Transmission fluid replacement?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Gando, May 30, 2021.
  1. Gando
    Gando New Member
    Nashville
    Do I need to drain & replace transmission fluid on my 2015 at 164K?
  2. xliderider
    xliderider Senior Member
    8,016
    3,198
    Honolulu, HI
    Are you the original owner? Has the transaxle fluid ever been drained and replaced?
    How long are you planning on keeping this car?
    Valiant V likes this.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,135
    Tampa, FL
    No, but you probably should. Most owners, I imagine, never change it and don't have a problem. But it's cheap and easy, and it might prevent a problem. When you drain it, you might be surprised at how dark it is compared to new stuff. Just make sure it's the Toyota ATF-WS.
  4. Mendel Leisk
    40,238
    My opinion, the optimum time for transaxle fluid change is after the cars been on the road about 10k miles. So yeah, time for a change.
    Grit and jerrymildred like this.
  5. Too Old to Clean EGR
    Too Old to Clean EGR Junior Member
    I have not seen an official transmission fluid replacement schedule, although I have seen on this forum that Toyota has mentioned 130,000 miles, in some context, so I changed mine at 120,000 miles and plan on changing it in 60,000 mile increments going forward. My old fluid looked fine. It was just a little darker than fresh fluid. I would go ahead and change the fluid at any mileage if you think it has not been changed. Unlike a traditional transmission, you do not have to worry about the transmission slipping after replacing worn fluid, you just want to keep the planetary gear lubricated. Actual failure of the gears seems to be rare but presumably the electric motors are at least partially lubricated by the fluid.
    Changing the transmission fluid is not much different than changing the oil. It does not have a torque converter, so most of the fluid drains right out. There are plenty of threads on replacing the fluid and there is a NutzAboutBoltz video. Just have a 10mm hex socket, two crush washers (Toyota calls them gaskets), 4 quarts of Toyota WS fluid, and a pump or a few feet of hose and funnel to refill the transmission. Also, make sure you can get the upper fill plug open before you open the bottom drain plug.
  6. Mendel Leisk
    40,238
    29 ft/lbs is the spec for fill and drain bolts. Level is correct, if you fill with the car level, till it starts coming back out. FWIW Toyota cautions to only use freshly opened bottles (of Toyota ATF WS).
    Valiant V and Grit like this.
  7. Grit
    Grit Senior Member
    6,367
    4,155
    Wilkes Land
    so you can just raise the front up?
  8. Mendel Leisk
    40,238
    cmon, just cus he said it’s like an oil change you start baiting him??
    Grit likes this.
  9. Grit
    Grit Senior Member
    6,367
    4,155
    Wilkes Land
    but Toyota says lifetime fluid also? So no need to worry about fresh open bottles because no need to change :LOL:
  10. Mendel Leisk
    40,238
    Cmon…
    Grit likes this.
  11. Grit
    Grit Senior Member
    6,367
    4,155
    Wilkes Land
    just looking out for the people who follows instructions carefully. There’s been 3 people who bought a charger because they were told on here to do so and there were no 120 outlets near their car to plug in the charger. Happened one feller yesterday :ROFLMAO:
    #11 Grit, Jun 4, 2021
  12. Mendel Leisk
    40,238
    Hey, people without computers bought boxed Windows95 when it first came out.
  13. Ed Beaty
    Ed Beaty Active Member
    334
    310
    Salt Lake City
    "cmon, just cus he said it’s like an oil change you start baiting him??"
    This is his essential (to him) task on PriusChat...
