Tires: 215/65/15
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Nightk81c, Mar 8, 2010.
  1. Nightk81c
    Nightk81c New Member
    Frisco TX
    Will 215/65/15 fit with the stock rims? Anyone have tires more than 195 on their prius?
  2. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    205/60/15's work OK 215/55/15's might work.
  3. cossie1600
    cossie1600 Active Member
    899
    92
    CT
    You are probably going to rub on 215/65, that's like a minivan size tire
  4. Joe166
    Joe166 New Member
    720
    97
    South Florida
    I don't know if they will fit on the standard wheels. That is a function of the width of the rim and I have no idea what that is. Maybe you should ask some experts, like at Tire Rack or Discount Tires. I have always found the guys at their 800 number pretty knowledgeable and friendly.
    As far as rubbing in the tire well, I kind of doubt that will be a problem. The V doesn't have any different tire wells and it has a much larger wheel and tire. I sure wouldn't guarantee it, though. Let us know how it works out.
  5. cossie1600
    899
    92
    CT
    The tire is nearly 13" larger in diameter, I will put a bet that the rubber liner will come off soon.
  6. Joe166
    Joe166 New Member
    720
    97
    South Florida
    What are you talking about? The diameter of the stock 195-65-15 tire is 25.0 inches and the diameter of the 215-65-15 tire is 26.0 inches.
    That looks like one inch to me.
    Your speedo will read a couple of miles per hour slow, though.
    There is a very simple tire size calculator at miata net: Tire size calculator
    Try it.
  7. cossie1600
    899
    92
    CT
    13mm I meant to say sorry, not ".
  8. Joe166
    Joe166 New Member
    720
    97
    South Florida
    Unless someone is giving you that particular size, the usual formula is to add one size in the first column and subtract one size in the middle. To do it right, go to the Miata site I linked in the prior post and look for the size that most closely approximates the diameter of the OEM tires so that your speedometer stays reasonably accurate. It should also be fairly easy to fit in the wheel well if it is close in size.
  9. mmichaell
    mmichaell Member
    241
    chicago
    Side comment: I've been using that tire size calculator on miata.net since '99. Very handy.
  10. yamisoshi
    yamisoshi Junior Member
    64
    Meridian, ID
    You can use the Tire Size online tools or simply use this formula ...
    215 x .65 / 10 / 2.54 x 2 + 15 = 26" wheel/tire diameter :D
