To burn or not to burn
Discussion in 'Gen 2 Prius Technical Discussion' started by PoulStaugaard, Jun 22, 2008.
  1. PoulStaugaard
    PoulStaugaard Now a PriusOwner
    95
    Copenhagen, Denmark
    The reasoning of the drive control computer still puzzles me :confused:. One minute, it will shut down the engine as soon as I lift off. The next minute, it will refuse to shut down until it has been sitting still for 4-5 seconds. It is not simply a matter of whether I run the A/C, nor is it seemingly related to the state of charge: Often it will happlily shut down the engine even though it has only 3 bars, at other times, it will run the engine until has charged itself (sometimes) up to green bars. The result of this behaviour is also apparent on the consumption bar graph, which will sometimes vary unpredictably between 35-40 km/l and 20 km/l. At other times, it will show a more steady 25-30 km/l.
    Is this normal behaviour or is it a sign of malfunction? The car is only 5 months & 4000 miles old.
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    This is normal behavior. The control algorithm is complex. It factors in load, temperature, idle check, speed, SOC, and probably a few other factors. Until you spend a lot of time with it, it's hard to guess what it will do when, and under what circumstances.
    Tom
  3. patsparks
    10,664
    567
    Adelaide South Australia
    I agree with Tom. Often the ICE will run to warm the coolant or cat converter, sometimes to charge the battery. When it runs until you stop then shuts down that isn't a bad thing, that is the HSD switching to it's best level of operation.
  4. PoulStaugaard
    95
    Copenhagen, Denmark
    I'm sure it has it's reasons, I just wish it would explain them better. Sometimes when it seems it must have run the engine long enough and it still doesn't shut down as I'm slowing to a halt, I will hit the EV button. It will take my advice allright, but if I then switch out of EV mode while at a halt, it will start the engine, run it for 5 seconds, then shut it down. That seems to me like plain stubbornness. It can't be that the cat or the coolant needs heating, I shouldn't think, and the state of charge is reported as just right, so why...?
  5. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    This will describe the "what" and "when" of many of the behaviors you're seeing, though the "why" for some of them, like that 5+ second ICE-on idle routine, remains a mystery to all but (apparently) Toyota engineers.
  6. Bob64
    1,540
    93
    Virginia
    Answer: depends mainly on your engine coolant temp.
    If your below 70c, it'll shutoff readily. If your above 70c for the FIRST time and stopping, it will "wait" for 5 seconds before shutting off - which is the signal that you've entered stage 4 mode, which will enable the engine to shutoff while moving.
  7. richard schumacher
    7,664
    1,042
    United States
    Unless you want to get deep into the arcana of hypermiling theory it's probably best to let the car manage itself, and use the EV button only at low speed at either end of a given trip (e.g., while leaving and entering your garage).
