Tire Pressure for the First Gen Prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by tntna, Dec 3, 2004.
  1. tntna
    tntna New Member
    131
    Central OH
    I've been reading a lot about increasing the tire pressure to 42/40 for optimal MPG. Is this true for the 2001 model as well? I've been following the recommended pressure in the manual for years. I'd like to be able to remember one set of numbers. I think they use the same tire so I would imagine same pressure would be fine.
  2. john1701a
    john1701a Prius Guru
    12,793
    5,275
    57
    Yes, the Classic (2001-2003) will benefit from increased tire-pressure.
    Higher PSI will provide higher MPG, reduced wear, and better handling. The catch is road noise will increase and you'll feel bumps in the road more (which actually could be considered a benefit when driving on snow).
    And I used 44/42 on my Classic. So you have a choice of how much to increase.
  3. tntna
    tntna New Member
    131
    Central OH
    Hey thanks John. Wish I would have found this site years ago. :)
