Toyota Prius 2004-2009 Lan Check Codes and their meanings
Discussion in 'Knowledge Base Articles Discussion' started by rigormortis, Oct 7, 2008.
  1. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    i have seen a trend on prius forums, where more people ask about DTC codes stored in the MFD (easter egg) but no real replies to what they actually mean. and to save you the hassle of logging on to toyota techweb., i typed them up for you all
    when i have taken my prius under warranty for service checks, and have asked service advisors what the meanings are, they avoid this issue.
    this should aid you in diagnosing problems with the mfd, bluetooth module, speakers, cd players, and everything AV-LAN related.
    anytime the prius encounters an error, even as something simple as putting in a cd upside down, the MFD screen logs this event.
    i am not sure if 'memory clear' is destructive or not. a lot of codes can be safely cleared out, and see if they come back.
    please do not edit this document and claim this as your idea!
    permission to distribute this document is free to anyone, but please refer them to priuschat as the originating site of this document.
    magher, WARUNASAT, RobH and 2 others like this.
  2. nerfer
    nerfer A young senior member
    2,507
    237
    28
    Chicagoland, IL, USA, Earth
    I haven't tried it, but I believe the instructions in this thread tell you how to get to the diagnostics menu, and then you can retrieve the diagnostic trouble codes (DTCs). Somebody please correct me if this isn't correct, or only works on certain models.
  3. rigormortis
    1,340
    26
    san jose, ca
    this has nothing to do with check engine codes, or the engine. its strictly for troubleshooting devices connected to the mfd or the av-lan, like the cd changer,radio, back up camera, speakers, dvd navigation system, mini disc system, the mfd itself, xm, sirius, the g-book, the cd player, the tape deck, etc etc
  4. Sierradiesel
    Sierradiesel New Member
    Pa
    Can anyone repost how to get the diagnostics menu. The link "this thread" does not work for me. Thanks.
  5. Sierradiesel
    Pa
    Thanks for the help-it works now.
  6. KCobby
    KCobby Member
    229
    74
    NYC area
    Awesome information - glad to find this - thanks rigormortis!!
    Getting to the diagnostic screen is relatively easy (if your MFD is functioning that is...)
    1. Push "ON" button once without foot on brake.
    2. Press "info" button on the side of the MFD and hold while turning on the lights three times
    That should take you to the diagnostic screen. From there you have lots of possibilities.
    I used this site which I think is also referenced in the link above, but just in case:
    http://andrew.daviel.org/prius/egg.html
