Theft deterrent
Discussion in 'Gen 2 Prius Technical Discussion' started by mikemcmo, Mar 21, 2011.
  1. mikemcmo
    mikemcmo Junior Member
    32
    Evanston, IL
    We have a 2004 Toyota Prius, with the smart entry and start system. A few days ago the (factory) theft deterrent alarm started going off at random, when there are no obvious causes. Last night it went off 3 times in the middle of the night. I won't have time to get it to a dealer in the next few days. Is there a way to defeat the theft deterrent system and still have the car be drivable and lockable? Somebody suggested I could lubricate the door lock switches which may not be making good contact. Or, the fob battery may be low. (Can't check either till my wife gets home with the car.) Any other ideas? Thanks in advance.
  2. BAllanJ
    BAllanJ Active Member
    667
    78
    Kingston Ontario
    Oh.. I get to be the one to say this this time. Are you still using the original 12v battery? It'll do odd electrical things like this when it gets old... and yours would be old if its original.
  3. mikemcmo
    32
    Evanston, IL
    Thanks! When I hit the lock button, the LED lights up right away, which supposedly indicates the battery is fresh enough, but I'd be willing to change it.
    BUT, I can't figure out how to get the fob thingy open! I can pry a knife under the one edge, but there's no obvious way in, and if I pry the plastic any more it looks like it's going to snap. Any ideas?
  4. FreydNot
    FreydNot Member
    214
    37
    Seattle, WA USA
    I think he meant your 12v battery in the back of the car. There are many threads here about 12 volt batteries going bad around 3 years in (some sooner, some later).
    If you need a quick fix for the night, disconnect the negative cable from the 12 volt battery where it bolts onto the car (not where it connects to the battery). This will kill all power to the car until you reconnect it. You will loose your radio presets, the auto up and down on the windows will need to be reset, and I think you will loose the current average MPG.
    Your call if that is better then going outside a few times in the middle of the night.
  5. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    No. BallanJ is not talking about the key fob battery. He's talking about the 12 volt battery in the hatch area on the passenger side behind a large black box. If you're still on the original, it's almost certainly in need of replacement now. You can test it via http://priuschat.com/forums/newbie-forum/73400-weird-stuff-happening-mpgs-dropping-test-battery.html. Best to try it after the car has been left overnight or at least 8 hours.
    As for the fob, that's a separate thing. Do not pry it open. Just pull on the mechanical key release, remove the key and then slide cover off. Putting your thumb on the Toyota logo might help. You'll see 4 screws. You'll need a small Philips screwdriver for that.
  6. mikemcmo
    32
    Evanston, IL
    Thanks! I will try the self-test recommended. At this point, my neighbors still like me, I think, and with some luck I can keep it that way.
  7. Patrick Wong
    18,200
    6,490
    1. The fob battery definitely is not the problem. BTW, the fact that the red LED lights up when you press a fob button is not evidence that the battery is good from the point of view of providing an adequate signal for the Smart receivers in the Prius. It is merely evidence that the fob battery is not totally dead.
    2. It's possible that the 12V battery might be a problem, if the voltage is sagging down while the car is IG-OFF and this is provoking the alarm to trigger. The 12V battery is located in the hatch, right rear corner, under the triangle-shaped hatch floor piece.
    3. I doubt that you can access the electrical contacts in the door switches without considerable trouble and effort.
    4. Since you won't be able to visit the dealer for a while, the most useful thing that you could do in the interim would be to find and disconnect the alarm horn. If you can't do that, then disconnect the 12V battery. You can either disconnect the negative cable where it connects to the body, or else the positive cable where it connects to the dedicated positive jumpstart terminal within the main relay/fuse box. The advantage of doing the latter is that you won't have to crawl into the hatch and find the mechanical hatch lock release when it is time to reconnect the battery.
    Good luck.
  8. mikemcmo
    32
    Evanston, IL
  9. mikemcmo
    32
    Evanston, IL
    Thanks a lot for your help and expertise. I think I should get a battery tomorrow, to at least eliminate that as a problem. (See my answer to cwerdna.) I called Grossinger Toyota earlier today and the guy I spoke to didn't inspire any confidence. He said they would let it sit around until the alarm went off again. Well, that could have been 2 or 3 days, and they don't offer a courtesy car. My wife can't walk 18 miles to work, not like back in the old days when people were tougher. The dealer pays for one day of a car rental if you run up a $350 tab. No thanks.
  10. mikemcmo
    32
    Evanston, IL
    Anybody still out there? I had the 12V battery replaced today, $215 ka-ching, thanks very much. They said the car sat quietly for 2 hours outside the shop afterwards. Picked it up, got it home, 20 minutes later the alarm went off again. Arrrgh. Went out somewhere and had it parked for an hour, nothing happened. Went into a store for 3 minutes, and it went off again. When I got back home I ran the self-test again twice, on the brand-new battery. The first time it passed, with 12.4V, 12V, and 14.0V. Right afterwards I did it again, and this time it didn't do as well, saying it had 12.3V, and when it should have 12 it said 12 for a flash, but then went to 11.9V, and then in the third step it went to 14V. Any ideas? Thanks a lot! (Not sure how the postings work, and am also sending a duplicate reply to Patrick Wong in hopes he sees it.)
  11. mikemcmo
    32
    Evanston, IL
    Are you still out there? Thanks for previous input. Good to have smart people on my side.
    I had the 12V battery replaced today, $215 ka-ching, thanks very much. They said the car sat quietly for 2 hours outside the shop afterwards. Picked it up, got it home, 20 minutes later the alarm went off again. Arrrgh. Went out somewhere and had it parked for an hour, nothing happened. Went into a store for 3 minutes, and it went off again. When I got back home I ran the self-test again twice, on the brand-new battery. The first time it passed, with 12.4V, 12V, and 14.0V. Right afterwards I did it again, and this time it didn't do as well, saying it had 12.3V, and when it should have 12 it said 12 for a flash, but then went right away to 11.9V, and then in the third step it went to 14V. Any ideas? Thanks a lot!
  12. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    Was the new battery charged before they installed it?
    Tom
  13. mikemcmo
    32
    Evanston, IL
    Thanks- great question. I forgot they have to do that. I will call them and look into it.
  14. Patrick Wong
    18,200
    6,490
    Unless you feel like your Prius is a serious theft target, I would be inclined to deactivate the alarm (by disconnecting the alarm horn.)
    I'm not sure how the dealer will be able to help you with that issue, if the alarm doesn't activate when the car is parked there.
  15. OwenTJester
    OwenTJester New Member
    Miami,Sebring,Orlando,Gainsville
    I have had a similar issue with my 07' V. Turns out it was my company's Nextel Radio/Phone that was left in the car it would go about 5 minutes between alarm triggers which is the same interval the Xmobile tracking softwre installed on the phone was set to report/update driver location.
    I have also had it happen when my friend misplaced his personal nextel in my car(no tracking software) and we called it and set the alarm off announcing to me that the phone was in the car.
    Nextels produce some sort of RF interference that trips a sensor in the anti theft.
    I would assume other strong RF signals could do the same.
    You may have some sort of tracking device installed in your car if it is leased.
    Here in Miami just about all new leased vehicles and some financed cars have "LoJack" there are allot of brands most use cellular.
  16. spitinuri
    spitinuri Member
    317
    Did you ever find out what the issue is? I am having the same problem. New Battery and FOB.
