Traction Battery Dies in 2009 Prius Pkg 4
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Gary Boyd, Jul 10, 2009.
  1. Gary Boyd
    Gary Boyd New Member
    Durango, CO
    I just bought a new Prius 2009 and driving it in the mountain in Colorado the Traction battery goes dead (even starting in the green) and then the engine just cycles fast then slow rpm over andover again and vehicle will not go over 45mph when the negine alone is powering the car. Toyota says " this is a known problem" and that they can therefore do nothing about it. even their customer relations group says the car is functioning "normally". Problem is I have ridden in other 2nd generation Prius and have talked to other dealers and none of them have this problem so how can it be "Normal". The dealer will do nothing even thought the wrranty states it can replace the: traction battery, battery control module, Hybrid control module, Inverter with converter. No where in the Toyota manuals does it warn the consumer that some hybrid vehicles might not function properly in mountaneous terrain like Colorado, Wyoming, Utah, etc... so what options do I have and can this problem be fixed?????
  2. PriusLewis
    PriusLewis Management Scientist
    1,002
    84
    Denver Metro
    Re: Traction Battery Dies in 2009 Prius Level IV
    I agree it shouldn't be a "known problem." Mine will exhaust the battery in the mountains running up to Blackhawk from Denver, but it will maintain speed on the ICE (it revs it's little heart out, but does a decent job). If you're climbing worse grades than here on the Front Range and at higher altitude I guess it could eventually be more than the ICE can handle. I'm definitely surprised at this.
  3. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    511
    63
    Was there any warning light or error message? How do you know it is dead?
  4. Gary Boyd
    Durango, CO
    So what options do I have to resolve this issue - I see you are a Prius Scientist - I am a mechanical engineer working on the next generation ceramic regenerated gas turbine prime mover to replace the 4 cylinder engine. I know there is a solution - afterall it is only hardware and EPROM's......
  5. Gary Boyd
    Durango, CO
    There are no warning lights but the traction battery indication goes from blue bars to purple and then to no bars and that is when the engine begins a cyclic rev to high rpm and the car can only go about 45mph.
  6. a priori
    a priori Canonus Curiosus
    3,083
    407
    23
    Chicagoland (West)
    Is the issue one of battery failure or of exhausting the battery? You can't be going uphill all the time, so the ICE should be recharging the battery at some point, unless there is a problem with the system.
    Are you driving in a high elevation area where the demand is so great that the HSD can't keep up? Do you think that is the problem, or do you believe the battery itself is bad?
    Are you driving alone or with passengers? Are you carrying anything else in the car? Are you using regular gasoline? Do you drive just in short intervals or for long stretches at a time?
  7. Gary Boyd
    Durango, CO
    I can be the only onein the car - worse withmore weight. The battery does not die - it simply loses all charge and does assist the engine. It will recharge going downhill in Drive or Regenerative Braking. When battery gets completely discharged in only 6 miles on a 6 degree incline then the engine begins rev up and down in a cyle - that car will only go 45mph in these conditions
  8. Bob64
    1,540
    93
    Virginia
    how fast does it lose all the charge?
  9. Frayadjacent
    Frayadjacent Resident Conservative
    375
    Austin, TX
    I'd think that you're driving the Prius in a very extreme environment. It's entirely feasible that with long uphill treks, the traction battery will discharge to it's lower threshold. There's a threshold of power output where a portion of that power comes from the battery. Keep the vehicle operating over that threshold, and you end up discharging the battery. At that point, only the ICE can power the vehicle.
    Depending on what you're actually trying to do (i.e. long uphill climbs), you're probably putting demand that is over the threshold mentioned above, and the vehicle is doing what would normally happen.
  10. Gary Boyd
    Durango, CO
    If that is the case then why do no other Prius' perform in this way - it certainly is not "normal". I have driven a 2006 and 2007 and neither have this problem.
  11. Frayadjacent
    375
    Austin, TX
    How many other Prius have you driven in THE SAME CIRCUMSTANCES to say that they do not operate the same?
    Have you left it on the Energy display on the MFD while driving in the mountains? Is energy mostly flowing FROM the battery?
    Remember, the battery only has SO much energy when it's fully charged up. You can actually use that energy pretty quickly if there's no opportunity to recover it.
    Your vehicle might be performing COMPLETELY normally given the circumstances. Again, think about the power threshold - once you start driving over that threshold, you're drawing power from the battery. If you keep it above that threshold like when driving uphill for extended periods you are GOING TO discharge the battery. There's no way around it.
    Also consider that the battery will heat up under heavy demand. When it heats up, the hybrid system limits the amount of power it can provide AND the amount of power it can absorb through regeneration. Heat KILLS batteries, so the system will throttle the battery to keep it from getting too hot. You may be encountering situations where this affects performance as well.
  12. CBarr31
    CBarr31 Active Member
    434
    225
    Charlotte, NC
    Gary,
    This doesn't sound "normal" at all. I have driven up large hills in Carolina, Tennessee, Virginia and West Virginia that are comparable and have always been fine with cruise set at 65-70 MPH. This includes the "7 mile hill" up I-77 crossing over from NC to VA.
    The battery will get low on these runs but I don't remember ever seeing it go purple on me. I only see that (purple) when I am sitting in the car for extended periods for some reason either on a phone call or playing with Bluetooth or Dice.
    If possible, is there a Toyota Dealership nearby this hill that you could take a Service Manager for a test ride? I always found service departments to be most responsive when a manager actually see/hears the problem.
    Another test could be sit with the car running long enough to get down to the purple and then drive up a smaller hill or at speed on the highway. If you "tax" the ICE in this situation and it is uncapable or recharging the traction battery do the same symptoms represent? If so you may be able to duplicate them for your Service Manager.
    I hope this helps.
    Chris
  13. yardman 49
    yardman 49 Active Member
    606
    77
    Northern Kentucky
    Maybe the TB cooling fan is not working. This could cause the TB to heat up too fast, and the car would reduce the battery charging to compensate.
  14. Frayadjacent
    375
    Austin, TX
    I would concur something like that could be happening, but wouldn't it throw a code?
  15. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,800
    Undisclosed Location
    The heart of your question is really "Is this Normal?". What is confusing the issue is that it IS normal to have quicker discharge when driving on an incline. However, I don't think the overall behavior is normal. Not being able to drive over 45mph and having your engine cycle fast and slow RPM over and over is NOT normal.
    In trying to determine if this in normal behavior and/or leverage warranty work, perhaps you could borrow or rent another Prius? I'd ask Toyota to pay for it. Drive it as you have driven yours and see if the results are the same. If another Prius demonstrates the exact same symptoms then maybe where you live and the driving you do IS going to be prohibitive of owning a Prius. But I doubt it. If another Prius doesn't react the same way, you'd have a clear case to tell Toyota and The Dealership, hey this isn't "normal", Fix it.
    I'm thinking that's the easiest, quickest way to determine if your Prius is simply operating normally or if you have a problem.
  16. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    How about make a video? It is easiest to see how you drive it in what kind of terrain, etc...
  17. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    The title of the thread is very misleading since it doesn't sound like the battery itself is the problem, and the explanation of what is happening is garbled too. Start over so that folks can follow along:
    1. What are the conditions of the drive? What road? What sort of grade, how long? Are you firewalling it to start out? What altitude at beginning and end?
    2. What is happening, in sequence?
    3. Have you driven another GenII Prius on this same stretch of road and seen the same thing happen?
    4. Are you doing this with AC maxed?
    I can't tell whether what you describe is normal or not for mountain conditions, but others should be able to.
    As to what might be effecting the vehicle other than the driving conditions:
    1. Check tire pressure as low pressure increases drag.
    2. Make sure the battery vent beside the passenger seat is not obstructed.
    3. Check your oil level, Toyota usually delivers them overfilled by 1/4". There is a possibility that this might cause trouble, even some oil ingestion into the air intake.
    4. Has the vehicle thrown any codes?
    5. I wonder if the inverter pump is not working properly?
    6. What fuel are you using?
    IF other Prius have the same problem on that stretch then there is not much you can do, so a direct comparison is needed. The traction battery cannot pull you all the way up a mountain, it just isn't very big and will soon be down to minimum SOC. The gasoline engine is small, which makes it more efficient, but not particularly well suited for long steep grades. If the engine alone can't maintain the speed you desire over a long steep grade, then the battery will soon be depleted. At altitude the power output is even less (nothing unusual about that.)
    The only suggestion I have for improving the horsepower of the ICE is to try a drop-in K&N air filter. This should slightly increase horsepower at WOT, but don't expect miracles...especially with a drop in filter.
  18. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    Eastern mountains are not the same as Colorado. You start at
    a much higher base altitude in the Rockies, and there are known
    effects of high altitude on battery performance as noted here.
    Some owners claim to never have issues of this sort, others do,
    and it doesn't seem to be tied to any particular year of car.
    Ambient pressure effects on sealed NiMH cells are documented,
    and as the car has no MAP or BARO sensors it cannot determine
    a particular set of conditions to compensate for. And of course
    when you're climbing hard it tends to use up the battery anyways.
    I saw the same thing, and once I was back down under about 2000 feet
    everything was completely back to normal. I've even seen hints of
    the effect in really stormy, low-pressure weather back home [which
    we've had plenty of in the northeast, thankyouverymuchyoucanquitnow].
    The 2010 Prius appears to incorporate a barometric sensor, possibly
    as an input to deal with precisely this issue.
    _H*
  19. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    ... this sounds normal for that region. i lived in Colorado for about a year with my 04. Utah climbs drain it.. Wyoming climbs drain it.. and parts of Colorado drain it.
    the "trick" is to try not using the battery.. so.. take it kinda slow and try to keep engine RPMs up while having motor RPMs down.. so try to get green arrow to battery as much as possible. in some areas this will be impossible. keeping from flooring it tends to help too... but sometimes you may feel as if you Have to floor it. try lifting off a little if you are flooring it.. and you'll feel the system start pulsing oddly. you should be getting battery regen when this happens...
    but yeah.. i assume that's why they added a gear ratio to the electric motor for the 2010 prius.... plus a bigger engine :)
  20. fuzzy1
    10,332
    6 degrees is a 10.5%, with is 50% steeper than the steepest section of I-70. I'm too new to hybrids to have driven a one in the mountains yet, but wouldn't be surprised that it if couldn't go faster than that.
    Could you mean 6%, not 6 degrees?
    6 miles of this slope is either 3,300 feet or 1,900 feet of elevation gain, which far exceeds the battery capacity. If the battery provides any significant portion of the traction power, it will be drained before reaching the top. Most of the climb must be done on the ICE alone.
