Tire Pressure Monitor, how does it work? (absolute or relative)
Discussion in 'Prius v Main Forum' started by wstt, Jul 24, 2013.
  1. wstt
    wstt Member
    147
    22
    Does anyone know how the tire pressure monitoring system works?
    Does it trigger at an absolute (actual) pressure level when it drops below it, or does it do a relative pressure level so if one tire is much less than the others it triggers the warning?
    I assume there is no way to access these pressure readings even if you can enter the car into diagnostic mode, correct?
    If it is an absolute level that triggers it, like 25psi, is there a way to adjust the level which triggers it? (I have my tires at 40psi, and 39psi and I don't want to wait until the tire gets to 25psi before the warning light comes on.)
  2. Air_Boss
    Air_Boss Senior Member
    4,126
    1,148
    New Yawk
    In my experience, it triggers in a range of a 5-7% variation across tires, i.e. ~2-3 psi on ~40 psi nominal.
  3. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    On previous Toyota vehicles I've had it was triggering at about 5# under the initial setting. So if any one tire dropped 5# it would trigger.
  4. wstt
    wstt Member
    147
    22
    What do you mean by "initial setting"? Is that the setting when Toyota first inflated the tires or when the sensors were put on? The setting when I last inflated the tires and then turned the car on? (I inflated them a little too much and then released some air before I started the car so I would think it could not pick up the higher values.)
  5. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    This is all in the manual. So you should read it to find where the reset switch is in your "v".
  6. wstt
    wstt Member
    147
    22
    Thanks. Somehow I missed it in the manual because I thought I looked at it. I looked at the manual online though via Toyota's website which isn't one PDF but sections that jump all around.
    Thanks,
  7. rdgrimes
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    There's a button under the dash, next to the button that turns off collision avoidance system. That button re-sets the tire monitor for the current pressures, press and hold till you get a flashing indicator on the dash. The spare is not included.
    xpcman likes this.
  8. syscon
    syscon Member
    329
    43
    Edm. Alberta
    If I'm not mistaken those tire pressure sensors (inside tires) they run on a battery, isn't it?
    How long do the battery last? I think the battery can not be replaced the sensor need to be replaced.
  9. xpcman
    1,302
    295
    Right - the battery can NOT be replaced. It would cost hundreds to replace them and then reprogram the car.
    Has anyone needed to replace them yet? I have read they last 6 to 9 years.
  10. rdgrimes
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    The general rule is to replace them when you replace the tires, but the only thing happens when one goes out is your alert comes on.
  11. Air_Boss
    4,126
    1,148
    New Yawk
    I have a low/annoyance-level leaky sensor that the dealership agreed to replace under the sensors' 3yr/36k warranty.
  12. harold
    harold Member
    227
    36
    SoFla
    2013 Prius v wagon
    Does the TPM only come with the ATP or does my v Five have it too?
  13. Air_Boss
    4,126
    1,148
    New Yawk
    We have TPMS on our v Five without ATP, so I would say, yes.
  14. harold
    harold Member
    227
    36
    SoFla
    2013 Prius v wagon
    I read the manual, says there's a screen that you can select , I don't get that screen?
  15. Air_Boss
    4,126
    1,148
    New Yawk
    We (2012 v Five) have no screen, no ability to determine which corner is at issue.
  16. harold
    harold Member
    227
    36
    SoFla
    2013 Prius v wagon
    Is there any sort of TPM in our cars, v Five(2013) ?
