TPMS
Discussion in 'Prius c Accessories and Modifications' started by krneidigh, Sep 6, 2012.
  1. krneidigh
    krneidigh Junior Member
    70
    17
    Pensacola
    I am getting new wheels and transferring over tpms and rubber. The guy the shop said they could do it, but they don't have the tool required to reset the TPMS. What does this mean? Do they have to be reset if they are ones currently on the car?
  2. RobH
    RobH Senior Member
    2,369
    984
    70
    Sunnyvale, California
    If they're transferring the sensors in the wheels, then no reset is required. If you change the tire pressures, then it would be appropriate to press the TPMS reset button under the dash. The fancy tool is only required to register different tire sensors.
  3. krneidigh
    70
    17
    Pensacola
    Cool, thanks.
  4. krneidigh
    70
    17
    Pensacola
    Are they programmed in position; driver front cant be installed in passenger rear? Or just as long as the sensor is on car, with the right pressure, the car doesn't care?
  5. dellrio
    dellrio Im pretty much awesome
    281
    88
    37
    Des Moines, IA
    placement does not matter - you should rotate the tires every 5,000 miles and resetting the TPMS would be impractical every 5K.
  6. krneidigh
    70
    17
    Pensacola
    Thanks for all the help. I just throw some wheels on this afternoon.
    MAXXIM WHEELS - MAZE 15"x6.5" offset 38mm 12.87lbs each.
  7. FastZX6R
    FastZX6R Junior Member
    Nice wheels.
    What do you guys do with the extra holes in the wheels?? I have Black Drag Wheels and they also have extra holes. Would be nice to cover them up somehow.
  8. shuiwm
    shuiwm Junior Member
    New York, NY
    are there any issue for the TPMS, is the sensor easy to remove & install?, thanks
  9. krneidigh
    70
    17
    Pensacola
    It's been 5k miles everything has been fine. I've seen pictures of them I honestly cant imagine they are difficult to swap them, but replacing them requires reprogramming and some shops carry the tool for that.
