Tire Weight Important?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by SuperchargedMR2, Mar 27, 2012.
  1. SuperchargedMR2
    SuperchargedMR2 Diehard Rams Fan
    673
    179
    Vancouver, WA
    We talk a lot about wheel weight but nobody says anything about tire weight. Is it important also is respect to MPG? I've been looking at tire weight a lot & I see a big difference. I was looking at a 205/55R16 size. The Goodyear Fuel Max seems to be the lightest at 18 lbs while the Yokohama Ascend & several Michelin tires seem to be around 22-23 lbs each. To me 4-5 lbs of unsprung weight is a lot to be able to save. What do you all think?
  2. tumbleweed
    tumbleweed Senior Member
    4,067
    690
    Eastern Oregon
    I agree, tire weight is at least as important as wheel weight. I think it could be argued that it may be more important since the tires mass is further from the center of rotation and therefore has a higher radial velocity.
  3. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    You're overemphasizing unsprung weight with respect to mpg. Less of it will help with acceleration/deceleration though.
  4. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    This one always messes with me. Generally speaking any extra weight is bad. It's worse for stop and go driving but it is not good for steady state driving either.
    On the other hand, the Prius Five 17" wheels are almost 10lbs heavier than the 15" wheels and the tires are approx. 3-4lbs heavier yet some claim they don't suffer mpg losses or that the loss is very minor at less than 2mpg.
    The weight on the AVID Ascend is pretty insane partially due to its 12/32 tread depth as is the weight on tires like the Primacy MXV4. I decided to try the Ascend to see how the weight would affect my mpg but so far they seem pretty comparable to the OE AVID S33D. So I'm not really sure what to think anymore. lol
    In general I would still recommend finding the lightest wheel you like and can afford. The tire weight is less important because there are other characteristics you must consider so that you choose the right one for you needs. I would not choose a tire just because it is the lightest.
  5. Former Member 68813
    3,524
    983
    US
    in my experience, tire weight is correlated with rolling resistance.
    the weight difference is usually in the thickness of sidewall (even though thickness of thread.plays a role too).
    the thicker the sidewall, the higher resistance to flexing, adding a lot to total rolling resistance.
  6. SuperchargedMR2
    673
    179
    Vancouver, WA
    I agree about not picking the lightest tire just on weight. I was looking at only LRR tires so that MPG could remain high. I've been looking at 205/55R16 in these tires which I believe to all be decent LRR tires....
    Goodyear Fuel Max 18 lbs.
    Bridgestone Ectopia EP422 19 lbs.
    Hankook Optima H426 19 lbs.
    Continental ProContact Eco+ 21 lbs.
    Michelin Defender 22 lbs.
    Michelin MXM4 22 lbs.
    Yokohama Ascend 23 lbs.
    Michelin Hydroedge 23 lbs.
    So which is best for MPG? I'm not worried about longevity as I enjoy buying & trying new tires every 3-5 years anyway. :D
  7. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    If you don't care about closeout models then get the Ecopia EP100. It will likely have the best mpg of any tire except the Energy Saver A/S. :)
    The rest of the ones you listed are all probably about the same. Maybe the Fuel Max or EP422 being the next highest?
  8. SoCalBPrius
    SoCalBPrius Active Member
    563
    118
    SoCal
    Is the Continental ProContact Eco different from DWS?
  9. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    Yes, quite a bit different but it doesn't come in the larger sizes. It is a low priced, long-wearing (80,000 mile warranty), LRR tire that performs well, especially in the wet.
  10. yeldogt
    yeldogt Active Member
    810
    313
    NE
    The unsprung mass -- the tire and the wheel weight being only one part - have the biggest influence on the suspension dynamics.
    This is a Prius
    The mass of the vehicle is not changing very much and the suspension dynamics are not maximized on the Prius anyway.
    Without getting into why some tires are heavier then others -- and how this is distributed ...... I would get the best tire for the car ... and forget about the weight.
