Towing and Now ABS & Brake Lights on Dash
Discussion in 'Gen 2 Prius Technical Discussion' started by bear15, Nov 1, 2011.
  1. bear15
    bear15 Member
    168
    35
    Suburban Chicago
    Today I used a tow dolley (two front wheels off the ground) to tow our 07 prius approx. 4 miles. I put the car in neutral as the manual specifies and followed all other directions. During the tow, I never traveled more than 25 mph.
    Now the ABS & Brake warning Lights are on in the Dash.
    I checked for codes, but it does not show any in my instrument tool, so there are not any code to re-set.
    Any help would be appreciated.
    Ed
  2. jdenenberg
    jdenenberg EE Professor
    3,914
    1,914
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Try disconnecting the negative 12v cable from the little aux battery (goes to the body) for a couple of minutes to reset codes and see if they clear.
    Your code reader can only see a subset of the codes from the many ECUs
    JeffD
  3. bear15
    bear15 Member
    168
    35
    Suburban Chicago
    I will give it a try tomorrow.
    Thanks, Ed
  4. bear15
    bear15 Member
    168
    35
    Suburban Chicago
    I tried disconnecting the 12v battery, but it did not solve the problem.
    The problem, however, is now solved!
    After approx. 2 miles of driving it to the dealer to look at, the warning lights went out. The dealer confirmed that we are good to go.
    Thanks, Ed
  5. Britprius
    Britprius Senior Member
    5,194
    1,918
    Herefordshire England
    Why is there a need to put the car in neutral with the front wheels off the ground on a tow dolly, surely all that is required is that the parking brake is released to allow the rear wheels to rotate and with the vehicle not made ready no codes will be thrown. Or am I missing something?
  6. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Good question, I wanna know also!!!:D
  7. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,515
    38
    Santa Fe, NM
    I don't see anywhere in the manual where is says put the car in neutral. I do see they have a legitimate concern that the steering lock mechanism can be trashed if towing with only the front wheels raised and the car turned off. So,
    0. Do not tow Ig-On if possible, because the 12V will die.
    1. If towing with all four wheels on the ground, the car must be in Ready, Neutral, and must be towed forward only.
    2. If towing with the front wheels off the ground, the car should be in Ready, Park, with the parking brake off. Using the old fashioned sling type tow truck (don't see those anymore) will destroy the front bumper.
    3. Towing on a flatbed is preferred.
  8. Britprius
    5,194
    1,918
    There is no steering lock on a gen2 Prius and why should it be in ready.
