Transducer types
Discussion in 'Gen 2 Prius Technical Discussion' started by genalex, Feb 11, 2007.
  1. genalex
    genalex Member
    265
    Jersey suburbs of Phila.
    You guys with the manuals:
    Can anyone satisfy the idle curiosity of an idle, retired engineer?
    With so much "drive by wire" design in the Prius, I'm curious about the types of transducers used to sense various parameters:
    . Steering wheel position and rate of change
    . Brake pedal ditto
    . Accelerator ditto
    . Audio volume knob
    . Outside temp sensor and its location
    . Fuel level
    . Wheel speed
    And does anyone know the type and source of the cpu/microcontroler used as master control?
  2. jdenenberg
    jdenenberg EE Professor
    3,910
    1,908
    Trumbull, CT
    2020 Prius
    LE AWD-e
    <div class='quotetop'>QUOTE(genalex @ Feb 11 2007, 12:39 AM) [snapback]388324[/snapback]</div>
    I'm also an engineer , but can only give an accurate answer to some of your questions.
    The brake pedal sensor in the 2001-2003 Prius was a potentiometer (Had contact dirt/wearout problems)
    The current Prius (2004-) uses a Hall Effect sensor.
    It's a float in the gas tank that doesn't work reliably (mostly due to the "bladder" in the gas tank whose stiffness varies with temperature). Running out of gas is not a good thing.
    These are the classical toothed variable reluctance sensors that provide information to the ABS systems in modern cars.
    Probably (there are many CPUs in these cars), but not me.
    JeffD
  3. Bill Merchant
    Bill Merchant absit invidia
    4,096
    85
    Denso makes the hybrid control ECU. Maybe check their site. There are lots of computers and specific LANs for them to talk on, plus gateways between LANs. I always refer to the computer, but it's really an orchestrated network of computers.
