Things We'd Like To See on PHEV Prius
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by M8s, Aug 18, 2010.
  1. M8s
    M8s Retired and Lovin' It
    614
    113
    33
    Colorado and Arizona
    As the PHEV isn't in final form yet and Toyota likes to be responsive to its customers' needs, I thought it would be wise to create a "wish list" of features we'd like to see on the upcoming PHEV. We just finished a 2,550 mile trip and the things we want in our next Prius were on our minds. So, here's my contribution to get the ball rolling.
    (I hope this hasn't been covered before. If so, feel free to delete or combine with the earlier thread.)
    1. Ability to plug-in and leave for 6 or 7 months. We have 2 homes and we'd like to be able to leave a Prius, on a charger of some kind, at each location while we're away. Our 2009s have to be run every few months (at least) to keep the traction battery charged, which means we have to return to Colorado in the bitter cold winter and to Arizona in the blazing hot summer just to charge up the traction battery.
    2. A 30 or 40-mile EV range. IIRC, this is what you get with the Hymotion setup. It would work a lot better for our normal driving pattern.
    3. Regen Available for Entire Battery. It would be a deal killer for me if 2/3s of the battery refused to recharge through regen once that portion was spent. We drive a lot of mountain roads and it seems possible, even likely, that the larger-capacity battery would be spent on the way up but would fully recharge on the long steep downhill sections.
    4. Ability to Select Recharge Mode While Driving. In our mountain driving, we know when we're approaching a long or steep grade (often they're both long and steep). I'd like to be able to choose a mode that tells the engine to work a little harder and really get the battery charged up in preparation for the long steep grade ahead. Often, there are several such uphill grades in a row and too little distance between them to recharge the battery. As it is, I normally have to tackle those mountain passes with a half-full battery (or less) which peters out part way up. Then, the ICE races just to go 55.
    5. Ability to Get Leather for Any Package. I like leather interior and am willing to pay for it. But I don't want to have to buy some expensive options that I don't want just to get leather.
    Feel free to add to the list.
  2. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    Built-in grill blocking
    Built-in scanguage displays
    OP: great points. As to #1, is there no one in either place that could check on things once a month? Drive your car for a day, perhaps.
  3. M8s
    614
    113
    33
    Good additions. I'd especially like to have more info displayed.
    There are a lot of little reasons we don't want someone to drive our Priuses while we're away: we live on the remote edge of town in both places; our AZ neighborhood is a ghost town in the summer; not everyone knows how to operate a Prius; we turn off the power to our garage doors and latch them when we're away; and, we'd have to give someone a key to our homes. No one thing is too bad but, in combination, we just prefer to leave our homes buttoned-up.
    If we could leave a Prius in each place, then my wife could get the convertable she's always wanted and we would just drive it back-and-forth between CO and AZ and we'd still have 2 cars wherever we were. As it is, we drive both Priuses to both places; that's two 841 mile trips two times every year - 3,364 miles total.
  4. Tideland Prius
    16,402
    - adjustable grille opening so that I can use an EBH to pre-heat the engine and not lose all the heat in EV mode
    - Tie PHV programming into navigation system. Allow PHV programming to realise that the destination is close and within EV mode so pre-heat of the engine at 1.x miles won't be necessary
    - LED headlights
    - 3-dr SKS standard on all models
  5. linuxpenguin
    linuxpenguin Active Member
    352
    182
    Follow up question--would you consider an after market conversion to meet your wishlist or are you set on having an OEM solution (yes, I realize the title of the thread is wishlist for Toyota PHV, but still)? The reason I ask is that a bunch of those features may not be available from Toyota for some time unless they really /really/ surprise us all...
    The benefits of an after-market system would seem to be self evident but the ones that stick out would be: no need to buy a new car, ability to select whatever vehicle feature package you want to start with and the ability to customize EV range based on what system you end up buying. I understand people may not want to mess with this as an option but I'm curious to see if you'd even consider it.
    Andrew
  6. M8s
    614
    113
    33
    Interesting question. I'd go for after market as long as it didn't impair the factory warranty. After all, after market leather is a viable option.
  7. mitch672
    mitch672 Technology Geek
    1,077
    197
    Randolph, MA
    I am considering the PICC conversion, as opposed to selling my 2010 Pkg V Prius and buying a Nissan Leaf
  8. sub3marathonman
    sub3marathonman Active Member
    557
    75
    These are my observations at least, hopefully others will add too.
  9. M8s
    614
    113
    33
    I don't think it would be all that hard. The PHEV already has a plug and charger for the traction battery so all Toyota needs to do is add a chip that tells it to run a test once a day and, if the battery SOC is down by some predetermined amount, then top it up. That's what my $60 Deltran Optimates do and I leave cars and a scooter on them for 6 months at a time.
    You may be right, but my list was partly aspirational.
    We don't live "in" the mountains but are surrounded by mountains and regularly drive up and over them. Our most recent trip, through CO, NM, AZ, CA, NV and UT, was almost continuous mountain driving. On the last stretch, from Grand Junction to Denver, we climbed for about 2 hours straight, including two very steep mountain passes (Vail and Loveland) then descended for about 1 hour. It would have been easy to recharge even a larger Lithium battery with regen. Moreover, the number of charge/discharge cycles is reduced if the battery is bigger.
    You haven't driven over Rocky Mountain passes much, have you? Keeping up momentum isn't going to do it when you have a gentle 30 to 100 mile climb (where your battery only gets up to about 50 - 60% charged), followed by an 8-mile long steep climb (battery depleted 1/3 of the way up), followed by a 5 to 10-mile descent (battery gets back to 60%), then followed by another 8 mile long very steep climb (battery depleted 1/4 of the way up). Also, keeping momentum up is impossible if a slow poke semi or motor home pulls out to pass an even slower vehicle. Once you slow down, you can push the gas pedal as hard as you want and never get back up to speed.
    Maybe Toyota should make a "mountin driving option package" available for those of us who have to deal with that kind of driving. OTOH, a selectable "mountain mode" would do just fine for me.
  10. adric22
    adric22 Ev and Hybrid Enthusiast
    642
    145
    Fort Worth, TX
    You realize, you can do a force-charge by pressing the gas and brake at the same time. I think the car has to be stopped. So if you are sitting a light or something before you take on this big hill, then you could force charge.
  11. UTBuckeye
    UTBuckeye Junior Member
    36
    Orange County, CA
    #1) I would love to see some stand alone options, i.e LED headlights
    #2) If they could tie the power from the solar roof into the battery that would be awesome! I know it wouldn't give you a lot of juice, but it would be nice when you don't have access to a plug, and I don't think it would be too difficult, just have a switch that can reroute the power from the fan to the battery. But hey what do I know, I am not an engineer!
  12. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Re: #2 - the current panel is good for <60w in direct sunlight (the roof is not at an optimal angle in most cases to hit this peak). It would require 2.5 days of continuous direct sunlight to recharge the car (assuming 3.6kWh @ 60w)
  13. bisco
    50,804
    i would go for aftermarket, all things being equal, but i don't see much on your chart yet?
  14. UTBuckeye
    36
    Orange County, CA
    Oh, yeah that wouldn't work! I didn't know the exact output of the solar roof hence my comment :D, but I still think my first suggestion would be great.
  15. kev12345
    kev12345 Junior Member
    68
    24
    Vancouver, BC
    a spare tire! i hate the idea of not having a spare...
  16. joe1347
    joe1347 Active Member
    669
    44
    AZ
    How about making it available to purchase?
    To start, just a 5kw-hr Lithium battery plug-in as a stand-alone option. Hopefully, Toyota can keep the additional weight down to not much more than 100 or so pounds similar to the Hymotion plug-in.
  17. rebenson
    rebenson Member
    364
    43
    Suburb of Chicago
    Will it be able to run in pure battery right in the beginning.
    Removable battery pack that could be in doors like when at work or when at home.
    Especially useful in cold / hot weather....
  18. HTMLSpinnr
    5,341
    920
    251
    Unless the battery packs were modularized and each w/ built-in chargers, I don't think removable would be doable due to weight concerns. There's also the issue of contact wear over time (reliability).
  19. web1b
    web1b Active Member
    817
    52
    I'd like to see lower pricing. Maybe the 2nd generation version in 5 years will be priced low enough that plug-in short range (under 50 mile EV range) will be standard in all Prius models by then?
    Maybe in 3 to 5 generations, there will be an affordable all electric with 500 mile range. That will be enough for any daily commute plus even a 200+ mile each way mile day trip.
    Then you only need a second vehicle or rental car if you want to do serious cross country road trips that most people rarely if ever do.
  20. kgurnsey
    kgurnsey New Member
    Ontario, Canada
    If PICC can get 40 miles of EV range, Toyota should be able to.
    I would add remote smartphone connectivity, like the Leaf or Volt, epecially with control over the HVAC. Preheating/cooling the car on grid power is nice.
