Transaxle oil change
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by a64pilot, Sep 17, 2009.
  1. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    I'm about to change the transaxle fluid soon. Is it the same as the GenII? I have found some threads about that one. Same tool requirement? Same fluid? Same drain and fill plug?
    Bob, you'd know wouldn't you?
    Would it be worth it to have an analysis done? I know there was interest and maybe some problems with the GenII, is the III any different?
    Lot of questions, sorry, just not up to speed on CVT's but I have re-built many, C4's, C6's, 727's and 904's, Powerglides etc.
    Just dated myself didn't I?:mad:
  2. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    I don't have access to my pictures and info right now, but I believe the drain and fill plugs are on the side of the transaxle and you would have to remove a plastic wheel well liner for the front drivers side wheel.
    Wayne
  3. eric1234
    eric1234 Active Member
    391
    198
    Hamden, CT
    How did you make out with the transmission fluid change? Was it easy to access from underneath via the oil change "door"?
    Thanks,
    Eric
  4. cossie1600
    cossie1600 Active Member
    899
    92
    CT
    There are no dipsticks to fill from the top right?
