Timing
Discussion in 'Gen 2 Prius Technical Discussion' started by Chris11, Mar 6, 2009.
  1. Chris11
    Chris11 Member
    220
    Washington
    I'm trying to understand how the timing works in our Atkinson cycle engine.
    "Normal" engines increase timing when less load (cruising) is encountered and decrease timing when under load. Looking at my new scan gauge I see what appears to be the opposite.
    Can anyone shed some light on this for me?
    Thanks.
  2. Patrick Wong
    18,200
    6,491
    Hi Chris,
    Actually ignition timing generally is a function of engine RPM, where spark advance increases as RPM increases. This is because it takes a finite amount of time for the spark to ignite the fuel/air mixture. As the pistons move up & down faster, the spark must ignite sooner so that an explosion happens as the piston reaches top-dead-center. Prius basically operates the same way.
    Knocking happens when the explosion happens before the piston reaches TDC and shows timing is too advanced. If timing is retarded then power output is reduced since the explosion happens as the piston already is descending from TDC.
  3. magruder
    magruder Average Member
    145
    Colorado
    I wonder how variable valve timing plays into that?
  4. Patrick Wong
    18,200
    6,491
    Please see the first document which is an excerpt from the 2001 New Car Features Manual. The intake valve side is variable, and the last two pages of the excerpt show the conditions under which timing is retarded and advanced.
    2G uses a similar concept although the amount of variability was reduced (see the second document). This reduction means less exhaust gas residue that will accumulate in the throttle body interior and on the throttle plate.
  5. Chris11
    Chris11 Member
    220
    Washington
    Hi Patrick.
    Harkening back to the distributor years (yes, I remember them...:D) and the vacuum advance portion, I have always thought that under low load (high vacuum) the timing was advanced and when going up a hill with low vacuum the timing was retarded. Apparently I had it backwards.
    Thank you for the course in timing 101.
  6. Patrick Wong
    18,200
    6,491
    Hi Chris,
    You are right about the vacuum advance portion of the distributor mechanism; but recall that the distributor also has a centrifugal advance which will advance timing based upon the speed at which the distributor shaft is rotating. And the distributor shaft speed is a direct function of engine RPM.
    This mechanical/vacuum system did not work very precisely. Hence the invention of computerized engine controls to specify correct ignition timing based upon engine RPM and load.
