Toyota Letter Confirming Use of 5W30 oil ?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by jdcollins5, Apr 8, 2010.
  1. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,342
    Wilmington, NC
    Has anyone received a letter from Toyota confirming the use of 5W30 oil in the 2010 Prius and stating that this letter overrides the Owner's Manual ?
    I just returned from my 10K service at my dealership. When the Service Advisor handed me the service report I immediately noticed that they had used 5W30 oil. When I showed this to the advisor, he asked me if I had received the letter from Toyota confirming the use of 5W30 oil. He said that the advisor's had been instructed to begin using 5W30 oil in 2010 Prius' unless the customer specifically asked for the 0W20 synthetic oil. He said that Toyota had so many complaints about the high cost of synthetic oil that they were in the process of sending out letters confirming that 5W30 oil was acceptable for use.
    Is this a fact or BS from an advisor caught by the customer?
    He did take me to the technician to see what was actually used. The technician acknowledged that he had used 5W30 and when questioned by the advisor he said that he put in what was listed in the service request. The advisor instructed the technician to drain and refill with 0W20 oil. He also said that he would note this in the computer so that from now on, it would be noted that I instructed only the use of 0W20.
    On another note, I did number the tires on the car and verified that these had been rotated properly. When I checked the pressure at home, after time to cool down, all four tires were at 47 psi !!! I had them at 42/40 and lowered them back to this pressure.
    So, I have to add my name to the list of disappointed people with their dealership service. My first experience at 5K was very good and this same advisor noted when asked that they were well aware of Toyota's recommendation of 0W20 synthetic oil for my Prius and assured me that this would be the only thing used.
    The thing that disappoints me the most is that this is right on the heels of all the latest media articles on Toyota's lack of attention to their customers. If Toyota is indeed in the process of issuing such a letter on the use of 5W30, then this is just another example of the disconnect between corporate Toyota and their dealerships. I would much prefer this to be just one example of an advisor caught in a blatant error and covering his rear end.
  2. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    My BS detector is going off big time!
  3. vinnie97
    vinnie97 Whatever Works
    1,430
    277
    Somewhere out there
    Mine came off the lot with 5W30 (according to the oil change sticker), so it wouldn't surprise me if there is some truth to this. I'm at 550 miles. Should I demand 0W20?
  4. jdcollins5
    5,131
    1,342
    Wilmington, NC
    From what I have read and understand from this forum, the 0W20 synthetic oil is the preferred for the best gas mileage and by the Toyota Owner's Manual. I will have to let some of the experts chime in here with the technical reasonings for 0W20 over 5W30.
  5. vinnie97
    1,430
    277
    Somewhere out there
    I only assume 5W30 was used as that is the grade listed for the next recommended oil change...I'm not sure where the vehicles are initially filled with oil so I can't be 100% sure it's not 0W20 that was used but it seems unlikely.
  6. leeb18c
    leeb18c Active Member
    272
    202
    SF Bay Area
    I had my oil change 2 weeks ago at the dealer using the free coupon i got during purchase. I forgot to tell the service adviser to use 0w20 but when i check the receipt it say "0w20 synthetic 5qt" was used. But the next oil change on the sticker say next 5k miles, not 10k. So i don't know, it's just another shop. You just have to keep an eye on everything.
  7. JimboPalmer
    12,470
    6,875
    Greenwood MS USA
    Sigh. No one hurts Toyota's credibility more than (some) Toyota dealers.
    (You wonder why did Toyota have so much difficulty deciding to up the OCI to 10,000 miles in 2010 MY Toyotas, until you read Threads like this)
    If you intend to change the oil at 10,000 mile intervals, only use 0w20 full synthetic. (if you are low on oil in the middle of nowhere you can use a quart of 5w20 to get you back to civilization)
    Most owners have multiple choices to do oil changes, never return to a shop that does not use the correct parts and fluids. While it would be fun to shame the bad dealers, I think Priuschat would have to spend too many dollars winning slander and libel suits. (Truth is always a winning defense)
    The Toyota website can locate alternative dealerships, the cartalk website can help find independent shops.
    Toyota Dealer Locator Search - Find Toyota Dealer
    Car Talk. Car tips, advice, and troubleshooting. | Mechanics Files
    If they are only in it for the money, you can only hurt them by not spending any there.
    (Vinnie I am unclear what you are claiming, it says you have an other non-hybrid, but you seem to be claiming to be mis-serviced by some dealer, presumably Toyota?)
  8. vinnie97
    1,430
    277
    Somewhere out there
    Sorry, I haven't updated the profile and I need to do so. I haven't been hurt, I'm just not clear on the regularity (or lack thereof) of 5W30 being used on new vehicles. The sticker recommends a change in 5000 miles and 5W30 is listed as the grade.
  9. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    Dealer installed oil change sticker? Ignore that and go with what the manufacturer recommends, 0W20 every 10k.
    They're all filled with 0W20 at the factory. I can't imagine your dealer or anyone else taking the liberty of draining it and replacing with 5W30.
  10. vinnie97
    1,430
    277
    Somewhere out there
    That doesn't make sense to me either (the car had 32 miles total mileage when I left the lot)...most likely it's just the dealer recommended viscosity at 5K miles/6 months. I think I'll go ahead and get the first change at 5K in any case, ensuring they fill up with 0W20 at that point in time.
  11. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    I thought the temporary replacement oil for 0w20 was 5w20, not 5w30.
  12. JimboPalmer
    12,470
    6,875
    Greenwood MS USA
    Thank you, it makes much more sense once I know what car we are talking about! I disliked the hurt wording and edited it quick once I read my own post. Once I write it, I can critique it.
    Several (10?) 2010 Toyota models recommend 0w20 full synthetic oil*, Toyota recently extended the service interval for them to 10,000 miles. The 2010 Prius is one of them, insist your dealer use 0w20. Toyota is going to try to weasel out of warranty claims if the dealer insists on some other oil.
    *if you are a quart low in Timbuktu, you can add a quart of 5w20, but then get the oil changed back to 0w20.
  13. Fstr911
    Fstr911 Member
    235
    55
    About the tire pressure. In my experience calibration and accuracy is not often checked on tire pressure gauges.
    Poor eyesight and tires baked by the sun also play a role.
    Not picking on you or them, but just offering some things to consider.
  14. Joe166
    Joe166 New Member
    720
    97
    South Florida
    I think you are giving them far more credit than they deserve. It is more likely that the top notch technician who was changing the oil (you know they put their very best mechanics, those with an intuitive feel for vehicles and vast amounts of experience), didn't bother to look it up and did it while in cruise control.
  15. toyolover
    toyolover Member
    441
    67
    toronto, canada
    Read from another forum that the Prius US manual specifies the use of 0w20 while Canadian manual says "use of 0w20 preferred but if it is not available, the use of 5w20 is also acceptable". I had my first oil change two weeks ago at the dealer. I specifically requested in writing the use of 0w20 but they still put 5w20 in it. When I asked them, they told me they didn't have the 0w20 in stock and so they put 5w20 instead (without my approval)! So be very specific about what you ask for and check your invoice before you leave the service department.
  16. vinnie97
    1,430
    277
    Somewhere out there
    Well, to be fair, I don't understand why a vehicle with only 32 miles needed an oil change. Maybe it was just a preprinted tag they had available for new cars on the lot. ;)
  17. timo27
    timo27 Member
    316
    52
    Baltimore, MD
    Sigh again. It would be so nice to locate a Toyota dealership that can find their a$$ with both hands. I need to get the cargo net fix done, and must get the brake recall, and would like to get them done on the same trip. When I call, they invariably say they have to inspect the cargo net for peeling off before they can order the kit--wouldn't they have them in stock? I've dealt with Honda, Acura, VW, SAAB, and GM dealerships who do not have institutionalized contempt for their clients. Very frustrating. The Prius is the only Toyota I'd consider, and I doubt I'll ever buy another Toyota until and unnless they clean up their act. Grrr.
    ~T
  18. priushippie
    priushippie New Member
    330
    Pennsyltucky
    My dealer put the cheapest Castrol 5 -20 in my 2010 RAV 4 after I specifically asked them if they were going to use genuine factory parts and they said yes. I will never go there again. Period! I hope they are happy. I have never taken my 2010 Prius there for anything so far, not even the brake recall.
  19. rumpledoll
    rumpledoll Member
    179
    46
    New Jersey, USA
    It is yet another dealer lie. In the USA, Toyota recommends 0W-20 and allows 5W-20 if 0W-20 isn't available provided you change it next change at 5,000 miles. Toyota recently sent letters to everyone that the oil change interval has been bumped to 10,000 miles if you use 0W-20 synthetic oil. It makes no mention of 5W-30.
    The owners manual does give wiggle room to use an unspecified higher viscosity oil in some extreme situations, but it is left unsaid exactly what those situations might be.
    Bottom line is use the recommended 0W-20 grade oil, demand they change it out and never go back there again. Only use different grades if you know why one might want to and you have that situation. For me, if I did long distance high speed driving in the American south west during the hottest months I might consider 5W-30, but in all likelihood would even then stick with 0W-20.
    Rumple
  20. jdcollins5
    5,131
    1,342
    Wilmington, NC
    Understood. I personally prefer to use 0W20 and stay with the 5K OCI, at least for the first few changes anyway.
    Unfortunately, this dealership is the only one in town. The next closest is an hour away. This is my first Toyota and I wanted to establish a relationship with this dealer. I had planned to have the 5K services through the 30K in order to establish this relationship.
    I will give anyone a second chance. I think this service advisor knows that I want only 0W20 and I will be sure that he acknowledges this the next time and not assume anything. If they screw up again, then I will start doing my own again, which I prefer to do anyway.
