Toyota's own plug-in Prius pictured!
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by clett, Nov 7, 2006.
  1. clett
    clett New Member
    537
    Scotland
    Toyota's advanced vehicle engineer and spokesman Bill Reinert was recently adddressing a peak oil conference with a slideshow. At the very end, he flashed up a picture up of the progress Toyota are making with plug-in hybrids.
    Rather than a new vehicle layout, it appears to be based on a current model Prius. (No word on how close to production though.)
    See the picture (briefly!) as it flashes up towards the end of his talk on video here:
    http://www.evworld.com/view.cfm?section=ar...mp;storyid=1127
    The remainder of his talk is also very interesting as it gives a frank statement of Toyota's environmental assessments and the approaches they are taking in future.
  2. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    Damn... you really can't tell what the picture shows in that, unfortunately. I *think* they may be sacrificing some trunk space for the batteries, but it's really difficult to tell with the video so grainy.
  3. hill
    8,575
    Dang! I've always compared destruction of the Ev1 and other anti battery philosophys of the auto industry as being like the smoking lobby . . . sure sounded weird hearing out of the mouth of the auto industry.
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    Interesting comments about the 'grid mix' causing more CO2 and Nox w/ a PHEV than with the current hybrid system if coal sourced energy increases. Also that they're "having problems" w/ the Li ion batteries as regards recycling. It even sounds as though they still don't have any certainty on range, battery size, or even how the system will be implemented (ie. whether an EV button will be used.
    The photo at the end basicly just showed a chunk of space behind the back seat and above the current battery pack being used for extra battery space...not really a suprise there. Too bad they can't go to those new fangled airless tires, eliminate the spare and use that space.
  5. ScottY
    ScottY New Member
    1,250
    Long Island, NY
    He didn't show the whole car right? He's just showing what the trunk will look like for the current Prius if they add extra battery for plug-in.
    <div class='quotetop'>QUOTE(efusco @ Nov 7 2006, 12:48 PM) [snapback]345068[/snapback]</div>
    Evan, maybe you can submit this suggestion to Toyota and see if they actually implement it. ;)
  6. jfschultz
    jfschultz Active Member
    636
    115
    Germantown, TN
    2020 Prius Prime
    <div class='quotetop'>QUOTE(efusco @ Nov 7 2006, 11:48 AM) [snapback]345068[/snapback]</div>
    Probably, at this stage of development, they are just working with modifying stock Prius. Ease of access and not truck space is the major consideration at this point. Practical refinements will come later in the development cycle.
  7. Tideland Prius
    16,405
    It looks like a modified Prius II. Also, the spy shots have also shown the new Prius riding around in disguise using the current Prius II body shell.
  8. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    <div class='quotetop'>QUOTE(efusco @ Nov 7 2006, 10:48 AM) [snapback]345068[/snapback]</div>
    As far as I can tell their still comparing inputs to outputs. It takes ~41 kWh of energy to produce a gallon of petrol. Where did that energy come from? If it comes from a coal fired plant the numbers that they've thrown around are worthless. Did I miss something in their discussion? They never seemed to include the energy inputs to produce the petrol.
  9. darelldd
    6,057
    389
    Northern CA
    <div class='quotetop'>QUOTE(tripp @ Nov 7 2006, 11:21 AM) [snapback]345151[/snapback]</div>
    'Zactly!
  10. Charles Suitt
    Charles Suitt Senior Member
    1,637
    17
    Dallas TX
    Quote Evan: "Too bad they can't go to those new fangled airless tires, eliminate the spare and use that space." Good thought, Evan!!
    ANY mechanical device, even the 'airless tires,' is subject to mechanical problems. Suppose, for example, you had to drive through some mud and it collected within the 'spokes' of the airless tire... what an out of balance problem that would be! I suppose that could be prevented by adding some sort of 'sidewalls,' though. Perhaps they could produce an "inflatable" spare good for 50 miles... I suppose I'm 'old school' and would be very uncomfortable without some kind of spare tire. OTOH, I have a "spare tire" around my waist. :lol: :lol:
  11. efusco
    19,891
    1,194
    Nixa, MO
    I think it's virtually certain they'll have sidewalls on those tires. I suspect the prototypes are shown without sidewalls for marketing and to make it clear what it is and how it works. sticks, rocks, mud, snow/ice, etc would certainly be a problem with an open structure like was displayed.
    And, while I agree that any mechanical part runs the potential for failure, and, arguably, the tire would be more at risk b/c of it's job, such a product as that would be much much less likely to failure than a traditional tire. Also, I doubt it would be more prone to failure than the fuel pump, battery pack, ECUs, etc...and we don't tote along spares of those.
  12. galaxee
    galaxee mostly benevolent
    9,810
    468
    MD
    vans that have fold-under-the-floor seats come with run-flats because there's no room underneath for a spare... but man are those things a $#*(& PITA to replace.
  13. pstockley
    pstockley New Member
    16
  14. Tideland Prius
    16,405
    <div class='quotetop'>QUOTE(galaxee @ Nov 8 2006, 01:31 PM) [snapback]345798[/snapback]</div>
    What about run-flats with TPMS? Is there such a combination? (I'm thinking Sienna AWD and XLE models with 17" rims)
  15. Eric Nothman
    Eric Nothman Prius owner
    101
    Washington DC area
    2020 Prius Prime
    This is a fascinating presentation from a Toyota engineer/industry specialist with many new pieces of information. Here are some key points from his presentation on the video:
    1) Model cycle is 2008 for the Prius (so updated Prius is next year?)
    2) Presenter asks us to 'do the math' that indicates this next generation Prius design goal = City at 75mpg and hiway at 64mpg (plus provide additional power)
    3) That the current hybrid price premium is $2,000 (based on the Camry)
    4) Lithium-ion issues are: recycling; and survivability (because of wide charge swings)
    5) Toyota engineers get a 'carbon budget' for CO2 pollution - for lifecycle of all materials used in the car
    (one would presume this would include the fuel)
    6) Toyota believes future electric generation capacity is going to have higher pollution than present capacity
    (with the implication due to Toyota 'carbon budget' engineering criteria - Toyota would not favor electric 'plug-in' option when considering total lifecycle of the vehicle - in terms of CO2)
    7) There will be 1 billion more cars on the planet soon contributing a lot of pollution
    (implication is that people will engineer solutions other than cars for transportation)
    Based on this my suggestion to Toyota (and other manufacturers) on point #5 & #6 is this:
    Package the (plug-in) hybrids for sale with 'wind power' certificates for the wind power premium for the first 100,000 miles of the vehicle - a value of $320 (included in the vehicle sales price). The plug-in car now runs on wind power. Here is the calculation:
    Given: 80 cents for a gallon equivalent of electricity and a gallon goes about 50 miles on the Prius
    (so the Prius uses about 2,000 gallons in 100,000 miles)
    Given: wind power certificate is equal to about 20% higher charge for electricity (today)
    (so 20% of 80 cents per gallon equivalent is the cost of non polluting wind power or 16 cents)
    Calculation: 2000*16(cents) = $320.00 (total) for wind power premium for first 100,000 miles
    So, the public has no choice - they get the 'wind power' certificates 'for free'. Toyota gets a car that causes zero green house gasses (needs to be a plug-in for this to work) and zero NOX etc. (achieves design goals).
    Market as 'let the wind carry you', 'run with the wind', 'with the wind at your back' and 'the first non-polluting car' etc. Also, work out joint marketing agreements with large electric energy companies that will advertise the cars to their customers (with special additional incentives etc. if you buy the car and charge at night)
    Separately, can someone post the video from this same conference for the presentation from Andy Frank (on Lithium Ion batteries)?
    Best regards,
    Eric
  16. clett
    clett New Member
    537
    Scotland
    Good post Eric, I like the wind investment idea.
    However Toyota are totally underestimating the recent and planned inroads made in renewable energy. Currently coal power (the cheapest form of electricity) is at about 3 cents per kWh, natural gas not too far off. BUT recent renewable technologies, and gradual improvements in existing renewable tech mean these are also closing in on the same 3 cents per kWh and are soon to be even cheaper than coal.
    When that happens, expect the carbon emissions of the power generation mix to improve dramatically. Toyota need to pre-empt this shift in generation in their calculations of lifetime CO2.
