Toyota USA - Something New is Just Around the Corner
Discussion in 'Toyota Hybrids and EVs' started by drash, Oct 25, 2023.
Tags:
  1. drash
    drash Senior Member
    2,530
    1,284
    Upstate NY
    john1701a likes this.
  2. drash
    drash Senior Member
    2,530
    1,284
    Upstate NY
    If it is the Crown Sport, and everything so far points to it, here's the stats from the Global Toyota site:
    Toyota Launches All-New Crown "Sport" in Japan | Toyota | Global Newsroom | Toyota Motor Corporation Official Global Website
    Spec Details Comment
    1 Powertrain 2.5L Series Parallel System (A25A-FXS) Same as seen in the RAV4 Hybrid and Venza
    2 Length 4720 mm (185.8 in) A touch shorter than the Venza
    3 Width 1880 mm (74.0 in) About an inch (25 mm) wider than the Venza
    4 Height 1565 mm (61.6 in) Only slightly higher than the Lexus UX but lower than all Toyota SUVs by at least 3 inches (76 mm).
    5 Efficiency 21.3 km/L (50.1 mpg) WLTC Venza gets 39 mpg Combined EPA
    6 Other Standard Dynamic Rear Steering (DRS) Seen only on the Platinum trim level of the Crown Crossover
    This will make a fairly crowded mid size SUV field already with the RAV4 and Venza, but it's what sells. They're planning on selling a PHEV version in the Japanese market next year. Not sure if they plan on selling the PHEV version in the NA market, or if it'll keep the AWD and DRS. The front end resembles the Prius so this kind of makes it a Prius SUV.
    50,800
    nice looking crown rear end!
  4. Trollbait
    12,227
    otatrant likes this.
  5. Tideland Prius
    16,401
    The taillights are more similar to the Crown Estate than the Crown Sport.
    That said, I also believe that the Crown Sport is coming but the teaser above is likely the Crown Estate (or whatever it ends up being called here - probably Crown SUV)
    Trollbait and drash like this.
  6. drash
    drash Senior Member
    2,530
    1,284
    Upstate NY
    You think the Crown Estate is a midsize SUV? Specs are about Highlander size, but then again is the Highlander a mid-size SUV? Wondering what Toyota thinks mid-size is.
  7. Trollbait
    12,227
    Tideland Prius and drash like this.
  8. drash
    drash Senior Member
    2,530
    1,284
    Upstate NY
    Yeah the rear end does resemble what Toyota is showing probably better than the Crown Sport rear end:
    The front end from Toyota USA:
    And from Toyota Global:
    Specs on the Crown Estate:
    1 Powertrain 2.5L Parallel Series Hybrid Similar to Highlander Hybrid and Sienna - but no details because it hasn't been released yet in Japan
    2 Length 4930 mm (194.1 in) Slightly less than the Highlander (not Grand Highlander)
    3 Width 1880 mm (74.0 in) 51 mm (2 in) skinnier than the Highlander slightly wider than the RAV4
    4 Height 1620 mm (63.8 in) Way lower than the Highlander and lower than even the Corolla Cross
    5 Other PHEV planned also No details yet
  9. Tideland Prius
    16,401
    Yeah what @Trollbait said. Probably a fancier version for those who want something more than utilitarian. The Venza is aimed at empty nesters and young professionals while the RAV4 is aimed at families and outdoorsy people. The Crown Estate is to the Highlander what the Venza is to the RAV4.
    The other teaser is likely the Camry. I doubt there’ll be a dive plane on a Crown Estate.
  10. drash
    drash Senior Member
    2,530
    1,284
    Upstate NY
    Solid date on the release of the Crown SUV - 14 November. For those staying up - 10 PM EST. For those keeping track this is at the LA Auto Show.
    Toyota Crown SUV Makes its Debut November 14 - Toyota USA Newsroom
    Toyota has already released the Crown Crossover, Crown Sport and Crown Sedan worldwide so it looks like the Estate is next. It will be an upgraded RAV4 sized SUV. Slightly wider and slightly longer than the RAV4 but nowhere near Highlander size which would have people screaming for a 7 seat version. I'm sure that won't stop some reviewers from suggesting a 7-seater, but Toyota is probably just trying to keep it simple. Some sites suggest some trims might also be offered with the Crown's Hybrid Max, because well it's a Crown, making it the first mid-sized SUV to feature this power plant. Its height also has some sites suggesting this is more of a wagon rather than an SUV. Its height does sit somewhere between Lexus' diminutive UX and the Corolla Cross and its length will probably give it more of a wagon look. Car and Driver suggested there's a US Trademark for the name Crown Signia :sick:. Isn't Signia already taken? I thought there was a Buick Signia.
    The Estate is supposed to offer a PHEV version as well. The only question is will the North American market get the Prime (PHEV) version? Toyota Global already said "The PHEV comes with a newly developed large-capacity lithium-ion battery" for the Crown Sport (Toyota Launches All-New Crown "Sport" in Japan | Toyota | Global Newsroom | Toyota Motor Corporation Official Global Website) so I'm assuming the Estate (Prime?) will have this battery as well. The PHEV version of the Crown Sport isn't due until 2024 (Winter 2023 is the actual release date) so we may get a peak at the new battery around December time frame, maybe.
    Tideland Prius likes this.
  11. Tideland Prius
    16,401
    So this is for when the Venza is too small? I must admit, I wasn't impressed with the Crown we have here (Crown Crossover in Japan). The interior didn't feel as special and as premium as I envisioned what a Crown should be. (Heck, it shares the climate control with the Gen 5 Prius and I'm pretty sure Toyota treats the Prius as a Corolla-class car).
    I guess it'll have better materials than the Highlander?
    I think you're thinking of the Buick Regal (Opel Insignia)
    drash likes this.
  12. Trollbait
    12,227
    I'd call it a wagon. Estate is what they call wagons in Europe after all.
  13. drash
    drash Senior Member
    2,530
    1,284
    Upstate NY
    Or too cheap? The Venza is about $3,000 to $4,000 (USD) more than a comparable RAV4 Hybrid. Funny thing though, the Venza is over 5 inches longer than the RAV4 and the same width but doesn't have as much cargo room as the RAV4. I'm thinking with the much lower roof of the Crown SUV it'll have even less than than the Venza.
    Haven't been inside of a Crown yet. I'd have to get the ultimate opinion from my wife if I can convince her to even look at the Crown. After her Lexus probably couldn't get her back in any Toy if we went car shopping again :LOL: although she likes the Venza. Me I'm more of an infrastructure guy, I'd have to drive it to see if it is anywhere as smooth, quiet, and comfortable as the NXh.
    Yeah I forgot about the Opels and Vauxhalls. Thought the name sounded somewhat familiar.
  14. Tideland Prius
    16,401
    Possibly. Especially since the prices of the RX has gone up, there's room below. The Venza must be selling well enough to have TMNA ask for the Crown Estate to be brought over.
    Haha. That's why I haven't moved up to a luxury car yet. My EV6 costs the same as an ES300h Executive Package (which is what I want... aside from a RX).
  15. Trollbait
    12,227
    It is about 3 inches longer in length, 2.5 taller in height, and an inch wider than the current Outback. The wheelbase of the Crown Crossover is 112.2 inches, and that is 4 longer than the Subaru.
    The Outback has 109 cu.ft. of passenger space, and 32.6 of cargo behind the second seats. Overall, it is about 4.5 more than the Rav4 hybrid's total. It is just shifted more to the passenger side and less in cargo. This Crown will likely be like the Outback in that regard with a longer wheelbase than the Rav. So I'd expect the cabin to be roomier than the Rav4, but the cargo space might be less in volume. Though the cargo floor space could be longer.
  16. Trollbait
    12,227
  17. ColoradoBoo
    ColoradoBoo Senior Member
    1,110
    727
    Monument, Colorado USA
    I love that Crown....might be a very tempting purchase when I retire and we go from a two Priis couple to one vehicle. (Or a small Lexus SUV.)
