The Smart key: More than just smart
Discussion in 'Gen 2 Prius Main Forum' started by 100 mph, Aug 17, 2008.
  1. 100 mph
    100 mph Junior Member
    40
    The indestructibleness of the Prius never ceases to amaze me. The other day, I hear this clanging coming from the dryer. It's the Smart key. My daughter left it in her jeans, and it went through the entire wash cycle. It went through most of the drying cycle too, until it fell out of the pant pocket and started clanging around.
    I dreaded the thought of having to pay hundreds of dollars for a new Smart key. It turns out that the dryer saved the key, because it works just fine.
    I've heard of people dropping cell phones in the toilet, and saving it by taking it apart and blow drying it immediately thereafter. The dryer evidently did the same thing for the Smart key. I am amazed.
  2. ceric
    ceric New Member
    1,114
    Fremont, CA
    The SmartKey has UHF antenna. The antenna volatge is the highest inside the transponder. Water has high resistance compared with metal. When any electronics got wet, make sure you dry it complete first before you "try to see if it still works"!
    Once you activate the high-voltage antenna, no one knows what is gonna happen!
    The IC runs on <5.5V, which is safe with water.
    Drying it completely also prevents rust build-up.
    Don't give Toyota too much credit on this. Most hand-held electronics are like this.
    Dry it before you try to see if it still works!!! The moment you try it, it could fail!
  3. Bob64
    1,540
    93
    Virginia
    uhhh... FYI: the key is equipped with a rubber seal, so it is water-resistant.
  4. apcpa2000
    apcpa2000 Junior Member
    33
    South Florida
    Good to know.
  5. PriuStorm
    PriuStorm Senior Member
    2,239
    149
    Davis, CA
    Can the rubberseal be damaged by the dryer?
  6. rfruth
    rfruth Member
    394
    Houston, Tx
    sure it can be damaged, someone test it :D
  7. rposton
    rposton Member
    139
    Nashville, TN
    My son went swimming with key FOB for about 30 min, now it is dead.
  8. RobH
    RobH Senior Member
    2,369
    984
    70
    Sunnyvale, California
    Try it plugged into the dash. That part probably still works, as well as the mechanical key.
    As for the remote/proximity functions, take the sliding cover off, remove the battery, and just let it dry out that way for a while. Replace the battery before putting it back together. Might work.
  9. patsparks
    10,664
    567
    Adelaide South Australia
    I can't answer quite as well as this bloke.
  10. bevspark
    bevspark Toyota, Major Sponsors of The
    707
    27
    Adelaide; South Australia
    Yeah!! Bring back the Bugga Commercials, they were very very funny. :rockon:
  11. Muhahahahaz
    Muhahahahaz Member
    136
    CA
    Water by itself will probably not damage it if you let it dry out first. However, pool water also contains a lot of chlorine, so I'm not surprised that it died.
    As an aside, I recently spilled a full cup of water directly on top of my desktop computer, causing it shut off immediately! My computer sits on the floor next to my desk, and it has a large fan that blows air out the top, so most of the water went straight through to the inside. I was pretty freaked out at first, but since I also built this computer, I know a thing or two about them. Well anyway, I simply unplugged everything, dried out the insides as well as I could, and let it sit for about 24 hours to dry. The next day I plugged it back in, and everything worked fine! :)
