Tires - Yokohama YK520?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by bubba_steel, Jun 16, 2010.
  1. bubba_steel
    bubba_steel New Member
    Hi all. I have a 2007 Prius and it's time to get new tires. After reading through all the posts, I decided on the Michelin HydroEdge tires. I went down to the tire store this afternoon, and I was told that those tires are on back-order. (Not just at their stores, but from Michelin.) The guy recommended that I consider the Yokohama YK520 since I live in S. California and weather is not a big issue. Just wondering if anyone had these on their Prius and what their thoughts were. (I've only found reviews of this tire on other vehicles.) Are their any other tires that I should consider? Thanks!
  2. silentak1
    silentak1 Since 2005
    893
    28
    LA
    I installed those for a friend's Accord many many years ago without doing enough research... not a great tire, comparable to the Goodyear Integrities. Dry grip is "ok", maybe even below ok if you like to drive spiritedly; I could easily make the car track "sideways" with a nice jolt at medium speeds, yep that crappy. Wet traction is even worse. Noise levels are fine, life was pretty good, but the thread actually looked pretty dried up after 2 years and 30,000 miles and the tire manufacture date was within a few months from the installation day. PSI was always kept in check.
    I would not recommend this tire, but sure is better than Barum, Arizona, Nexen, Visa, and other crap tires.
    I do like Yokohama tires though, what else is available? Tirerack.com can also give you tons of reviews.
  3. JimboPalmer
    12,470
    6,875
    Greenwood MS USA
  4. bubba_steel
    Thanks for the quick reply guys! After reading more reviews this afternoon, I think I'm gonna give the GY Assurance Fuel Max a try.
  5. JimboPalmer
    12,470
    6,875
    Greenwood MS USA
