Tran problem
Discussion in 'Gen 2 Prius Technical Discussion' started by combsad7, Jun 14, 2008.
  1. combsad7
    combsad7 Junior Member
    51
    Western Kentucky USA
    My 2008 Prius with 1772 miles would not move today after filling it with gas, no I did not overfile the tank. The parking break green light stayed on, my car would not go into Drive, Reverse or nutural. Had my car flat bed to a Toyota dealer.
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    Not much to go on there. Let us know what's found. Did the car go into "ready"? did the ICE start up while in Park? Any other lights on the dash?
    Were you able to shut it down completely? What happened, in detail, when you put your foot on the brake and pushed the start button?
    There have been scattered reports of oddities causing problems very early in the life of the car, but nothing consistant.
  3. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi Combsad7,
    The car will not go into gear if any of the doors are ajar, or one of the door switches is not working correctly.
    Its premature to assume this on my part, but that is most likely what happened.
  4. hschuck
    hschuck Member
    385
    bay city, ca
  5. Patrick Wong
    18,200
    6,490
    Interesting - assuming that you had depressed the brake pedal when attempting to shift, my guess is that the brake pedal light switch has failed or is out of adjustment.
    It must not have been easy to pull the Prius up onto the flat bed while the transaxle remained in P.
  6. combsad7
    51
    Yes, tow driver put pads under the wheels and pulled my Prius on the tow truck, it took a long time to load my Prius on the truck. There were no doors ajar, the ready light was on, no warning lights. I tried turning it off and on with my foot on the brake. Looked in owers manual, could not find any help. I put the smart key in the key slot on dash, still remained in park. Brake lights do come on when I press the brake petal. ICE did start up.
  7. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi All,
    I had forgotten about the brake pedal/power-on button thing. I did that too when I first had the car. My assumption at the time was I was doing something wrong, not the car was broken. And just fiddled around until I got the car to work. Later I found out I had forgotten to press the brake peddle.
    Hschuck, I will have to double check my 2006. I do remember the beeping hysterics the car makes when one starts it with a door open. But do not remember actually trying to put the car in gear with all that noise going on.
    Once the car is on, and one opens a door, that is another thing. They do not want it to go out of gear, while driving down the road, and somebody should pop a door open accidentally.
  8. Patrick Wong
    18,200
    6,490
    OK, this indicates that the brake switch is properly adjusted. Hence, the problem is either with the shift selector lever, the hybrid vehicle ECU, the transmission control ECU, or the shift control actuator assembly that physically locks the transaxle.
    Since you did not see any warning lights, this probably means no DTC were logged. You indicated that the green LED in the Park switch remained turned on. (If the LED was blinking, that would signify a malfunction detected by the system.)
    My guess is that the shift selector lever failed; please let us know the outcome.
  9. patsparks
    10,664
    567
    Adelaide South Australia
    I've had a situation once or twice where I have been a bit quick with the power button and not hit the brake until I was already touching the power button, also very brief touch of power button and it seems to trick the system. It wont go into gear and it wont turn off. I needed to hold the power button in to shut it down, the way you force a frozen PC to shut down then reboot it and all was fine.
    Did you have trouble shutting it down after this happened?
  10. bwilson4web
    15,939
    Pure, unadulterated speculation since I do not have an NHW20: could the parking paw fail and/or been overloaded? If you put the car in "Park" on a slope, in theory, a steep enough slope could "lock" the parking paw and the motor might have a little trouble getting it disengaged. Alternatively, a parking paw sensor might fail and thus not let the car go into any 'gear.' ... Just my wandering imagination as I wait for the aspirin to kick in.
  11. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    I believe the brake pedal switch assembly has two switches in one unit. One switch runs the brake lights, the other tells the ECU that the brake pedal is pushed. It's possible for one to fail while the other still works.
    Tom
  12. Patrick Wong
    18,200
    6,490
    Hi Tom,
    Cruise control-equipped Prius have a two-part brake pedal switch. I understand that the second switch is used to tell the hybrid vehicle ECU when to disengage the cruise function.
    Base Prius w/o cruise control only have one brake pedal switch, so that switch performs double duty regarding brake lights and signaling that it is OK to make the Prius READY.
  13. qbee42
    18,058
    3,076
    Northern Michigan
    Ah, that makes sense. I've never looked closely at a base model.
    It should be a quick test to see if it's a bad switch, but it sounds like that's not the case this time.
    Tom
  14. combsad7
    51
    Service manger at Toyota Dealer says the shift selector is bad, Then he asks what I did to it, I replied tried to start my Prius by one pushing on brake and two pushing on button. Then I ask the service manager how he would start the car, he replies just like I did. Parts should be in and I should get my car back Friday. They did give me a loaner but I dislike "smart" service manager who thinks I broke my car on purpose. All covered by warrenty.
  15. efusco
    19,891
    1,194
    Nixa, MO
    Don't you just wanna slap them when they say that?
    There've been a couple reports of shifters that have been bad, but not a widespread problem.
  16. ny biker
    ny biker Member
    463
    Northern Virginia
    2022 Prius
    Which dealer did you go to?
