Toyota remote starter useless below -22F (-30C)
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Zorro-la-binette, Dec 11, 2011.
  1. Zorro-la-binette
    Zorro-la-binette New Member
    Québec, Canada.
    Hello all,
    I had an original Toyota remote starter installed when I bought my 2010 Prius. The dealer informed me at that time that the range was about 90 feet and that I be better with a jobber remote starter... I did stick with the Toyota because I didnt want another remote transmitter key with my keyfob and that the range was not a problem for me...
    And winter came and the remote starter was working fine except that on one pretty cold winter morning it did not...and the next morning. It took a while for the dealer to find the problem...
    Sit tight in your chair... in the check list of the technician for remote starter problem(wich I have copy) it is stated that :(Sorry it is in french, but translated, it goes like that:)
    Remote starter wont work below -22F(-30C) this is a normal condition and no fixing is required.:eek:
    What do you think of that! :rolleyes:
    I made that post to let you know that information. Now I have a "Chinese remote starter" working fine with my Japanese car!
    Hope this will help.
  2. ucsmfu
    ucsmfu Senior Member
    1,498
    420
    canada
    what that sucks !!!!, I was thinking of getting the oem one, now i might consider the compustar :)
  3. NineScorpions
    NineScorpions Economy, Meet Style!!
    375
    64
    -22F? Dear God
  4. Judgeless
    Judgeless Senior Member
    1,821
    257
    Cleveland, OH
    It does work way below 22F. I know there is a cut off temp but it is a lot lower than 22F. I did not like the short distance and the 10 minutes it would run the car before turning off so I disabled the OEM remote start and had a Viper unit installed.
    There are threads on this that cover the exact temp it cuts off.
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    The OP said -22, not 22. You missed the sign.
    Tom
  6. Teakwood
    Teakwood Member
    491
    73
    New Mexico
    At -30C, things get iffy.
    Commercial is typically 0 °C to 70 °C. Industrial (automotive) is usually −40 °C to 85 °C. Military temp range is usually −55 °C to 125 °C.
    However, there are exceptions and Industrial temp range can be −25 °C to 85 °C).
    So, it should still work at -30C, but the operating temp range for the particular device may be one of the exceptions.
    Reference: [ame]http://en.wikipedia.org/wiki/Operating_temperature[/ame]
  7. Judgeless
    1,821
    257
    Cleveland, OH
    I did miss the sign. There are people that claim it does not work around +5F. I never had that issue. I would hate to live in an area that is -22F.
  8. Judgeless
    1,821
    257
    Cleveland, OH
  9. oldasdust
    oldasdust Member
    356
    47
    illinois
    HHHHHHHHHHHHHMMMMMMMMMMMMM I have a 2 year old Honda that sits outside and has never not started in winter. We have made it to 20 below ????
  10. Judgeless
    1,821
    257
    Cleveland, OH
    The car will start with the button. The remote start has a cut off of -22F.
  11. samsprius1
    samsprius1 Active Member
    720
    182
    2023 Prius
    Limited AWD-e
    I'm with you on this Judge! Went with the viper 5501 this is a 2way unit so you always know if your car started or not, amazing range they claim 1mile! I Have had it start 5 blocks from work,Through brick walls! Works like no other remote start I have had.A little more $$ than others but worth it!
    Viper - Viper 5501 Responder LC3 SuperCode SST 2-Way Remote Start System
  12. Yogi56
    Yogi56 New Member
    156
    26
    Escondido, CA
    At -22c I'd have too much anti freeze (12 year old kind) in me to drive so not an issue. Would you be using a block heater at this temp? Wonder if that would give the OEM system a chance to work?
  13. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    Right there with you, Yogi except that the coldest part of the day is the early morning and I barely have time to get up, shower, get dressed, eat breakfast, chip the ice off my car and get under way. The only way I can fit in a couple snifters of antifreeze is if I get up earlier and that just ain't happening!
