called a "concept car". A Toyota rep. stated at that time "this shows some of the ideas we are considering for future Toyota hybrid models". Note "some of" and "future Toyota Hybrid models". I think you are reading way too much into this. It's a "concept car", not a pre-production test model.
    Most automakers are not brave/foolish enough to produce such a different design. It's the "Edsel effect". They hate bathing in red ink!
  10. mjms2b
    mjms2b MJ Green
    349
    Socal
    <div class='quotetop'>QUOTE(David Beale @ Oct 28 2007, 08:32 PM) [snapback]531790[/snapback]</div>
    yes of course, I get that, I haven't quite lost my sanity. I meant only that this could be - or that many people think that this is the precursor to the new Prius, versus some other X-hybrid. That's all I meant. it's just exciting to see. I have no doubt the final product will be much different, but I love to see progress. ;)
  11. Tiki Robot
    Tiki Robot New Member
    <div class='quotetop'>QUOTE(hill @ Oct 27 2007, 08:00 AM) [snapback]531127[/snapback]</div>
    From what I read, the gas "engine" is only a generator that powers the battery (ie, the gas engine never directly makes the tires spin). It's simply an alternate source of electricity. If you never drain the battery, you could get away with never using any gasoline.
    That's the way it was described in the article I read, anyway.
  12. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,000
    Fort Lee, NJ
    <div class='quotetop'>QUOTE(Tiki Robot @ Oct 29 2007, 10:02 AM) [snapback]531924[/snapback]</div>
    Sure, Volt's gas engine can spin the tires. When the battery is drained, the power from the engine goes straight to the electric motor and in turn to the wheels. The battery pack can not be charging and powering the electric motors at the same time!
    The crucial question is will Volt's IC engine kick in to assist during high power demand? If it does, it will make Volt a hybrid. If they IC engine does not assist, the demand / spec / life and price on the battery pack is going to be very expensive making it not ready for the mass market.
  13. Tiki Robot
    <div class='quotetop'>QUOTE(usbseawolf2000 @ Oct 29 2007, 01:44 PM) [snapback]532008[/snapback]</div>
    That's not what the article I read (or the wiki) says. Obviously when the gas generator is running, it's the original source of the power that ultimately spins the wheels, but it's the electric motor that does the work.
    It's not entirely clear to me whether the gas generator would be supplying power directly to the to the motor or whether it charges the batteries which power the motor. The implication in the article I read was that the generator is simply another way to charge the batteries, just like plugging it into the wall.
    It wouldn't need to do that if the generator simply kicked on when the batteries were running low and kept them at a minimum charge.
    I saw one on display a while ago and they did mention that they were having trouble making the battery hardy enough.
  14. usbseawolf2000
    14,487
    3,000
    Fort Lee, NJ
    <div class='quotetop'>QUOTE(Tiki Robot @ Oct 31 2007, 12:05 PM) [snapback]532945[/snapback]</div>
    Right, there will be no mechanical connection but the power can flow skipping the battery pack. When the Volt's battery get low, it would be a series-hybrid then wouldn't it? From that we can say Volt is a series hybrid with an extended EV mode.
    Volt's generator will need to be at least 85hp(Prius: ~35hp) and the traction motor with 160hp (Prius: 67hp). Considering it's battery pack can hold 12 times more juice than Prius', it is going to be expensive.
    We'll see how the spec of the next gen Prius is going to come out. I think Toyota is going to use the same 1.5 liter engine. They may raise the ICE RPM to 5.5k or 6k RPM. The generator and electric motor should get more powerful while decreasing in size. The battery pack may weight slightly less because they will continue to use the same proven NiMH.
  15. bredekamp
    bredekamp Member
    569
    Somerset West, South Africa
    <div class='quotetop'>QUOTE(MJGreen @ Oct 27 2007, 07:43 AM) [snapback]531072[/snapback]</div>
    The shape I would say is spot-on for the next Prius. If you can imagine the Hybrid X with conventional seats, a B-pillar and regular doors, I'd say it would be very nice as a Prius3.
    I do hope the change the dashboard....I don't like that pod in the middle that looks like a big eye...staring at you.
  16. mjms2b
    mjms2b MJ Green
    349
    Socal
    <div class='quotetop'>QUOTE(Albertus @ Oct 31 2007, 10:57 AM) [snapback]533014[/snapback]</div>
    no doubt there will be many changes before it acutally arrives.
