To those with an EBH installed
Discussion in 'Gen 2 Prius Technical Discussion' started by treehggr, Aug 21, 2007.
  1. treehggr
    treehggr New Member
    230
    Hello,
    I just had my EBH installed by Wayne yesterday evening and used it for the first time this morning. I have it set for a 3hr heat up and I didn't really notice a difference in my first 5 min bar. When starting my car this morning I was on 2 purple bars and ended up being able to start my glide in the same place before using the EBH. Would I have been better off starting out with more of a charge, say 3-4 blue bars? I read through many posts and was not able to find the answer I was looking for. Any help or guidance would be great.
    Edit:
    This morning when I went out to my garage I started up my car and unplugged my EBH. My scangauge gave me a coolant reading of 160 degrees. I waited about 15 seconds till the engine shut off and backed out my driveway to find that I was able to glide at any speed right off the bat. I was pretty surprised that S4 came so early. My commute to work is 9 miles each way and I was able to grab a photo with my phone when I got to work. It looks like I was able to acheive a 50-52 mpg first 5 min bar. I'm pretty happy with the results and want to thank Wayne for installing this bad boy and all of you for the help. And how do you like that, 86 degrees out already at 5:21 am. The desert sucks.
    [attachmentid=10822]
  2. tekn0wledg
    tekn0wledg New Member
    136
    My guess is it was related to the SOC of your battery. When you start your engine you have a tendency to use the battery during S1-S3. When you got to S4, you likely didn't have at least 5-6 bars, and thus you were not able to glide just yet.
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    I can usually P&G within 1/4 mile. And yea, I'd give it a little time, I suspect the low SOC was part of the problem for you this time around.
  4. treehggr
    treehggr New Member
    230
    Good to hear. I guess thats the reason for the ICE running as usual this morning. The ICE stops charging the battery at 3 bars or 4?
  5. efusco
    19,891
    1,194
    Nixa, MO
    <div class='quotetop'>QUOTE(treehggr @ Aug 21 2007, 09:19 AM) [snapback]499715[/snapback]</div>
    Depends, sometimes just with 2 bars, it depends upon whether you're stopped, accelerating, steady state, etc.
    Just remember, go very gentle for the first 30-45 seconds after entering Ready mode when using the EBH to minimize battery drain while the car works through S1...as soon as you're in S2 you should be able to P&G...just remember you'll need to get over 35mph before you can glide unless you come to a complete stop and let the ICE shut down on it's own to get into S4. Once in S4 you should be able to get into a glide from any speed below 41mph.
  6. gazz
    gazz Member
    216
    Coventry, UK
    <div class='quotetop'>QUOTE(treehggr @ Aug 21 2007, 09:12 AM) [snapback]499711[/snapback]</div>
    To give you an idea if I heat it for 2 hrs and the outside temp is about 15C it will heat it to about 35C. The car will glide at 40C so it take about a hundred yards to reach. It is summer in the UK so how it will perform in the winter will be interesting to see. I use a ScangaugeII to see the engine temp.
    You will need a reasonable SOC. 3 bars plus
  7. treehggr
    treehggr New Member
    230
    Ok, I have one stop sign in my housing plan about 500 yds from my driveway then I travel about 1/4 mile until I hit the main road. Would it be beneficial to sit at that 1st stop sign for a few seconds to let the ICE shut down then start my glide at a lower speed? Or do you think that is too early for me to be able to enter S4?
  8. efusco
    19,891
    1,194
    Nixa, MO
    <div class='quotetop'>QUOTE(treehggr @ Aug 21 2007, 09:57 AM) [snapback]499742[/snapback]</div>
    Yes I think it would be benefitial to wait at that first stop sign. It's probably not too early to enter S4 if your operating temp is over 150 at that stop....in the dead of winter it might be too soon, but most of the year it should be fine.
  9. treehggr
    treehggr New Member
    230
    <div class='quotetop'>QUOTE(efusco @ Aug 21 2007, 08:14 AM) [snapback]499748[/snapback]</div>
    Awesome thanks. Yeah if I can get that low speed gliding in early (speed limit 25) that would be great.
    Thanks for all the help guys.
  10. bwilson4web
    15,934
    I have noticed that with the block heater, after getting to S3/S4, it is best to get a little time, 1-2 miles, above 42 mph to put a charge on the battery and then drop back to the below 42 mph route. The battery charge doesn't cost much fuel, the ICE is pretty efficient at ~50 mph, and afterwards, I can let the hybrid control laws handle cycling between ICE and EV with excellent MPG.
  11. MSantos
    MSantos EcoAccelerometry
    585
    256
    Canada, Winnipeg
    2024 Prius Prime
    XSE Premium
    <div class='quotetop'>QUOTE(gazz @ Aug 21 2007, 08:43 AM) [snapback]499735[/snapback]</div>
    That is very interesting.
    I cannot get into a glide until the engine reaches 50C (122F) and the Air intake temp is at 25C or higher. I too use a ScanGauge II to read the temp values.
    Cheers;
    MSantos
  12. treehggr
    treehggr New Member
    230
    Well I parked the car this evening with a SOC of 4 bars. I'm going to sit at that stop sight till the ICE shuts off tomorrow morning to see if in fact that will put me into S4. If so this will be a dramatic improvement over not using an EBH. I'll post tomorrow with the results. Thanks again for the input.
  13. philmcneal
    philmcneal Taxi!
    332
    Simcoe Ontario
    <div class='quotetop'>QUOTE(treehggr @ Aug 21 2007, 05:20 PM) [snapback]500026[/snapback]</div>
    try this with the engine block heater installed:
    start car, let it run the engine in park (i recommend with parking brake if you want to save 140 watts and not turn on the DRL)
    as that's happening unplug your EBH, by the time you get into your car the car should be in S3 mode (since your coolant should be around 50 degrees C unless you plugged after a hot start)
    NOW someone ask me (uh isn't it stupid to let the engine idle while not moving? your getting 0 miles to the gallon or 0 km/L) but the problem is, when the engine starts up the first time, it uses most of its energy from the battery because the engine has to "do its thing" before it can provide any motion power to the wheels, by the time the engine is done you have used a lot of juice from the battery already (unless you went really slow like 20 km/h) its time for payback aka CONVERSION LOSSES IS A BIG NO NO. But as soon as you hear the engine die in P for the first time, take heart your engine will provide motion power! For those without a EBH this idling time is increased, but for users with its only a mere 20-30 seconds or less even on hot days.
    pulse (use engine when most efficent)
    glide (hit the ev mode switch but keep it below 54 km/h or else you will be forced to glide with the engine on until you get back down to 54 km/h again.)
    when engine coolant surpasses 70 degrees C you may begin to pulse and glide at higher speed intervals (64km/h tops instead of 54 km/h tops) since after 56 km/h letting off the gas pedal goes into "stealth" mode or "temporarly EV mode until you press the gas pedal too hard, although i find interesting in pure EV MODE that gas press needs to be harder!"
    just use the engine when its most efficent ( for NHW20 i find between 1500 rpms and 2300 rpms, keep SOC above 55% to avoid conversion losses (engine power to battery power is a NO NO, try to focus engine power to the wheels at all times and leave the charging to the slowing down to a stop or hills).
  14. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    When you start your Prius in the morning, try not to use the accelerator, just let the car coast to the first stop light, it will do so at about 1280 RPM/1312RPM. If you can, stay on the gas as little as possible, but keep the ICE going, until you hit that main road (whatever the heck the name is). When you stop at the main road you should feel the auto stop into stage 4, your SOC should be up and you can glide.
    And remember, if you want into the 70's (MPG) stay out of that battery.
    Wayne
  15. Tideland Prius
    16,403
    Except that if you're in the garage, you don't want the engine to run and pollute it...
  16. gazz
    gazz Member
    216
    Coventry, UK
    <div class='quotetop'>QUOTE(MSantos @ Aug 21 2007, 02:31 PM) [snapback]499877[/snapback]</div>
    I can defiantly get into glide at 40C, the only thing is that it seems to need a certain time, so if you use a block heater that gets it to nearly 40C it seems to need a few hundred yards of driving. I find getting the block heater to heat to about 30-35C seems to give the engine the time to settle down and then glide at 40.
