tower brace
Discussion in 'Prius c Main Forum' started by fgp, Apr 11, 2012.
  1. fgp
    fgp Active Member
    503
    169
    daytona
    2023 Prius
    just ordered the strut crossbar reinforcer from cusco. i think im the first to do so. my plan (at this point is to order most of the suspension upgrades. between now and then i hope there will be like a coilover upgrade that will give me a good ride without shaking me crazy. stifeness is fine but so is a good ride. all comments welcome
  2. SquallLHeart
    SquallLHeart The Techie Guy
    826
    247
    San Jose, CA
    i'm gonna wait until other options are available. :p
  3. fgp
    fgp Active Member
    503
    169
    daytona
    2023 Prius
    oh oh squall , you normally have a good reasons behind your comments. i love stiffness and i think ill continue, but i also feel that there will be a high end upgrade of coilover available. what do you think
  4. SquallLHeart
    826
    247
    San Jose, CA
    i'm hoping coilovers are going to be made.. but most aftermarket companies take a few months for them to develop and catch up. i don't know what else is going to be planned at the moment.. but i'm in talks with Tanabe right now.
  5. fgp
    fgp Active Member
    503
    169
    daytona
    2023 Prius
    i did notice a coil over available but it was almost $1700 which is way more than i want to take a chance on. especially when you cant test ride it
  6. formula
    formula Member
    320
    32
    CA
    that are pricey for me. lol I will wait for more options.
  7. SquallLHeart
    826
    247
    San Jose, CA
    any good coilover set is going to cost at least $1K.. but should be less than $2K typically.. $1.7K doesn’t sound too bad.. but like I mentioned.. it's best to wait for more options to pop up.
    when there's only one or two available.. this early on.. you have to ask yourself if that company rushed thru development to just be able to release their products first..
  8. Mike500
    Mike500 Senior Member
    2,593
    766
    Over the past 40 years, I've seen all sorts of kits like these.
    To make them easy to install, they cone with enlarged holes, slots and shims.
    You'll NEVER see these in the aircraft industry.
    All parts need to be expertly fitted without undue stress. It takes a lot of extra work, but it's worth it.
  9. priusCpilot
    priusCpilot Active Member
    663
    210
    LA
    Can't wait to see some shots of it up close. Since its aluminum it should be light. If you can I would love to know how much it weights. Cusco makes some very quality items. Im sure this will be nice when you get it.
  10. fgp
    fgp Active Member
    503
    169
    daytona
    2023 Prius
    well, i talked to cusco today. they said the brace is actually coming from japan and that it will not reach us for almost another month. so i wont see it until almost the 1st of june. disappointing, but so it goes. :(
  11. kkim
    kkim Active Member
    386
    132
    kauai, hawaii
