Tire size and mpg
Discussion in 'Gen 2 Prius Main Forum' started by noname87, May 12, 2010.
  1. noname87
    noname87 Junior Member
    84
    NC
    I am looking at getting new tires. I notice that the 195/65 size is cheaper than the 185/65 for the same model. Any reason not to pick the 195 size. Will the mpg be effect that much?
  2. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    195/65 is a wider and taller tire. it may drop your mpg by 2 or 3 at most.
    as long as you don't break the 205 region... then you should be OK mpg wise... with my tires i get mid to high 30's.. sometimes low 40's.... it's really about having a great car, to me, over getting mpg. (comfort, accessories, gear-less, etc)
  3. uart
    uart Senior Member
    4,220
    1,209
    Australia
    If you want to go 195 then get 195/60 as the speedo and odo will be more accurate than with 195/65.
