transaxle oil
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by edwardob, Jun 13, 2010.
  1. edwardob
    edwardob Member
    227
    33
    ireland
    how many litres is required for transaxle oil change?
    thanks
  2. ursle
    ursle Gas miser
    1,049
    192
    NH
    4.2 Liters
  3. jdenenberg
    jdenenberg EE Professor
    3,910
    1,908
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Also get washers (two) for the fill and empty plugs.
  4. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    And make sure to take off the fill plug BEFORE you take off the drain plug! If for any reason the fill plug is seized, cross-threaded or otherwise buggered, then YOU will be buggered if you remove the drain plug first
  5. edwardob
    edwardob Member
    227
    33
    ireland
    wow!!!
    great information ....and quick
    and also thanks for extra tips
  6. Patrick Wong
    18,200
    6,490
    Also think about how you are going to get the new oil into the fill hole. There are at least two possibilities:
    1) plastic funnel with 3 foot long flexible tail. Place the funnel between the radiator and inverter, and snake the tail down to the fill hole.
    2) hand operated pump that screws on top of the bottle
    I prefer #1.
    You will need a 10 mm hex key socket for the drain plug, and a 24 mm socket for the fill plug.
  7. gmalarkey
    gmalarkey New Member
    New York
    I'm still trying to find the fill port...is it accessible, does anyone have an image???
  8. ursle
    ursle Gas miser
    1,049
    192
    NH
    I did mine recently
    it's just 6" from the empty port, directly toward the front of the car, get good light and look closely, it's recesses a little bit, remember to get the funnel and long (3') rubber tube to use to get the oil to the fill port.
  9. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
